Photobucket is down (again) so I figure I'll try out something new.
Here's a very small update as I haven't done much out in the shop. There's been a lot going on (aside from shop progress) from multiple snow storms and frigid weather, to each person in the house getting sick, to me and my wife taking on eating nothing but clean, "whole" foods for the month of January. Let me tell you, the first ten days or so you're in a very harsh reality due to your prior eating habits. The month is done (we're actually still doing it 80% of the time, though) and things are settled down a bit.
I snuck out to the shop for an hour or so, yesterday. The air lines are just sitting, waiting for me to finish them. I wanted to address the drop above the bench since it was in the warmer, lower level of the garage. I'll get to the attic air line drop, next.
I cut a piece of scrap to mount the drop to. This is my most beat up tool in the shop. You can see the shipping tag on it. This was part of the very small amount of tools I had shipped out here when I moved. I'm dedicated to using this until it dies. It's a tad out of square from it's very hard life but it still chops, haha.
I marked some holes from a wood template I made (AFTER I messed up my first attempt) and drilled and tapped two holes to mount the aluminum block. After that, a couple more holes were drilled to mount to the Wall Control brackets and fastened everything.
Here's a closer view where you can see the brackets in the back. To my surprise, they're solid after everything was bolted. I figured there would be some upward movement because the slot rails stuff slides up so you can remove it.
These are plastic PEX clamps. They worked perfect. Only problem is you have to buy a pretty large quantity of them.
The mess on a small bench can't get horrible like my old benches. Now I can clean up quickly and get onto a new project.
Here it is, finished. Now I'll get over to the other end and the line that drops through the ceiling set.
That's it for now...
