Show your new tool arrivals
[memphis]
My new Gray Tools haul,
1/2" Chrome Sockets
72t 1/2 fixed head with hard plastic handle
3/8" and 1/4" roto heads (Dynamic is Gray's Import line)
The 3/8" roto is super stiff... drag back is insane on it compared to the Canuck 1/2" drive above it
1/4" feels great,
I think these are Harbor Freight in disguise... Not as cheap but lifetime warranty at least and 1/4 the price of snap on
Pocket screw driver
Not pictured are two 6pt wrenches for brake bleeders, also bought some Ullman picks (re badge for Blue Point) and gear wrench palm ratchets
ptgarcia
Alta Loma, CA
Carquest
South Carolina
The result of too much time spent on Ultimate Garage website!73c82efa21b76d426bed2130287402a8.jpgd99f8c091cb5cdcdb1f5df4f9a830214.jpgfbc4d6066d03a1fdb5a29c230de01e2f.jpge7b4903b68d4a2fed0a1bc1d2177f57d.jpg
stonesfan68
Houston, TX
I picked up some SK long-pattern metric combination wrenches. The chrome is nice!
NoahG
Detroit, MI
The usual. Like I needed another multi bit. c2740d1d612c21cbfc50ae76dccf9433.jpg
Tyguy1209
New wrenches 0° offset
Knipex
Pier deal he had
Promised me a heated jacket next week
Sent from my SAMSUNG-SM-G891A using Tapatalk
MattVette89
SW Chicago
1/4" feels great,
Identical outside of color. I bought the HF 3/8" a while ago to try it myself...I think it *****.
MattVette89
SW Chicago
Thats cool, both together, part number? Wonder if it comes like this in wobble plus
1438tfpk.
Not sure on the wobble plus. I can't find any info about this set online. Not sure if it's too new, an old promo, etc. I picked it up from ebay.
walkerbait
My first ratcheting screwdriver. For some reason I expected the ratcheting mechanism to be smoother. It seems to "catch" a little at one point in the 360 rotation every time around. Anyone have one and know if this is normal?
T45
/QUOTE]
Hmmm....should have a very light action...if its New-new have the truck look at it. if its an ebay purchase, disasemble and clean/lubricate the mech...
FYI there are threads on GJ somewhere on the internals. good luck.
Qualitytools
SOCAL
/QUOTE]
+1 I checked the link about taking one apart and lubed it although mine was fine but afterwards, WOW! quieter and smoother after that :)
Qualitytools
SOCAL
You will like those ratchets as they extend and come in handy when you need that extra bit of Umph!
chrisnazzy
Arizona
You should be able to grip the knurled part of the shank between your thumb and pointer fingers, roll it back and forth and get the ratcheting mechanism to spin quite freely. If not it certainly can be disassembled and re-lubed.
dodge610
North Canton Ohio
354eab0185531c030f8848fdf9436651.jpg8034a2a48be5f6104cd83a7e7ea7cfc1.jpg85f46e9200b1a1f456783802dcc263f2.jpgKobalt 20 of. Hi biz green screwdriver set from hot deals section.
walkerbait
Thanks for all the comments on the ratcheting screwdriver. I have been at work all day, but will take another look when I get home. I also contacted Snap On to see if it's normal and to ask about warranty repair service (I ordered this new off their website).
Is there a specific lube that goes in these? I have no plans to take it apart myself since I bought it brand new from SO, but just for future reference I guess.
txusa03
Have too many already and did not need to see this especially in green🙈
Damn garage journal😀
Mastermind
Ypsilanti, MI
I did find the perfect remedy added led strips , mag switches with normally closed/open optio s so you can wire them your way. If your handy with soldering even better.
Yes i have about 50 bucks into both lockers, etter than 450 from snap on . With 4 strips (2 on top ,2 on the top inner panel of the locker) all out of site when you open and work great. Though it took more strips to get the same lighting as the snap on unit . With a bit of time and work ill be adding more to the back of the lockers as well as my power drawer. The possibilities are endless
To the goods
https://vimeo.com/195588335
https://vimeo.com/195588512
Here is the parts used on amazon
Magnetic Switch https://www.amazon.com/dp/B0009SUF08/?tag=atomicindus08-20
LE 16.4ft LED Flexible Strip Lights, 300 Units SMD 3528 LEDs, 12V DC Non-waterproof, Light Strips, LED ribbon, DIY Christmas Holiday Home Kitchen Car Bar Indoor Party Decoration (Daylight White) https://www.amazon.com/dp/B00HSF65MC/?tag=atomicindus08-20
LE Power Adapter, Transformers, Power Supply For LED Strip, Output 12V DC, 3A Max, 36 Watt Max, UL Listed https://www.amazon.com/dp/B00DKSI0S8/?tag=atomicindus08-20
You can add connector if you dont wsnt to solder . I also used the 3w power supply vs the 2a you can buy with the lights because i may run alot more and utilize one power source.
Thanks man, should save me some double sided tape! I got a set that are little housings with I think 5 cob leds in them, then a couple feet of wire and another housing, 10 or 12 total. Stupid brite on a 9 volt battery, but I have a converter already as well. I'm just gonna mount the rocker switch inside. Thanks again for your inspiration.
isb cornbinder
I got a screaming deal from Amazon for this AC fitting crimp tool. I ordered it on December 4,2016 Amazon shipped on Dec 6 and the tool arrived at my door on December 7.
I got the Snap-On toolbox for $50 on Craigslist and the Snap-On retractable for $20.
PelicanPines
Got some new Hex sockets... but I posted them the other day... Here is the socket organizers I found on Amazon... I got the red set (1/4,3/8,1/2) a few months ago... they didn't offer other colors at the time.
They now have BLUE and BLACK... but the black has a different brand name. They are all the exact same quality and finish/material. Very high quality.
I will be modifying them slightly... there is a hole on both ends... I plan on putting a drawer pull in one end so it is easy to grab the whole rail.
K-Dog
Millersville Maryland
Thank you so very much.
walkerbait
Added the F80 and TF72. The ratchets are multiplying!
Qualitytools
SOCAL
I use Super Lube you can purchase a tube from Harbor F.
78C-10
No. Illinois
Bought this from our SO guy today. Did I need it? Heck no. Did I want it? Heck yeah!!! Been on his truck for a long time and I finally said I had to have it. Going home for light use. ;)
MattVette89
SW Chicago
Picked up my replacement screwdriver handle and the 1/4" driver I ordered:
Merry Christmas from my Snap On dealer.... greatest socks ever...
walkerbait
3/8" semi-deep set arrived to match my shallow and deeps.
