building a 60" x 24" workbench
Atlsud
I'm planning a 60"x24" workbench and wanted to ask some experts on construction.
It will be built with 2x4 and particle board tops. I was initially thinking of using the simpson tie kit but I was given a nice pocket hole jig. Would the screws in the pocket holes be strong enough?
Thanks in advance!
73RR
Blank Email
Central Ory-Gun
You'll be better off with a metal frame.......and if you want a really stout work surface, shop around for a short piece of glu-lam beam.
A
Atlsud
It will be freestanding on 3" casters. General purpose with a heavy vise on one corner. Will also use for miter saw and work surface when wrenching on the car.
zippy99
Elmer, NJ
Thanks in advance!
Pocket screws in softwood are not going to stand up. I have a mobile bench that I build using the simpson brackets for the same types of uses you mention and it works great. Added bonus it went together really fast. You should be able to build the whole thing in an hour or so.
matt_i
SE Michigan
The welded tube frame would be my advice as it won't need any "X" bracing via metal strapping or other.
James-W
Southeastern Wisconsin
I've built some 2x4 workbenches and went through several designs using screws, lag bolts, lots of bracing, etc. This is the sturdiest design for a small, wood workbench that I've come across. I've built several this way now and have been very happy. Take a look.
I agree, that is a very strong design. The only thing I would do is to have a brace from the center bottom of the legs (on the brace going between the the end legs) to the center of the bench on the bottom side.
Cyberbear
California
A lot depends on the weight the bench will be subjected to. Personally, I'd opt for the corner legs to be 4 x 4 with a let in notch for vertical strength and only rely on glue and bolts to hold it all together. The top can be anything solid in nature and then covered with replaceable real Masonite. The bottom shelf can be plywood of suitable thickness and acts to support the legs. The casters should be the lockable type to keep the bench from rolling all over the shop when positioned. Under drawers can be added for small tool and supply storage. Adding a four outlet box is a real convenience as well in order to always have available electrical power wherever you are working for portable power tools and lights, etc. These benches are fun to build and will last forever w/o extreme abuse. My personal bench size is 48" x 72" for portability and being stable under heavy loads.
R_einan
Eastern WA
I've built a couple of work benches, all using a design my father in law showed me. The one I built in my last shop was a free standing unit. It's hell for stout, and I've had a ton of weight on the design. Using 2x4 for legs, place a horizontal board running the length of the bench at the flush with the tops of the legs. Then place a 2x accross the top of each leg extending out over the horizontal support, tying both sides together. Then a 2x2 filler between the top ties. Then attach the top around the perimeter and across the center supports. You can add a lower shelf at whatever height you wish using 2x2s. For a rolling bench I would upgrade the corner legs to 4x4s.
MushCreek
Upstate South Carolina
This is how I build them. Very strong and rigid. The key is using GLUE and screws. The legs are made out of plywood with a 2X2 in the corner, again, glued and screwed. I make the plywood pieces 8" at the top tapered down to 4" at the bottom.
bczygan
DETROIT! Arsenal of Scrappers
That is very far from the sturdiest design.
The lateral strength is all in the joints:
The design of a bench depends on it's use.
Some need mass and some need light rigidity.
The OP sounds like he needs a medium duty bench that has a top with enough strength to work on and a frame rigid enough in all 3 axis, yet also light, so it can be moved.
2x4's and sheet goods are his preferred materials and they will work well.
Frame it up as desired with the 2x4's using whatever joinery is desired, but make sure to frame in a bottom shelf at the base. This will make the bottom of the legs rigid and give him something to mount the casters to.
Being only 24" deep, and on casters, this will be tippy front to back, so it needs ballast. The low bottom base will give him a place to put tools and toolboxes to provide some ballast.
The top can be anything he wants.
But the secret to lateral strength will be what mushcreek proposed. Sheath the 2 sides and back completely with plywood, glued and screwed. I wouldn't do any fancy sloped legs like he shows, just full cladding, tying the framing all together.
Bill
Furley
Thanks in advance!
I built this one with a few mods. First, I lowered the bottom shelf to give me more space for tools. Second, I put it on lockable wheels to make it mobile, yet sturdy when locked. Third, I made 3 equal width drawers. If I did it again, I would put the drawers on slides. It has been great for both woodworking and mechanical projects.
http://www.familyhandyman.com/workshop/workbench/simple-workbench-plans/view-all
rick carpenter
Huntsville, East Texas
Arlsud,
Bczygan has some good advice building off what MushCreek posted re the cladding. But I think you can come up with a close second that's more accessible if you made a lower shelf then clad four ~12" plywood strips horizontally under the top and the shelf. You could cover the strips with pegboard mounted to some 1x stand-offs. I think the pocket screws would pull through after a while so I suggest you be sure to use fender washers with any screws/lags/bolts directly into the wood.
I used a 1-3/4" industrial particlewood door for my bench "sub-top" with 1/2" mdf as a sacrificial topper.
Bdbecker, that bench is a beauty!
Catadj78
Alabama
Don't know nor care if it's right or wrong but it works for me
matt_i
SE Michigan
Some people use oak flooring as a bench top. It works really well and the cost isn't terrible.
I did this with some 3/4" solid maple flooring. I ripped the tongue off to make sort of an "edge band" with the groove facing down. Its nailed to a solid door and then a steel tube frame underneath. Have to get a pic, its approaching 20yo now!
bczygan
Some attention needs to be given to the casters.
Since the bench will be narrow front to back, they should be mounted as close to the corners as possible. The top should also not overhang the box too much either.
And the casters should be carefully chosen. They need to be a big enough diameter to roll easily on the surface it will be used on. Larger diameter will roll over rougher surfaces. But it needs to be balanced with a width and grippiness that will keep the bench stable.
As mentioned above, at least 2 of them should be lockable.
Bill
driftpin
I chose to use commercial products instead of making my own, but I just used a frame from Sears, and made my own tabletop. I got one of the formed sheetmetal Craftsman frames. It's 2' x 8' and I topped it w/a 4' x 8' x 3/4" CDX plywood sheet ripped to make two 2' x 8' pieces, which I them glued & screwed together to make the countertop. I went to a sheet metal shop and bought a 3/16" steel sheet and 3/4" strips to case the edges of my wood tabletop. I made the dimensions of the steel sheet to overhang the wood tabletop by the thickness of the edge steel banding. I wanted a surface that I could put mechanical components onto and wail-away on them without having to worry about denting a thinner surface, as-in some lighter gauge of steel sheet. I countersunk the holes in the 3/16" sheet steel so I could use flat-top machine screws for a flush finish. Since the top surface does tend to oxidize, I keep it waxed. I've thought about getting a cap of stainless steel to just sit on-top, but it's not high on my priority list. Underneath I have Craftsman drawer roller cabinets, or shelved cabinets, all on casters, the three fit perfectly. The workbench is against a masonry wall, so a few fasteners into that, and it's as rigid as you could want.
Above the countertop I have Whirlpool Corp. brand Gladiator wall panels for adjustability of hanging an assortment of frequently-used tools. I also have my cordless chargers mounted to the wall panels to get them off the benchtop, I made some plywood brackets to mount them using the stamped-steel brackets Gladiator includes with their wall-hanging cabinets, but which I didn't use for cabinet-hanging, as I tapconed my 30" x 30" x 12" wall cabinets in-place.
I made sure I used 4" electrical boxes so I could wire-in two duplex outlets at each box. The 4" boxes are 3' o.c. I also have a 20 amp 220 volt box for my Powermatic 64 table saw I bought from a Coast Guardsman in Key West, the best $125 investment I ever made.
I installed a Harbor Freight Tools (HFT) 50' air hose retracting reel above the workbench. When I'm done with work, I simply blow-out the overhead doors all the floor debris of a small nature, the big stuff and metal shavings I generally sweep-up to prevent trauma from it lying in the driveway, or getting embedded in someone's shoe sole, and then defacing the interior of the house's red oak floors we recently re-finished.
All the Gladiator and Craftsman stuff I waited until it went on-sale, I saved up to 80% (!) off the retail cost by waiting for close-outs and sales. The roller Craftsman cabinets under the workbench were $325-400+ retail, I paid $84 apiece. When the salesman told me the price, I asked him, "how-many do you have at that price?" I bought them all, limited to 'stock on-hand.' The workbench frame was $208 retail, I paid $80. All was new-in-box, not returns. I don't have the time to spend making all the cabinets and drawers I would need, so this worked out well for me.
I like reading about how others approach the construction, in my case, it was easier to just get permission from "The War Dept." to get new stuff, and then to buy it. The Gladiator cabinets are welded, though they do have knock-down ones too, I found the welded Pro line to be more-sturdy.
Always_Thinkin
Illinois
Do you happen to have any pictures of your workbench? Curious to see what it looks like. I have always thought this was a good design, one of my favorites.
Know Wosad
Mr. Soup
Troy, Missouri
My son and I built this one for him from a box of leftover hardwood flooring and some scrap stuff laying around. You don't have to get fancy just use what you got.
johnehr
Oak Grove, Minnesota
I used a simple 2x4 design idea that I saw at one point on GJ... works great, adaptable to desired size, easy build...ffbeee28c73b8a72b453ade4e9d3fa6b.jpga14e2e399d9070e79a22e8330535e5b0.jpg4bc794c8fa7b92ee9b009241ca7647d8.jpg6350e67a7ffc19c73243513bf8fd356b.jpg
