Yes that's the one, No we don't race at the Glen this year but will be at Sonoma Raceway in Sept. I'm at Mid-Ohio today setting up, here is a picture of my garage for the next four days.Thats the one I saw in St Pete that I wanted but would have to build a bigger garage. Will you be at the Glen on Labor day?
Any pics of a VW with 300 original miles are def worth posting up!
round is a shape
Thanks for sharing this!!!! This is on my to do list for my QT7.5 unitCleaned up this a.m.after the long job of installing a suspension lift last weekend.
I finished up with this little after cooler project.
A little custom work necessary for the outlet of the pump too tank (instead of being a compression fit I welded a -12 an male fitting to it) some SS hose too a big hayden 1290 oil cooler (27.2"×23.4"×2.1") with 3/4"npt outlets. Secured it to the fan shroud with some vinyl cushion clamps, 1/4×20 fang bolts using two 1/8 thick rubber washers on each side of the shroud. Came out nice so far. (compressor is a husky 80 gallon two stage 7.5hp 175 psi) should jave got an ir but for 500 in great shape on craigslist i needed it badly .Anyway from cold start 0 psi too 175 psi I measured just about 200F Outlet temp (measured at the cooler input and I saw just over 90F coming out) .this was with it being at least 90F in the shop . The large pulley does an ample amount of airflow through the cooler to get the temps down. I think an electric fan that came on with the starter would do even better but I don't have a blast cabinet yet or anything that will consume any large cfm of air to see what kind of temps continuous cycles will do .Hoping to find a deal on a hypertherm soon and change that.
Got some semi-related work done. I ordered a new SS table that has nice beveled edges. I wanted a more user friendly table for work, plus to use the original table top on my work bench, as I had planned all along.
The SS table I ordered several months ago has a nice rounded front and a back plate. Perfect for my work bench.
Instead I used the hell out of it as a table with a shelf for my XS-400 build.
I still wanted to use it for my work bench, so I ordered another table with no back plate to use for the table, plus it gave me an extra shelf.
Perfect for what I needed.
Then I stripped the structure from the old shelf and construction glued it to my old work bench surface. Old work bench:
New one with the SS top on it:
Oh, anyone need some washers? I have about 25 pounds of them.
Last night did some multi-point inspecting on our coach for an upcoming trip and noticed the hydraulic reservoir for our slides and generator slide a bit low so topped it off.
I received a package of MT3 drill bits that I purchased off of ebay last week. Then spent the next 2+ hours sharpening the drill bits. HOLY **** is it amazing how people try to sharpen a drill bit. No wonder why they put these up for sale, there is no way they would cut any metal in the shape they were in nor in the manner in which the person tried to sharpen them.
Oh well, their loss in knowing how to sharpen a drill bit properly is my gain I guess.
Mike.
I watched a guy repair our garage door. Now I can do it myself next time!
Tell me how you did it please. Never done it.![]()
Kind of hard to explain by typing. Maybe I ought to do a video of the process.
Basically to keep a 118* tip you want to keep each side of center approx. 59-60 degrees from parallel to centerline. I rest my left hand on the tool rest at the correct included angle with the drill bit faced slightly upward to keep the heel of the bit lower than the cutting edge. I go back and forth from side to side turning the bit 180-degrees in my hand and using my right hand to turn the bit on occasion to keep the two sides equal, but I use my left hand as a guide by keeping the same placement on the tool rest. I also have my cup of water nearby to keep the bit quenched between grinds.
Most of the time I can do this by sight quite easily but when I get to some of the larger ones sometimes I use my small adjustable protractor to keep the angle correct and to measure the distance from edge of bit to centerline in order to keep the bit symmetrical. If the bit is not equal side to side you will get a nasty vibration as the drill bit seeks that center point when drilling.
I would say take what I explained which takes about 2 minutes to read (and hopefully I made enough sense that you could follow along) and multiply that by nearly 30 years of sharpening drill bits by hand and you can get pretty proficient at it.
Improperly sharpened drill bits have to be one of my pet peeves with my co-workers. I have shown many and quite a few have picked up pretty will but there are a lot that just don't think it is worth the time to learn properly. I can honestly say learning to sharpen drill bits free hand is one of the absolute best skills that I learned to master in career. I am always touching up a drill bit and it takes so much less time than using any of the commercially available sharpeners out there and our shop at work has tried about all of them. I still just do it free hand.
Hope that was helpful and not too confusing. Maybe that would be a good idea for a video for my channel. Hmmm.
On edit, I should point out that I am LEFT handed. IF you are right handed you will more than likely want to switch opposite to what I stated above.
Mike.
Thanks for the detailed explanation. I think I will not try it as I am sure I will mess any drill bit I put my hands on![]()
where did you get the cooler? online?
Thanks for the info.
You probably have carbon buildup inside the generator. Take it apart (be careful there is a TINY cleaning pin on the end of the actuating rod), and clean with lacquer thinner.
