The VISES of Garage Journal
lpcjvt
I just got my vise mostly pulled apart and I have stripped most of the paint off it. I had a broken screw holding one of the jaws that I will need to replace. Does anyone know how the end cap comes off. I don't want to ruin anything while trying to remove it. Maybe I should just leave it on paint it and assemble it. Any advice would be welcomed.
KMScott
Round the ends of a wooden dowel that fits in your threaded nut and tap it out with a mallet. Does not take much to drive it out. If you use a square end punch then you will dent the inside of the end cap. The screw is a 1/4:20 and that uses a #7 drill as the tap drill, I would use a 3/16 drill and see if it loosens. Nice vise. Good luck and welcome to GJ.
lpcjvt
Thank you for the info. I did get the screw out now to find a similar replacement for it. Looks like the year on this one is stamped 6-71 do you happen know what color that would have been? The light blue or Verde Green?
KMScott
I do not know the correct color, not much of a Wilton history buff. Both choices are what everyone uses. Shucks, paint it what color you like or maybe someone will mention the correct color for your year.
lpcjvt
I'll probably end up with the light blue the green doesn't seem to be stocked at my local hardware store. This will get quite a bit of use and I think just about any color will beat the messy yellow and white combo it was.
Thanks again for the help.
zoomieport
The Mall City
You can order Rustoleum Verde Green from Home Depot, pretty reasonably...
Take Care!
Mike
va.grouseman
Southern-Central VA.
Previously posted by Drivesitfar.
VA: I can't say I've seen you post this Velox vise in the past, but you might have. does that screw on the side adjust the height of the dynamic jaw so that you can get it to line up or is that a problem with that particular vise?
I posted that thing back on page 479, post 9564.---Had that thing 4 years.---It works like the Dodge Slide Set, or similar to it.---Read PchJKB's info on it.---Danged if he can't get the skinny on any vise made.---That's an asset to us all.
sld961
, I believe Maui is right about the buggered up slide on the Columbian, but you are in luck, Columbian used a tough malleable steel in their vises which bends before it will crack.---Which means like Kwoswalt99 said, most of that can be pounded back in shape.---If you get it, reshape as much as possible before you grind anything.---Columbians are good vises, they just don't get the respect that some others do.
Bcom
Nebraska
Hi, can anyone give me some info on this vise? I can't make out the model number. How big is it, how much does it weigh, how much is it worth (central PA)?
I'm looking for a general purpose vise to use, not a collector's vise.
I have a ridgid that looks almost identical to that. My ridgid has 506 stamped on the side and is 101Lbs.
sld961
Sld961, it looks like a Columbian 604. And it appears that somebody dropped it on its tail at some point and damaged the top end of the slide at the rear. I would inspect this area closely for cracks.
This would serve as a good general purpose vise if it is in good working condition.
Maui
With the slide damaged like that it will not be easily removed from the vise body without some whittlin'.
JKB
That Columbian would make a good general use vise, if it hasn't got a crack.
Judging from the leaves and boot in the picture its pretty small, maybe 3" jaw width.
You can hammer that back into shape.
Thanks guys. He's asking too much for me, especially with the apparent damage. Oh well, maybe next time.
GETRIDAONE
Auburn, GA
I have been to the Madison, GA tool meet for the last two years. I bought quite a few vises there. Tool trading starts at daylight ( or before ) in the parking lot. You never know what will turn up ? It is on Feb. 3rd & 4th but you have to be a member of M-WTCA
Maybe Mike will bring that tiny Wilton for display.
trijeff
Northern Cali
JKB ... still haven't been able to locate anything at all in print re: the Prentiss 98 if you are looking for a challenge ;) Really just looking for a company brochure or supplier catalog (not patent for the Bulldog or anything like that), would like to see the "official" specs on this thing.
drivesitfar
Meatsis: I sold my Simplex 61s to a young member and even though it was a couple of years ago my back still is sore from putting it in his trunk. well not really, but it is a beast and I know he didn't have it easy lifting it out unless he took it apart. i'm guessing in the 140 to 160 range cause it's every bit as heavy as my Morgan 160 and Rock Island 577.
ALL: speaking of Desmond Stephens, Simplex didnt they end up being Rigid? and when did the names change?
any of you with Craftsman 519x's can you post up pictures of your vises on the new 5198 thread in Vintage tools with the DATE STAMPS too?
it's looking more and more like ROCK ISLAND VISE company made the 519x's, but still looking for information. i actually have a newer wood vise in it's original box MADE IN JAPAN with 5195 on it that doesn't mean much, but just saying we are gathering FACTS and trying to solve a mystery. personally i think it was MR. PLUMB in the STUDY.
cheers
thanks
KMScott
Wrapped up a Reed 109 repair last weekend and wanted to share a few pic's. This big guy was treated a little rough.
<a href="https://visejaws.smugmug.com/Demoman/i-ChZzQFW/A"><img src="https://photos.smugmug.com/Demoman/i-ChZzQFW/0/M/Demomans%20Vises%20%2824%29-M.jpg" alt=""></a>
Chopped and welded up the jaw towers and filled the missing material with new jaws. 100 years from now someone will look at this and think Parker worked together on jaw design. Jaws are 9 inches wide and 2-1/2 inches tall.
<a href="https://visejaws.smugmug.com/Demoman/i-nQtL4sM/A"><img src="https://photos.smugmug.com/Demoman/i-nQtL4sM/0/M/Demos%20Reed%20109-1-23-17%20%281%29-M.jpg" alt=""></a>
<a href="https://visejaws.smugmug.com/Demoman/i-vKMCCDZ/A"><img src="https://photos.smugmug.com/Demoman/i-vKMCCDZ/0/M/Demos%20Reed%20109-1-23-17%20%2810%29-M.jpg" alt=""></a>
Repaired a tail split and added a new handle. 1-1/4 diameter with 2" balls and 24 inches long. It is a big one. Everything about this vise is big, shucks the nut is 5-1/2 inches long and spindle threads are 1-1/2:3 Acme.
<a href="https://visejaws.smugmug.com/Demoman/i-jJmgzpT/A"><img src="https://photos.smugmug.com/Demoman/i-jJmgzpT/0/M/Demos%20Reed%20109-1-23-17%20%285%29-M.jpg" alt=""></a>
Gotta show the jaws.
<a href="https://visejaws.smugmug.com/Demoman/i-8FBg8HC/A"><img src="https://photos.smugmug.com/Demoman/i-8FBg8HC/0/M/Demos%20Reed%20109-1-23-17%20%283%29-M.jpg" alt=""></a>
Hope the Kansas owner likes it.
trijeff
Northern Cali
Everything is AMAZING as usual, Kevin, but those triple step monster jaws are absolutely incredible!!! How many total hours went into the complete rehab??
VISEs
Dolex. Here is a vise that I had shipped over from France with a couple anvils. It's pretty well built. Nothing crazy. Just a nice, different, design.
Say shouldn't every vise be able to clamp down on a 3" x 12" bridge timber!!?!?
Bcom
Nebraska
Vises---- before i even read ur details on this vise,you could tell that the vise appeared very foreign. Still very cool. So those screws on top, are they just to keeo the slide tight or something?
VISEs
Correct. They are brass screws.
