Re: The Lone Beech Garage Build Thread (60x46)
Thursday - October 20, 2016
I forgot to mention that in addition to the main quest that took place over the past few days, there was a sub-quest also.
Back in
Post 1113 I noted I had acquired a Powermatic 1150 Variable Speed Drill Press. In
Post 1118 I indicated I had discovered an issue but I didn't elaborate.
The big issue with the drill press was a cracked casting that held the variable speed control mechanics. I had checked the speed before I purchased it by using the control to go from the high speed it was set at to a lower speed. That worked fine.
When I got the tool home, I tried going from that lower speed to a higher speed. This caused quite a noisy commotion under the drill press's sheet metal. When I removed the cover, I found the broken casting.
I checked eBay and found what looked to be just what I needed. Better yet, the seller appeared to be motivated as he had lowered the "Buy it now" price and also had a best offer available. I wound up getting the part for $12 plus shipping. However it was the newer "Gold" paint scheme and my Drill Press was the 1970's "Green" color.
Some research revealed that Rustoleum made a Hammered Dark Green paint that was said to be a dead ringer for the Powermatic color.
Problem solved... Not!
I could not find this item - in a single can - anywhere near Peachtree City, GA. Oh I could order a case from Lowes or Home Depot or I could get a single can off of Amazon or eBay for around $15 but that was it. While technically not Unobtainium, I wasn't going to buy a case or pay 15 bucks for a single can.
Recently I had, once again, tried to look for this product on the InterWeb. This time I happened to find a listing at Menards. We don't have these stores in the south but they are in the Midwest. Indeed, there is one in Princeton, IN just about 20 miles south of my parent's farm. I would be driving right past it as a part of my Lone Beech Melon Farm Sign quest.
I checked the Princeton store's inventory via their web site and found that they indeed had Rustoleum Hammered Dark Green in stock for about $5. As I drove north on Sunday I stopped at this store and grabbed a couple cans before continuing to the Lone Beech Melon Farm less than a half hour up the road.
I hope to sand blast the casting, paint it and get it installed in the Drill Press some time in November.
Scott
