Do Ratcheting Adapters for Wrenches Exist?
winlinmac
USA
Not to be confused with ratcheting adapters for breaker bars and such.
I don't want to have to spend extra for extra long / jumbo ratcheting wrenches. Are there ratcheting adapters available in which I can insert into the box end of an extra long wrench?
SuzukiGS750EZ
Do you mean something you can insert in the box end of a wrench that would allow it to turn into a ratchet or something you can click in to make it an open ended ratcheting wrench?
Tim37
I haven't ever seen any thing like that.
I think the issue would be size of wrench needes you would probably need a 1 1/2 wrench to accept a 1" adapter.
W
winlinmac
USA
Not sure if this is what I'm looking for. I'm thinking about a non-ratcheting wrench that can be converted to a ratcheting wrench to make it easier to drive the fastener around. I think the Wera Joker wrenches are somewhat able to simulate that ratcheting effect but still requires you to lift the wrench and turn.
If something practical is available, then I don't have to look for extra long ratcheting wrenches which tend to cost over a triple digit figure.
Are these what you are looking for? Or do you want them to ratchet too?
https://www.amazon.com/dp/B0002NYCZE/?tag=atomicindus08-20
Also comes in a set to fit SAE wrenches.
SuzukiGS750EZ
It depends on where you look and what sizes you need. I wouldn't imagine you would need an extra long wrench for anything under like 13-14mm. So a 14-21mm set or something of the sort would be fine. Plus, most are double box end. So you get two wrenches in one. 4 wrenches and you have the spread. What do you consider too expensive for a set?
WWheeler
Middleofnowhere USA
This isn't exactly what you are asking for, as it's not an adapter, but several brands have made 'speed wrenches' or 'quickwrenches' or whatever gimmicky name they came up with (I've got old sae/metric sets of Craftsman "quickwrench" like shown below) that have an open end designed to let you use a ratcheting motion to be able to turn the fastener without lifting or removing it each turn.
I only mention them because you brought up the Wera Jokers with the 12 pt open ends that, as you said "still requires you to lift the wrench and turn". These similarly work on the open end but without having to lift the wrench. They are good time-savers for turning on or off but notsomuch for breaking loose or torquing down tight. For that you're better off to flip the wrench over and use the box end.
I don't think Craftsman makes them like that any more, but not too long ago I saw they had brought back the same design in their black oxide 'mach' series of tools called 'ratcheting open end wrenches' or some such.
I've seen Snap On had similar sets at one time also. Not sure if they still do.
Ign
Butte Peak ND
What if you took the GW "hollow" pass-thru ratchet/sockets & just shortened the sockets a bit?
Craftsman marketed this too, particularly w their cordless ratchet. Can't remember their name for it?
WWheeler
Middleofnowhere USA
I believe Craftsman called them 'Max Axess' and GearWrench 'Pass-Thru Vortex" but there are a gazillion other brands too and many will swap with each other.
Which Pass Thru/Go Through Sockets/Ratchets Swap/Interchange?
http://www.garagejournal.com/forum/showthread.php?t=209810
I have a large Craftsman set of these and I'm a fan. They have worked for me quite a few times in places where the only other option would have taken forever and a day. It's can be a serious time saver to get a ratchet where a ratchet doesn't normally go.
Derek420
Southern Indiana
They make them in sorts at least gear wrench makes inserts for the box end on ratchet wrenches that allow you to make it a ratchet so you can use sockets. They make them in 3 sizes for 3 size wrenches. I think they are awesome and I own the set. Check them out.
T45
OP, this thread is ????. Just buy some XL ratcheting wrenches.
ratcheting adapters are >expensive and have >huge stack height
they also > need to be assembled/disassembled every time used /change sizes.
Those 3 points in combination defeat the point of >saving money (expensiv) and the benefits of ratcheting wrenches in the first place (no assembly of sockets, low stack height)
M6erfan
'Merica!
I've seen them but unless it's for compactness in your tool kit (which is important in some instances), I dont see the point.
WWheeler
Middleofnowhere USA
The GearWrench ratcheting wrench serpentine belt set is a possible fit for what the OP wants. It's a long handle adapter that fits into one end of an included ratcheting wrench and a set of various sized thru sockets, square drives, crowsfeet a 3/8 adapter that fits into the other end of the wrench.
If you're looking for that XL reach this tool has it, and it can accept regular 3/8 and compatible thru-sockets as well.
T45
If the op really needs this, he can make it work but its not cheap.
> snap on xdhrm11
> snap on low profile 1/4 drive metric socket set 5-14mm
This has a pretty low stack heght, is long, it ratchets, and its good quality, and takes up minimal box space.
Downside is it cost $250 new, and the sockets have alot of chamfer which make them unsuitable to everyday use without being kind of annoying. you also need to be careful not to back a chamfered bolt into an obstruction, as the ratchet doesn't reverse and thethere is less clearance than using a normal ratchet wrench. This setup is also not suitable to abuse as the 11mm ratchet wrench is not very strong when used with larger bolt sizes like 13/14mm.
So i think the general advice is to spend maybe 70 bucks on a small set of imports if budget is an issue. If its not an issues, lots of options abound to save space.
W
winlinmac
USA
Whats the lowest price the Gearwrench XL Ratcheting Wrench set has ever went for? Looking over the options here, this may be the only viable option. Thanks
> snap on xdhrm11
T45
PROMO
KDT-85988 12Pc Metric Xl GearBox Ratcheting Wrench Set 8-19mm
+ KDT-85998 9pc GearBox Ratcheting Wrench Set SAE
Code: KDT-85988C
REg $196.98
On Sale $140.70
http:// www.ntxtools.com/ network-tool-warehouse/KDT-85988C.html
:beer:
Edit: if you need cheap, this set is $75
Neiko 03114A Flex-Head Double Box End Ratcheting Wrenches
Extra Long Design | 5-Piece Set | Metric 8mm - 19mm
https://jet.com/ product/detail/669c115aba7a4be8b8f2ef676471b673
Tom.C
Why don't you just buy socket caps? They come in sets of 3, The only way your gonna turn large a standard combo wrench into a ratchet is with a welder a Palm ratchet and or ratcheting breaker bar head, and some enginuety.
W
winlinmac
USA
Thanks T45, the Gearwrench looks good. Hopefully, this Friday, I'll be able to come across a coupon which should in turn bring cost further down, if not Neiko or even a fewer-piece set should do. :)
I see a few 5-piece sets on eBay going for $30-$40
PROMO
Code: KDT-85988C
REg $196.98
On Sale $140.70
:beer:
LXCam
This could possibly be the dumbest tool to own. You're literally asking if a ratchet exists.
Buy a damn stubby ratchet in each size then some tubing to make various cheater bars out of. Then you can have any length your little heart desires.
You should really start buying your shrums from someone else willy, your threads get crazier by the day. :eyecrazy:
