Started to get the new house built
SB440R/T
North Carolina
It may not be too late to change the garage openings, talk to the contractor about it..
Money spent now won't feel bad compared every time you look at the wasted space.
Move the air compressor outside, closed in storage.
I think I am actually ok with it now. The wife can keep all her stuff to the small side of the garage and I can put a 4 post in the center of the bigger area and have room to work. If I put it on casters I can move it to the edge and park 4 cars if needed.
marklc
I would do 50 amp for the welder and 30 amp for the compressor. I think that would cover whatever size of each you end up getting. IMO
SB440R/T
North Carolina
I asked for two 220v outlets and two 110v 30 amp outlets. What is the normal amp rating for 220's? I never specified anything for that.
marklc
Depends on size of compressor and welder you purchase/own. IF you do a 50 amp for a 220V welder and a 30 for a 220V compressor that should cover you now and if you decide to get something larger in the future.
What are the 30 amp 110 outlets going to be for?
SB440R/T
North Carolina
Just thought it would be good to have, I am guessing I am off on that?
marklc
30 amp requires larger wire also #6 for 50 amp, #10 for 30 amp and #12 for 20 amp.
I think your fine with 20 amp 110V circuits.
I'd recommend the 30 amp for air compressor in case you decide to step up to a larger 2 stage or whatever. At least your covered. Same with the 50 amp welding outlet. Easier to have it there now before walls are finished. Again just my opinion. Wire is cheap compared to trying to get it in there later.
SB440R/T
North Carolina
Sounds good. Thanks.
SB440R/T
North Carolina
Weekly update: Plumbing has started and some of the final framing was done.
Roof is working and house is wrapped
Fireplace is framed in
Stairs are in place to the bonus room and storage area. Bonus room will just have the air system and drywall hung. I will finish it off later down the road.
Plenty big for a bed and man room. This is right over the garage.
Bib Overalls
Jonesboro, Arkansas
50 amps and #6 wire for the welder. 30 amps and #10 wire is the norm for compressors. However, some compressors are at the max point and running a 40 amp on #8 wire circuit is prudent.
Compressors generate a lot of heat and they are air cooled. The large pulley is also a fan. A lot of people enclose their compressors to quiet them down without provisions for a constant supply of cooling air.
SB440R/T
North Carolina
Thanks Bib, this is what I had laid out in another thread. Thoughts?
SB440R/T
North Carolina
Great progress. Do you have a closing date yet?
Yea, the house should be done at the end of Sept and we don't close until the 1st of Nov. We would do it earlier, but we have a lease that does not end until the 28th of Nov. Gives me 4 weeks to move everything.
Remythepug
Charlotte, NC
Oh wow 4 weeks is plenty of time to move. We're trying to move in 4 hours haha but don't have that much stuff.
We hired some local movers for a decent hourly rate. (3 guys and a 26' truck) I can let you know if they do a good job next month [emoji106]
SB440R/T
North Carolina
Yea I already started bugging the wife about starting to pack things. I plan on doing most of it except for the big stuff.
SB440R/T
North Carolina
You will see a theme here, all things my wife was interested in and I am not except for the electrical panel.
We have a roof
Doors and windows
Front Door
Two panels in the garage
Cheap guest bathroom that I won't ever probably see.
Ceramic Master Shower
Free Standing Tub for the wife
SB440R/T
North Carolina
Concrete was poured for the garage, there is a center slab that is 8" and 4x17 and the rest is 4". I don't see reinforcement though. Is that an issue if the concrete is 3000 PSI?
SB440R/T
North Carolina
Well finally home after a short tour. Got to do the final picks of the cabinets and then went to go see the house. Concrete for the garage is down and saw cut. The ceilings should be about 11'8' when they are finished. Inside dimensions seem about 23' x 34', lots of room.
Outlets on the left side, one more not pictured. Can also see the light drops.
Front of the house, the roof line of the garage is REALLY high.
stikman56
Looks nice, but why do we always say "building a new house"? Could we ever build an old house? :)
SB440R/T
North Carolina
Drywall is going up and it is starting to really take shape. That portion should be complete the end of next week and then they go on to trim. Siding and the rest of the brick work should start soon also.
Garage
Storage/Golf cart garage
Breakfast area
Kitchen
Master
Reading room
Living room
Bonus Room and stairs
SB440R/T
North Carolina
Maybe I missed it, but why the two panels ?
Just room to grow, I have three 220's in the garage along with the extra lights, outlets, and 30amp 110 outlet. If I ever decide I want to do something crazy it is there to expand. If I don't, it was cheap to add now anyway.
SB440R/T
North Carolina
Few updates, trim has started. I have never understood why you do trim before you paint, wouldn't the seems look a lot cleaner if you painted first?
Anyway, here are a few pictures.
Trim
Cedar mantle
Pantry door
wasfast
San Diego CA
The trim installation just depends on process. One option is to texture and spray the walls, then install trim, then paint trim. Another option is to
install the trim
caulk and fill all the joints of the trim
spray the trim
mask the trim
Texture all the walls
Paint the walls
The latter prevents having to recut all the edges along the trim from caulking and lets you tape on a smooth, sealed surface (the painted trim, likely satin or glossy white). The trim should definitely be sprayed thus doing it first saves a masking step. The walls may be rough sprayed but ultimately backrolling is best.
SB440R/T
North Carolina
Slowly moving along. Well it seems slow, but there is a lot happening.
Garage has its first coat. Keeping it white, but will do some accent color later.
Siding, not a fan of the color, but the wife loves it so I don't really care much.
Master bedroom ceiling is painted
Wood beams are sealed (not what we expected, but still nice)
Trim and doors are being painted.
Cabinet colors, island on the left, mains on the right. The darker colored tile is what we are using for the whole house.
SB440R/T
North Carolina
Starting to look like a house finally. All the siding and paint should be done in the next few days. Hopefully the floors start going in this week. Then it will start to look like its near completion.
Siding going on
Paint in the bathroom
Main color
Accent wall
Main color
Doggie Door
