I did find the perfect remedy added led strips , mag switches with normally closed/open optio s so you can wire them your way. If your handy with soldering even better.
Yes i have about 50 bucks into both lockers, etter than 450 from snap on . With 4 strips (2 on top ,2 on the top inner panel of the locker) all out of site when you open and work great. Though it took more strips to get the same lighting as the snap on unit . With a bit of time and work ill be adding more to the back of the lockers as well as my power drawer. The possibilities are endless
To the goods
https://vimeo.com/195588335
https://vimeo.com/195588512
Here is the parts used on amazon
Magnetic Switch
https://www.amazon.com/dp/B0009SUF08/?tag=atomicindus08-20
LE 16.4ft LED Flexible Strip Lights, 300 Units SMD 3528 LEDs, 12V DC Non-waterproof, Light Strips, LED ribbon, DIY Christmas Holiday Home Kitchen Car Bar Indoor Party Decoration (Daylight White)
https://www.amazon.com/dp/B00HSF65MC/?tag=atomicindus08-20
LE Power Adapter, Transformers, Power Supply For LED Strip, Output 12V DC, 3A Max, 36 Watt Max, UL Listed
https://www.amazon.com/dp/B00DKSI0S8/?tag=atomicindus08-20
You can add connector if you dont wsnt to solder . I also used the 3w power supply vs the 2a you can buy with the lights because i may run alot more and utilize one power source.
