Aussiejake
Looking at purchasing a new 1/2" impact wrench. Heavy diesel mechanic and over my snap on wrench.
And the Milwaukee is rated at 700ftlbs... (Which is why people buy it)
https://www.milwaukeetool.com/power-tools/cordless/2763-22
Milwaukee's smaller 1/2" is like 180ftlbs, which is pretty respectable..
The Ingersoll Rand 1/2" high torque is rated at 780ftlbs...
http://www.ingersollrandproducts.co...ols/iqv20/w7150-1-2-20v-high-torque-impactool
Their new high power small 1/2", (that also comes in 3/8) is 365ftlbs
http://www.ingersollrandproducts.com/am-en/products/tools/Iqv-cordless-tools/iqv20/w5152
And their 1/2" right angle impact with 180ftlbs
http://www.ingersollrandproducts.com/am-en/products/tools/Iqv-cordless-tools/iqv20/W5330-W5350/w5350
IR also makes a similar looking 20v ratchet, and lighting as well.
Again, it's smart to invest in a platform, not just your first tool.
Also the platform argument is how all you guys got sucked into getting a few good tools and then a whole bunch of mediocre tools. There's no one manufacturer that makes the best of all. If you're going to have more than 3 batteries anyways (which most of you do), you might as well get the best tool of each brand.
No offense to anyone here, but please try to demo the Ryobi 1/2" impact before you go any further. I Use the 4.0ah lithium batteries, and am beyond impressed. I use this thing professionally daily. Ryobi claims 300 ft lbs, and I believe it.
http://www.homedepot.com/p/Ryobi-ON...-Speed-Impact-Wrench-Tool-Only-P261/205885687
Whoops, just realized you're in Australia, do you have Home Depot down under??
300 ft. Lbs. ........pretty weak sauce
Unless he means he works on locomotives when he says he is a diesel mechanic, the torque difference between 325lb-ft of the Metabo and 700 lb-ft of the Milwaukee is meaningless. Compact size and low weight are king in the world of auto technicians. Go with the Metabo.
If you're going to go 1/2", you may as well get the cream of the crop. Why spend all that money on a tool that might not be able to remove an over torqued lug nut one day? I think 400 ft lb's is a pretty meaningful difference. A 3/8" can be purchased later on to achieve the compact size and low weight aspect, while using the same battery.
LOL. I feel bad because he was being serious...
For 99% of what I do, this impact is more than capable. Laugh all you want....
I turn wrenches for a living, do you?
Let me put it to you this way, I maintain an entire counties worth of aerial equipment by myself. My Ryobi will tear 160 ft lb torqued lug nuts off of F450's no problem. I use my air in the shop, but when on the road, the Ryobi is priceless. I have over 60 vehicles in my fleet, repaired and maintained by no one but me. There is no cordless impact that will pull the crank pulley bolt out of a D8 46a. Ask me how I know. That's where 3/4 guns come into play. Cordless and heavy equipment don't play well together.
While the Ryobi might be "good enough" all impacts and batteries are not created equal. There is a reason why premium stuff is more expensive. I know these are not the same tools - but rather a battery comparison. If you watch "Real tool Reviews" he did a demo on Makita's new compact (almost the size of their 12v) 18v impact drivers. Running their smallest 18v on a 2ah pack, the Makita drove almost the same amount of deck screws into pressure treated lumber as Ryobi's full size driver using a 4ah pack in a separate video. While many people choose to run stuff like Ryobi in a professional setting, (mostly due to cost savings) they really aren't designed for the constant abuse, and warranties might exclude that. (I've read this has been the case with PC for some people) I've watched a few YouTube videos comparing the Ryobi impacts wrench with better brands and the results are pretty clear why the more expensive stuff costs more.
I do. I work on motor coaches, they use the same running gear as trucks do, with heavy suspensions of course. My M18 2662-20 can take lug nuts off. I'm not saying it's a good idea, but it will and I have as well. I don't need air very often working on them and air hoses are a PITA as far as I'm concerned. With the small air hose my IR 258 would not remove them the other day and the Milwaukee did. I think you might be using cordless impacts with lesser torque, when you're speaking of heavy equipment? Cordless 1/2" models are as strong as air now. My Nitrocat 1000M does no better than my Milwaukee, they are pretty evenly matched to be honest. I tested them side by side on a wheel one day out of curiosity,both take about the same time to remove a lug nut that was torqued properly. Go figure. 10 years ago if you were to ask me I'd have said I'd never thought I'd see that day come. There's stronger cordless than the one I have.
If you're down for chasing specs, then go ahead and get the Milwaukee. It does that well, but swinging a 7 lb tool around daily isn't for me when a 4 lb tool will cover 99% of the workload. I've had that compact 18v Milwaukee as well, and it does fine, just the Metabo is 50% more power and has better torque control.
No offense, but I am fairly certain you are a lineman working for a company very similar to mine (although smaller). I don't care about videos, I don't care about YouTube, I care about results. I've had my Ryobi next to Milwaukee in the field. The difference is dismal. I had the original Ryobi 1/2 impact, and I was sold. I bought the newer version, and swore there would never be a red or yellow cordless tool in my box again. I am extremely satisfied with all of my Ryobi cordless. Why waste money when you don't have to?
Then you have a faulty nitrocat
Well, all I can say is my corded IR's are rated at 300ftlbs, and my Milwaukee is rated at 500ftlbs (200 LESS than the 1/2" drive version). The results are quite clear to me. Also - it's the platform I invested in. If Ryobi ever makes towers lights, lights I can drop into manholes like the lanterns and original m18 floodlight, cable cutters - maybe I'd reconsider. But getting half the runtime from Ryobi's 4ah batteries compared to a premium brand is not something I can ever overlook. (besides the fact that Ryobi doesn't make a 7/16 hex drive impact) the 5 year tool warranty is another benefit. Brushless motors are another.
I'm sure nearly any cordless impact will work fine for driving a lag into a pole.....
