Clausing 5400 Lathe Restoration
C
Cahark
Dayton,Oh
Worked on the lathe tonight. Spent a good 3 hours after work.
First, I continued to clean the spindle and headstock components. Someone decided it would be a good idea to tighten down set screws on the shaft without the included brass plugs. I was able to stone off all of the bad parts and ended up with a nice piece. I will do a final cleaning before assembly.
Next up was removing the name plates. At first I tried to slot the rivet screws with a cutoff and twist them out with a screwdriver. I didn't have much luck with that. Next I used a cold chisel to pry the head of the rivett up. Then I was able to get under the head with a set of small dykes. It really worked well.
e8fb4ce153cf25ebd95f3f3b183de2c3.jpg7b23d86e5ae44f68ba1d74d2e23dcc41.jpgf3a477d70ccb1860ddd740e8fd305719.jpg
After I had them out, I opened up the existing holes with a number 43 drill, and tapped the holes with a 4-40 tap. I would love to have brand new rivets to install, but I didn't want to have to buy a bag of them for just a few tags. I have plenty of 4-40 screws in stock.
I also got a chance to strip the old paint off of the headstock.
Lastly I was able to remove the bed from the cabinet. There I found where all of the mice in my shop were living.
If all goes well I may be able to paint the rest of the machine this weekend.
C
Cahark
Dayton,Oh
Love the write up. I have a 6300 and love it! Clausing 'used to' make some good lathes
This lathe never cut "right" before I went through it. (Im starting to find some of the reasons why. I'm really hoping for an excellent machine after all of this. It's hard to come home from running top notch equipment at work to machines that don't function as they should at the house Haha.
C
Cahark
Dayton,Oh
Got home from work around 4:30. Kicked **** until around 10:30-11.
First, I started to remove the under drive unit. My goal was to remove it as a complete unit, but I did have to remove a few linkages and parts.
97a7fd50b298890c8d771b24be535e98.jpg2219541b828696bb6461cfc5e39e711d.jpg07ee158f7e3354c9731969dbbe7ff083.jpg
My plan is to work on the under drive while the paint on the main cabinet cures over the next week or so.
A friend of mine offered his help to start wire and flap wheeling the cabinet. After about 3 hours, we were able to strip off most of the paint from the bed and the cabinet.
eacdeb4956c8b85a73d9731c09b98d99.jpg6a068738f0dcf41dd3660d2da744b0b8.jpg58fb7bfbd133fe655aace79e7055cade.jpg
The goal for tomarow is to set up a temporary paint area, clean up the prepped metal, tape off the areas needed and spray the rest of the machine. That will allow me to start to clean the underdrive and assemble the sub assemblies through the week.
C
Cahark
Dayton,Oh
Great project!
Thanks. It's been a busy one! I'll be glad to have a break for a week or two when this ones done. Taping off at the momente53f1e908b590036806bc2aac6138771.jpg
cgrutt
Coming out great man, one more question, how are you managing moving the heavy parts? Do you have a helper or are you doing this on your own? I took another look at my machine yesterday and had second thoughts about dismantling it on my own, LOL...
C
Cahark
Dayton,Oh
A few years ago I made some leveling feet/risers for the Lathe. They allowed me for one to level the machine on my uneven floor, and also to get it just high enough that I can put my pallet jack underneath the machine to move it as one piece. As far as moving the machine when it's dismantled, I have been able to move each piece on my own including the bed. It's definitely great to have a helper around though. It's funny that you ask that, I was thinking to myself today that if I ever moved into a different home and moved my machine shop to the basement, I would have no problem dismantling the lathe and moving it with a helper down a set of stairs. But to answer your question, as long as you are able bodied, you should be able to move everything by yourself. But I would recommend a helper.
MBfreak
MEMBER EMERITUS
Linkoping , Sweden
Really great job and good write up.
Thanks a lot, always comforting to see that there are others out there like me who can spend 3 months restoring an old tool!!
And end up with a good lathe, far better than the poor quality machines sold today that can do at least drilling, milling and turning but all at a horrible quality.
Keep it up.
Attach a pic of my affliction. 3 ton soviet era lathe , wonderful quality.
Ola
C
Cahark
Dayton,Oh
Great work on the lathe, I keep telling myself I want to pick up a lathe some day, not sure I'd want to restore it though.
I was on the fence about going through mine for a few years. The llathe wasn't giving me the results that I was expecting. At that point I felt that there was significant work that needed to be done on the machine to fix the problems that I had. I figured if I was going to get that far into it I might as well put on a coat of paint haha.
cgrutt
Thanks, my machine is also on a caster platform that allows me to move it within garage. I don't think I'd be able to remove bed even with a helper without some sort of come-a-long or engine hoist. I think my machine is a little bit bigger than yours though. Thanks and good luck with restoration, it's coming out great!
C
Cahark
Dayton,Oh
I totally recognize the need for portability. My small garage dictates that almost everything must be on casters. I try to leave my lathe rigidly mounted to the floor as much as possible. It needs to be precision leveled and aligned to achieve accuracy and rigidity. But Sometimes you just have to move the darn thing lol
C
Cahark
Dayton,Oh
Making lots of progress tonight. My friend stoped by again to help me get everything prepped. After about five hours of work I was ready for paint. This is where we are at now87c2c6b3666a4e1694955bc595ffab43.jpg2fa9d1353ca7f0db2967d8c497e6f576.jpg3c6ccab4af94ea951cd14e068a778e54.jpg
C
Cahark
Dayton,Oh
Keep it up.
Ola
That looks like a nice machine. It's 5 times heavier than mine ha ha. I get spoiled running heavy duty lathes at work. Someday I am hoping to have a barn big enough to have a big old Monarch.
You are correct about the quality of old steel. I love old machines!
cgrutt
This is the way I bought it. Haven't used it yet, LOL... Agree it has to come off casters...
cgrutt
So, was that the way it was sprayed or lowered just for the picture, because, well... it's awesome :)
C
Cahark
Dayton,Oh
Drying, assembly, and a bit of repair is all that's left
C
Cahark
Dayton,Oh
I'm sorry, I don't follow. Lower?
cgrutt
No, just looks like the plastic was lowered on the flag for pic, which, I think is Awesome, whether it was or wasn't. Love the pic. No worries...
C
Cahark
Dayton,Oh
Oh I see! Sorry, no it was by accident. I do however try to keep the flag clear at all times.
C
Cahark
Dayton,Oh
After two solid days really kicking some **** out in the garage I decided to take yesterday off to spend time with family and friends, and even go to an auction. The auction was the estate of a JVS machining instructor. He had a little bit of everything. Seems like most of his time went into building garden scale trains. He had an index mill, a Bridgeport mill, a small South Bend 9 inch lathe, a large 12 inch unnamed lathe, and a Hammond surface grinder. It seems like he really did some nice work.
I was lucky enough to purchase a drill press vice that he owned. It looks to be a palmgren. I'm sure I will find the exact model when I take it apart and get it cleaned up.
He had a lot of other nice items that I tried to bid on, but they ended up going higher than I really wanted. Probably a good thing anyways, truly I have most of what I need already. I just hate to see a good deal walk by.
More work in the garage tonight, my wife picked up some bearings for me on her way home from work.
C
Cahark
Dayton,Oh
Things are going well in the garage. Slow but sure this evening.
Today's task was to tackle the play in the saddle. As I showed in an earlier post, the saddle had a decent amount of wear due to the bed being hardened, and the saddle being soft cast iron. Not to mention 50 years of use didn't help things much either. When I checked everything out in a dry fit, there didn't seem to be any rocking or the saddle so I decided to work with what I had.
I started off with .012" vertical play in the tight areas and .016 in the loose areas. The difference shows roughly .004" wear in the bed between the head and tailstock.
After I figured out how much slack there was, I installed the gib without the .011 shim.
This brought my slack to .003-.006 roughly.
edf33f051b44062131b54a9ac11dec0c.jpg0ec3cc9303685dde60802aea5811a546.jpg865a169e0fb97fecb92ff56d09357900.jpg
After getting this info, I went to the mill. I lined everything up and milled both surfaces of the gib. I also milled an extra .011 off the mounting surface on a .002 taper to account for wear. so I could re install the existing shim and allow for more adjustment in the future.
Afterwards, I reinstalled everything and checked my progress. I was able to bring everything back pretty close. .0012ish in the front, and roughly .004 in the middle.
I know it's not the best practice, but I will use the carriage lock to snugg everything up in the worn areas. Gotta do what you gotta do on old equipment.
Things are looking better already.
C
Cahark
Dayton,Oh
Looking great!
Do you have a model/color # on that rust-oleum industrial enamel and clear you used? I'd like to use that for some equipment now after seeing how well it came out of a can for you, especially in winter!
https://www.amazon.com/dp/B003UNEE7E/?tag=atomicindus08-20
This? (Says high performance not indstural so not sure)
This is what I use. 4.99 a can at menards. Dark machine gray. Afterwards I use the crystal clear enamel by rust oleum.
I do one coat primer, 2 coats color, 2 coats clear.
1 coat per hour when cold, 2 coats per hour above 65.
https://www.amazon.com/dp/B000LNQ9L0/?tag=atomicindus08-20
May not be the scientific way, but it's worked pretty well for the past year or so on my projects.
ToddW
In the snow
Thanks! Always looking for different paint to try.
For reference, your pictures you've posted is that the gloss crystal clear enamel sprayed on already or just the dark machine gray? And which primer do you use?
I got some really expensive self-etching primer that when you touched it with your nail would flake off really pissed me off, it wasn't self etching at all.
C
Cahark
Dayton,Oh
Everything with the dark gray already has the crystal clear enamel on it. The gloss looks slightly better in person. It's easy to apply, dries fast and is very smooth to the touch.
I recognize that the clear is is a bit overkill, but I like the extra layer of protection and the easy to clean surface.
When I'm cleaning the castings before paint I tend to use a flap wheel instead of a wire wheel in the areas that I want to be nice and smooth. The flap wheel usually doesn't pull out body filler or lead filler that the manufacturer may have used. Plus it smooths out rough casting marks while you are at it.
I use this primer.
I cannot attest to this for the long term, but it's worked well for a year now, and seems to harden well. They also sell it in a gallon if you wish to use an HVLP.
C
Cahark
Dayton,Oh
Came in the house for dinner, thought I'd give a little bit of an update. I started to install the bearings that hold the cross side screw to the taper attachment. You could tell that they were very worn and "clicked" when you turned the shaft.
As I gathered my things to start installing them, I remembered some tools I made to install arbor bearings on my Unisaw. It turned out to be a perfect fit for this too
After I got the bearings on, I placed everything in the carrier. The brass plug under the set screw was missing, so I took this chance to cut a new one.
It feels as good as new now. Hopefully I will have some more progress after dinner.
C
Cahark
Dayton,Oh
Got another hour and a half into it tonight. Taking it easy through the week. I was able to get the cross slide on. It's mostly adjusted, but I still need to get the taper attachment on.
I also filled the oil in the apron to make sure there were no leaks on my new gasket. Last thing I want is to have to remove it from the lathe and fix a bad gasket.
I also picked up a few thumb screws from McMaster Carr. They are a touch big, but I like the extra leverage. I also went ahead and cut some new brass plugs because again, somebody lost them within the last 50 years.
Tomorrow, I have a friend stopping by to help me mount the cabinet, and the bed.
C
Cahark
Dayton,Oh
Tonight My time for the lathe was short. I started by setting up the idler pulley in the lathe and trued up the grooves that the belts wore into it. It was also slightly out of concentricity with the bearings. If I left it that way, it would cause excessive wear and vibration.
It turned out pretty well, especially after I installed the new bearings.
Next up, I had a friend stop over to help me put the cabinets together, along with the leveling feet. Once the cabinet was roughly level, I was able to install the bed.
Last, I put on the compound. Didn't take any pictures of it because I figured it was pretty straight forward.
Tomorrow I'm hoping to have the carriage fully assembled, and possibly move on to the quick change gearbox.
C
Cahark
Dayton,Oh
Yet another busy day on the Clausing lathe. I started the day off with mounting the apron on to the Saddle, and then moved on to installing the taper attachment. It truly went beautifully. With everything being cleaned and fitted properly, it went together Like a well oiled machine.
After that I proceeded to adjust the taper attachment so there was as little play as possible. I also adjusted the cross slide Gibbs. Everything is very tight, and there is only about .008" backlash in the crossfeed.
I could probably make this number even smaller if I add a Gibb and some set screws to the piece that travels along with taper attachment. I had noticed that this is the way a similar model was made via the assembly drawings. (Maybe in the future)
After that, I decided to install the lead screw and the quickchange gearbox. As I stepped back to take a couple pictures I realized that the lead screw was on a slight angle slanting down towards the tailstock end of the machine. I had remembered seeing that there was supposed to be a shim between the bed and the gearbox in the assembly drawing. When I tore down my machine there was no shim there. Go figure.... at this point, I loosened up the gearbox to drop it down so I could determine how big of a shim I needed to make the lead screw parallel with the bed. Also, to doublecheck myself I measured from the bottom of the bed to the centerline of the lead screw hole in the apron. this gave me a difference of about 1/16". Tomorrow I will cut out a few shims around that size and determine the exact fit that I need.
If all goes well I'm really hoping to turn some parts over the weekend or early next week.
C
Cahark
Dayton,Oh
Started the day making shims. The quick change gearbox needed to be lowered about 1/16" to line everything up. Now that it's where it should be, the lead screw is nice and parallel.
After I finished the quick change, I moved on to the spindle. I ended up using the same puller setup that I used to remove the spindle, to install it. Worked out great.
I made sure that everything was spotless before I finished putting it all together. I adjusted the spindle as the manual described "one full spin after a sharp spin by hand". I placed an indicator on the face of the spindle and there was essentially zero movement.
Now don't get too excited, but I decided to lay the headstock on the ways. I didn't get anything locked down yet, but i should be able to finish it up in the morning.
Done for the night. Electric and under drive Saturday.
C
Cahark
Dayton,Oh
Starting off the day picking up supplies. Number one on my list is a new set of knobs for my machine, and propane. It's going to be 17 today. 9eec9cfc2f6e4edaa6c2b2458230a063.jpg
C
Cahark
Dayton,Oh
Today is going a little bit slower than I had expected, but it looks like I will have everything finished except for the underdrive today. I went ahead and set the mesh on the banjo gears. It's much quieter now that there is no crud down in the grooves of the gears. They glide along just like they should. I also made sure to actually tighten down the headstock this time. In case you missed it, the previous owner missed that important detail.
sanddan
Oregon
Just found this build, excellent work done so far. Looking forward to the rest of the updates.
Like the hammer in the last pic.
C
Cahark
Dayton,Oh
Thanks a lot. It's a lixie. I pretty sure nearly every machinist in the USA has a couple different sizes of them in their roll around. They are my favorite.
