ptgb
Have decided to sheath the interior walls of my new 24'x32' garage with plywood. I am aware of the ply v. OSB v. drywall debates (even the fire part) and have read many of them for the pros and cons of each, so I don't want to start that debate here... my mind is made up; plywood.
Anyway, for this thread, I am looking for you guyes opinion on which plywood you would go with out of two choices. Both are the same price and reasonable (for ply). Plan on priming and painting after install.
One choice:
http://www.menards.com/main/p-1920284-c-5698.htm
1/2" for easier handling and should be decent as far as knots, splits, etc. Plan on having 1/16" caulked seams and screwing it to the walls.
Another choice:
http://www.menards.com/main/p-1920265-c-5698.htm
3/4" for more strength. Doesn't classify as to "A" "B" or "C", so I don't know surface condition until I see it (closest Menards is 50 miles away). If the surface is comparable to the other one then that doesn't come into play. Tongue and groove; so how do I handle the seams (**** it together or still gap it)? Is the T&G an advantage on a wall mounting situation?
If it were you, which would you lean towards, all things considered... thanks.
One choice:
Another choice:
