kinigitt
UPDATED 10/17/2016
Hi all,
I'm 3 years in on a brand new house, and things are settling down finally to the point where I can address my complete lack of work space.
The main usage of the garage would be for vehicle maintenance, small engine repair, and learning how to weld.
I've moved a fire pit and small oak tree out of the way, so I now have comfortable room for a 34'x28' structure.
It will sit at the back corner of my property, which is roughly a half acre surrounded by a 6 foot privacy fence. I have 14' between the side of the house and the property line, so plenty of room to drive vehicles back there.
So the plan has CHANGED again to 34' wide (eaves) by 28' deep (gable ends), with 10' high walls, topped by a gambrel roof. I'm interested in the engineered roof trusses from barnplans.com
There will be a loft just past the halfway point (18' long spanning the full width of the roof). Structure details are not finalized as far as support for the loft. I would like to eliminate any posts on the ground floor. I want to find out if this is affordable and feasible for a 28' span.
The open side will eventually house a 2 post lift. Tons of room with those trusses.
As for framing, is 2"x6" @ 16 O.C.
5" slab with rebar on 24" centers, chairs, pumped, vapor barrier. Sitting on compacted gravel. (thanks matt)
Roofing will be steel panels, to keep it simple and low-maintenance. Exterior siding hasnt been decided. I will probably drywall the interior, eventually.
1 man door, 2 10'x8' doors
Rough in for a toilet and small sink in the loft
Slop sink downstairs
One drain centered under the lift. Not even sure at this point.
Basic corner staircase to access the attic.
Small cantilevered patio out of the loft? (like Sreno's build)
Compressor tucked under the stairs, with adequate ventilation and access.
Dedicated electrical panel (not sure what size?)
Frame windows ahead of time and cut them out later?
As far as heating/cooling needs, what are your suggestions? It's brutally cold in the winter, and sickeningly humid in the summer. I live just outside Montreal, Quebec.
I was thinking insulated roof, bringing the conditioned envelope right up to the trusses, with an unvented roof. Cellulose sprayed in between sheetrock and roof sheathing? The trusses have plenty of room.
Loft can stay open with a railing or be closed off, eventually.
Adequate ventilation will be important.
Here are a few clumsy sketchup attempts, and some reference pictures of the trusses in question from barnplans.
Hi all,
