Above 1200 Sq/FT The Warthog Hidey Hole
J
jbmatth
Northern Ok.
Andy,
I'm sure you will step it up soon enough, I'm sure you can string up some LED rope lights or something. Maybe even install an outlet so you can plug in the drop light below the lift.
JB
J
jbmatth
Northern Ok.
Thanks for jumping back in bonecrrusher, I truly do appreciate the kind comments, that is the reason I keep posting, it also give me encouragement to keep at things. I seem to go in spurts, I'll fly through 2-3 projects in a day or two, then will spend a month or two on the next one. Or in the case of Herb's Hearse a year and 3 months. Speaking of Herb's Hearse I've got some progress to report on as well as a horse trailer I'll try to get uploaded today.
JB
J
jbmatth
Northern Ok.
The other day I was talking to my good friend Alex when he asked me if I would take a look at his horse trailer. I said of course, I knew it needed some work but was in workable condition as is but had gotten worse when and unruly horse decided it would rather be out than in. His wife was headed back from Kansas and dropped it off. Turns out the part that was broken was cast and I don't have the equipment to fix it. However, I asked if they would like me to take care of some of the rust on the front and fix the lights, none work working.
Wow that got bad fast. The previous owner decided to use bondo to "fix" the rust:
I used some more of the stove cover that was included with the stove Andy (OidIronFarmer) had gotten me, and made 1,000's of tack welds:
It had similar problems on the sides:
And repaired:
Just to let everyone know I didn't cut out the metal underneath and know this won't be a permanent repair and the owners know this and are fine with it, they just didn't want the roof to blow off while hauling it on the interstate. I then rewired the lights and it is ready to be picked up, good news is that I was waiting on parts for Herb's Hearse so I didn't actually loose any time on that. I was waiting on this black rubber insulation tape to cover the tank straps and top of the gas tank:
View media item 67745
It worked really well even if it wasn't all that sticky even after being inside the house for 24 hours. Nonetheless I was now able to install the tank and finish the last of the fuel lines:
View media item 67746
Done and dusted. I'm now waiting on some hose for the filler neck. I forgot to mention I also replaced a section of the wire for the tank level sending unit as the insulation was shot. I'm glad I did that before installing the tank. :)
Up next will be setting the timing and installing the filler neck for the last time hopefully.
JB
BUGTHUG
Kansas
you have the rubber seal that goes between the fill neck and the body (fender). I'm pretty sure I put that in the box?
That trailer patch looks good.
Are you going to the Sunflower swap meet this weekend? I have a stress test on Friday, not sure how I will feel after that. The Dr's office is close to the swap meet. I'll def try and go on Saturday. You get the best stuff if you are there first on Fri, but sometimes you get the best deals on Sat, if they don't want to load it up and take it back home with them. I hope we can meet up and wonder around and look at stuff.
J
jbmatth
Northern Ok.
Herb,
Yes I do have the seal and it is installed, I thought I mentioned that earlier, but may have mis-remembered. :) I don't know if I'll make it or not, Friday is open, and I hadn't planned on taking it off but I may just have to. Saturday doesn't look too promising though. I'll let you know if I end up going.
JB
shortykorte
Tallahassee, Fl
Do you have a spare lift light/outlet taking up space in the shop. Great idea.
When I click on video I get a picture of a yellow jack. Help please?
J
jbmatth
Northern Ok.
Shorty,
Thanks, I'm happy it all worked out how I planned it last June. That has never happened to me before, usually things don't work out so well. LOL
Try this link, I fixed it in the original post as well, not sure what happened there before:
RTP 10 Lift W/ In Floor Lights
JB
J
jbmatth
Northern Ok.
Thanks Joe, I did it all with my phone and actually was pretty easy. Maybe one day I will actually learn video making and editing.
JB
J
jbmatth
Northern Ok.
Nothing too exciting going on just yet, I have been doing some fine tuning on Herb's Hearse. I'm still waiting on one more elbow to finalize the fuel system. I love being able to shop online but waiting on a slow boat from china gets old at times. It is scheduled to arrive today however.
I have also been working on the ignition system as well. When Herb and I tried to start it a week or so ago the distributor spun about 180°. :( I never messed with that part so you can't blame me. I found this instruction manual online for his engine and it came in handy. Points gapped to .016", plugs gapped to .040", and timing set as best I could for the time being. I may have to advance the timing a little but won't know until we try to start it again.
Next up is bleeding the brakes and adjusting them. Then as long as it fires and runs I'll hand it back over to Herb.:beer::pimpflash:thumbup:
JB
J
jbmatth
Northern Ok.
Andy,
The hinge support on the back door was the cast piece, it is welded to a 1.5" square tube, the square tube is what is actually broken. Their farrier's boyfriend is a professional welder and he said he could do that part, for pay... So to save them money I took care of the rest.
All,
Sadly no work recently, work has tossed a wrench in things. Yeah for 14 hour days again, if all goes well I'll be able to watch the Super Bowl but who knows.
JB
J
jbmatth
Northern Ok.
All,
It has been a very rough week with work and LOTS of extra hours. I was able to finish the install of the filler neck on Herb's Hearse. However, I didn't have enough hose clamps big enough so I need to source more of those today. On another note I just made a rather large investment, but what could it be? You'll just have to wait around to find out, I'll keep you guessing until I can get some good daylight pictures.
JB
jabin
SW Ohio
All,
JB
New roof???
J
jbmatth
Northern Ok.
Taumac,
I thought about that, if I could debut Herb's Hearse by having him start it up in the dark, then transition into some classical music that hits the end of the crescendo just as the lights turn on. By the way thanks for subscribing my channel, you are the first! I've had my account for 8 years now and posted 4 videos, so in 8 more years I'll have 8 videos and 2 subscribers. That is when the big time internet money starts rolling in. LOL
JB
BUGTHUG
Kansas
Music for my hearse would probably have to be some erieee opera :eek:
I'm thinking you invested in a big welder/generator, to do fences with and other odd jobs:dunno:
I found my new shop manual for the hearse, its even got pictures:thumbup::thumbup::thumbup: you need it?
I can't remember if I drained the oil, and didn't refill it? you might want to check BEFORE it gets running.:scared:
Went to part of the swap meet, made myself go. Just didn't feel all that good after the stress test on Thursday. The only thing I bought was a Mopar, Direct Connection plate, and the frame on it says something HEMI on it.:D
OK let me know if you need that manual.
J
jbmatth
Northern Ok.
Herb,
Good choice on the music, the only thing is I technically can't do anything copy written for the music. Nope not a big welder/generator, although that is on my wish list.
It wouldn't mind having the manual, I think I have everything ready to give it a shot at starting again, I even put oil in it a couple of months ago. :thumbup:
I didn't get to make it to the Sunflower Swap Meet, I wanted to take the whole day off but ended up having to work from 4 something AM to almost 7 PM. I slept pretty good that night, but then had to return on Saturday for some more free overtime and worked until 6 PM. :wtf:
Hopefully the stress test didn't stress you out too much! If all goes well I'll try to take all of Friday off if you want to come out and try to start it up with me.
JB
J
jbmatth
Northern Ok.
Call, text, or PM me on Thursday later in the day, this week isn't shaping up to be any better than last. I need some QST and to stop having to work 14 hours a day just to keep my head above water.
JB
J
jbmatth
Northern Ok.
I hear ya! all work and no QST makes JB a dull wornout mate!
I completely agree, I haven't had enough time for fun in too long. I did get a few minutes this morning to clean off my bench at least and that made me feel better about myself. :)
Okay so my too big of purchase, I didn't plan this and didn't expect to pay what I did but in a good way. In the end I think it'll help out.
Before:
So the story goes like this:
On Super Bowl Sunday I has relaxing for a few minutes when someone honked outside. The gentleman in the truck asked if I'd considered sealing the roof on my shed. Well of course, but I haven't thought I could spare the money at this point in time. He said he could coat the entire outside with a tar based paint for 18! :scared:
I politely declined and said I had more work to do hammering in nails and installing screws before I could justify the cost, as well as seal up some holes. He then haggled a bit and said he would screw every sheet down as I'd done on the other side of the roof and patch the holes as well as spray everything for a much more reasonable price. I accepted and came home Sunday night to this:
After:
Some photos sent to me, they are poor quality, but might as well post them:
So now just to wait until the next rain storm to see how it holds up, time will tell. I'm pretty excited to have this much more under control for the time being.
JB
mefast
Southwestern, Ontario
JB,
That looks awesome! I may not have posted too many comments lately, but have still been reading along. Great job with the hoist and lights too!
J
jbmatth
Northern Ok.
Thanks Andy, Sadly the dust will still be pretty bad because of the gaps at all of the door and if we ever get a gully washer water will still run in from the door openings but we don't get those tooooo often. That can be cured with some grading and drainage work eventually. Now if I could just get some free time from work...
JB
J
jbmatth
Northern Ok.
JB,
Thanks Mefast, it is nice to see a shiny building, but I didn't know how many dents were in the metal until now. :shocking: The lift and lights work great and is very nice to have.
JB
rmalkow2
Brighton, MI
Sometimes you find the deal and sometimes it finds you. It looks great and hope it helps to manage the leak issue you had before.
jabin
SW Ohio
!!!!! That's pretty nice, Congrats!!! I'm sure dealing with a leaky shop has hung on your mind.
I wonder how much cooler it may be in the summer??
J
jbmatth
Northern Ok.
wow, the hidey hole looks totally different. nice color combo also. sure hope it holds up well.:thumbup:
jim
Jim,
Thank you, and I sure hope so too, it came with a 5 year warranty but who knows how much the warranty is worth anymore anyway. We will see how much cooler it is, I never really thought about that with it being winter and all.
Jabin,
It has been haunting me ever since the first time I noticed it and it started to wreck everything in the shop. Hopefully it'll help quite a bit but time will tell.
rmalkow2,
I do as well and if not at least it is shiny. :pimpflash I'll take it when deals fall in my lap, but who is to say who got the better deal on this one just yet.
Looks great JB.
Thank you John, I'll need my shades before going out there in the summer.
JB
-Brent-
Utah
There's not much "hidey" anymore, that thing is bright! I can't wait to see some better pics.
OutlawDrifter
KS
We painted the roof of my father-in-law's building with similar stuff. Worked out pretty good for sealing it up. Went on brown and dried silver.
J
jbmatth
Northern Ok.
Brent,
I'll see what I can do for better pictures, sadly I leave when it is dark and get home at nearly dark as well. Perhaps this weekend.
JB, done well.:thumbup:
Thank you 1/2, now it is time to wait and see how it holds up.
Outlaw,
If I have similar results I'll take it!
All,
I'm still slacking but should get some free time this weekend to get some stuff knocked out and the weather is supposed to be spectacular for it as well. I may even get some time off of work tomorrow too. I'm so close to being able to start up Herb's Hearse I can smell it.
JB
J
jbmatth
Northern Ok.
War Wagon,
Hopefully the sun will be out at some point this weekend and I can get ya'll some better photos.
JB
