The Machine Work Thread
paranoid56
San Diego, Ca
made a spinning top out of stainless and a ceramic ball bearing a the tip. first time working with stainless. hoping the next one turns out better. but overall super happy with it.
qst3Qllq5xxODmFCYu04ufqZSEiXs4wUbHOjV4yUG2pEM8fBoyLCHwAmLNDEkISwtusQRYt_vF9XpogriUiKmmq13q7sjKsFLaCCR373q7LrG2taKia_LMCRQVHbwRik-dnp3qKw55CuUDsuhf5hUdGlZ9BBuejnW-XMrwqr35e9zWfYk8kuStW1WBkrkv3QiNDyNhxOcIUDYzfnh3OiNPvPA5Ics3TMyH2WeKJhLq7lrJe_xWX2MpH2JH_e9_0m_4d1o_7zV4ll7nRk8AjAvA8NlaV002LEFbbddjgP9xeHeb2-Tgqit0RydtSOAvDIvcVFSjrEJJWu2hT8cy_QJtZSkiIr0_P2nsmU0Wv83EXeOhdKDJB3FqnZbW0yImCGA288L0sWMrAoDKQXXjUlDgYjHbikMAJcu2_XgkW-_y6CO0Ub_tCBydiSEZI6AICBIHyLbReJWNjJso0F0bnoDDfQ4Ed9V4cfYbBy_VCrarKttte4TodLbfew_m3Oq4p7d36TChHvOLB36hjZxoWd3Fjk5haCE5TWHgt0bSociNwpwxh2zzmcjjTopipqMjtX3t6K88PqfUl6iD4vroACyJHU7kUusfZLQuZY60buZG4=s749-no
bullnerd
Jersey
Paranoid have you ever seen the spinner stuff on Instagram?
Some guys spending A LOT of time on those things!
KMScott
Jim Johnstone;6101606 Partially done a set of connecting rods for an air compressor.[/QUOTE said:
Nice work Jim, what type of aluminum did you use?
I had some time on my new HAAS TM-1 CNC that I fit in my basement. Had to lower it 9 inches to fit. I have a couple 2" Wilton Baby vises with no swivel bases and decided to cut a few out of a 3/4 plate. I clamped and bolted down the 3/4 plate to a aluminum Tee style plate that is clamped in my Kurt, this gave me a nice platform to machine these swivel bases.
I used two different angle cutters, a 10 degree on the top cut above the ears and a 7 degree on the bottom, kind of looks like a radius on the side llike the original bases.
Made a fixture to cut the bottom.
The inner ring was easier to cut.
Even though it is not original it came out pretty close to original but once painted it will look pretty close. The steel will not break like the cast base if dropped. That is what I did on one of my Baby base's, I dropped it and it broke.
KMScott
Have you had a look at autodesk fusion 360?
I'll be honest, I can cut anything I want including cores and cavities for molds. I was software broke back when I was building Molds. I used Hypermill nested in Mechanical Desktop but have since moved back to Mastercam 9 which cuts anything I build now. I am going to explore Fusion 360 because I am curious. Thanks Jim.
I am curious on brazing bronze to aluminum and will be checking in now and then. Good luck on your rod building.
Jim Johnstone
Brantford, Ontario
Thanks, my fabricator is waiting for a sample of some brazing rod from his supplier to test it out.
JMarshall
Oklahoma City, OK
A few things i have made over the years. I own a small machine shop, with for the most part state of the art cnc machines. 3-4 axis machining and turning centers. Also have small to medium manual lathe/milling machines.
bullnerd
Jersey
MC9 Here too! :thumbup: But I only have a 2 axis P-trak.
bbcc
Edmonton
Prototyped an on head spring compressor for LS cylinder heads. Working on my junky round column mill drill, best machine I could afford. First project I've pushed through it to date. With the process more or less figured out I'll be producing a few of these and some other parts for local guys. Goal is to do enough work to pay for better machines!
Also played around with some "walking the cup" on the weld. So if it looks ridiculous that's why haha. Not the application for it but for a prototype I figured why not.
Jim Johnstone
Brantford, Ontario
Neat little job today. Customer dropped off 2 stainless flanges and asked us to make a split flange from them.
H
Hephaestus29
Indianapolis
Those pieces with the two U shaped
places milled in the ends look just like
the S.S. mounting brackets that are on
some restroom partitions I bought.
H
Hephaestus29
Indianapolis
Looks like an interesting Job.
Jim Johnstone
Brantford, Ontario
Nice job on the flange. How about describing how you did that?
Well the first thing I did was sit at the computer and draw the flange in solidworks and sort out exactly how I was going to split them to fit each other.
Next I had to sort out work holding, I ended up putting a long 5/8" stud through a 246 block and bolting the flange directly to the 246 block using the one bolt hole that didn't get cut.
Next up was locating the bolt holes since both halves needed to line up precisely when they were done. I did this by finding center on the left hand hole, zeroing out the machine control, then finding center on the right hand hole, writing down the X and Y coordinates relative to the left hand hole and calculating the angle the flange was sitting at. Then I imported the solidworks model of one half of the flange into mastercam, rotated the model the same amount as the calculated angle, and started making my programs.
Started out with a 3/4" mitsubishi carbide inserted tool and made a program to run along the outside leaving 0.015" on the wall and cutting off the excess. Then using the same tool I machined down the pads leaving the same 0.015" on the wall and floor. Then I switched to a 1/2" solid carbide endmill, made a singe pass on the outside of the "V" face to -0.005" and did a finish pass on the pad to -0.005" on the wall and 0.000" on the floor. I left the tool a few thou high so I could mic the thickness and then drop down the tool accordingly to get it on size.
After that, put the other one in upside down compared to the first one and repeat all the above steps.
H
Hephaestus29
Indianapolis
Here's my latest re-purpose, with quite a bit of machining, so I thought I'd post it over here too.
It's a Bosch Plunge Router Base, turned into a power draw bar, using a butterfly air wrench like other people have done. I may be the first to use a plunge router base though. It already had the springs and smooth up and down motion to do the job. I still have to make a handle for it since I'm not using a cylinder to force it down, I might try that later if it proves to be a pain in the a$$ but it will still be much faster than hand tightening with a wrench every time.
It still needs plumbed in also but you get the idea.
H
Hephaestus29
Indianapolis
I spent a little time organizing my files tonight and milled out the slots in this plastic to make a little file rack.
Griff93
Huntsville, AL
We made some weld on tow points for the bumpers we're building in our 'new' cnc mill. This sure beats the heck out of the old way of doing them with a manual bridgeport and a rotary table.
chrisBTSC
Folsom, CA
I'm super curious as to why the customer wanted a split flange. You can't install that onto a tube or pipe in halves so what other purpose would the split have?
Jim Johnstone
Brantford, Ontario
I'm wishing I had an opportunity to speak directly with the customer, boss just brought me the flanges and told me what they wanted. I did point out to the boss that the rad closed up past the 180 degree point, he replied "make it to the print". They never brought it back to rework so I guess it must have done whatever they wanted of it.
chrisBTSC
Folsom, CA
I've been thinking about this because it's bugging the **** out of me. The only real conclusion that I can come up with is it's going to be welded onto a pipe that is already in place (installed). Maybe there is an obstruction of some sort that they have to rotate the halves around before they reach their weld-on spot.
Mario428
PEI, Canada
I see the flange had a large radius on one side. This is not a typical flange. It is used onn what is called a "stub end" https://www.mcmaster.com/#45735k296/=16gymkw
The stub end is welded to a pc of pipe with the flange in place. I am guessing they wanted to replace the flange without rewelding the pipe.
Very nice machine work.
matt_i
SE Michigan
Yeeaahh, thats not going to brand exactly the way you want it.
It needs to be english-readable from the top side, and mirror-image viewed from the "wood side"
However its a beautiful job!
I was thinking if you could tig weld some bracketry to the pieces, then bandsaw thru the thickness and cut off the heart and the letters (or machine off the backside), you would then have what you'd need. The bottom surface would then be the working/burning surface.
