What did you do "TO" your garage today?
JimVonBaden
Northern Virginia
Jim,
It's already done but did you consider actually having the one wall slanted against your property line like in the picture below (green line)? Or was that not worth it or very minimal space gain?
I'm just over thinking since I always try to get the max amount of space utilized with things.
Can't wait to see progress pictures!
-Nigel
The pad is a full 20' wide, so I am considering a full width addition. It would end up less than 1' from the fence, so I have not decided. I will not angle it. Too complicated for me to build. Besides, I will put my AC there.
Thanks for the idea though.
By the way, you should come by sometime. I am having my annual tech day on the 22nd.
NewShockerGuy
Northern Virginia / DC
That's true, never thought about the angle making it harder to build but that makes sense.
I'd love to come by! Appreciate it! We are going to be out of town next week and then the follow week for LA but after that I'm free so we'll have to sync something up.
-Nigel
NewShockerGuy
Decided to add some shelves. I had added shelves years ago. Then realized that there is still dead space above the cabinets and on the one side of the wall. Ordered some more closetmaid maxload since it matches everything already and installed it last week. Also changed the single outlet on the wall to a double so that way I don't have to keep unplugging the car when I need to use the outlet. Worked out quite well.
Before/after pictures of shelves. Only crappy part is since the shelves are further in the garage if I NEED to get to something I have to pull a car out depending on how close I park to the wall.. not a big deal because most of the stuff that will be there are things that aren't touched that often. I just want to get as much stuff off the floor and out of areas.
-Nigel
kenewagner
Installed this 18,000 BTU window AC. Got it free from a friend converting his house to central air conditioning. Barely fit in the opening. I made up some alum side panels and bottom panel to give it a clean look. Should make July a good month to work on the car
Ken
Free Willie
Connecticut
Tested the elevator/motorcycle lift table today! Everything works as it should.:rocker: More posted on my shop thread.
gfmucci
I painted Woodlife on the lower several feet of T1-11 and sill plate to reduce chance of rotting.
Sawdustmaker
Placentia, Orange Co., California
Got to Costco and picked up a pair of LED tubes to replace the fluorescent tubes in one of my fixtures. First impression is that the "cool white" LED tubes don't give as much light as the "daylight" fluorescent tubes. Time will tell. :headscrat Not in a rush to change all of them over yet.
gfmucci
I got my slab lifting company back to complete the lifting of the rear third of a cracked floor slab using jacks and polyurethane foam under pressure. It needs to come up another 1 to 2 inches. They should complete the work today by 3 pm.
gfmucci
I agree with you on "daylight" being brighter to the eye. 5000 K appears brighter than the more typical 3500 K, whether LED or fluorescent.
Crazyjake8493
Upstate NY
Brought the old couch from the house out to the garage, put away the snowblower and cab, and stared at the wall for a half hour deciding whether to mount the bigger tv directly on the wall or on a shelf.
padroo
Chesterton, In.
The grass is really growing so I had my wife pull her ZTR mower out of the corner and did the spring once over. Oil change, grease, a new drive belt and fresh blades. It will be 13 years old this year and still runs like it did when it was new. It is a 52 inch Toro with a 23 hp Kalwasaki engine.
CoogarXR
FINALLY got a new roof put on the garage. The original 1986 roof has has a leak for about 7+ years, lol. Just a small drip, in an out-of-the-way corner, but still. I have been randomly calling roofers for years, nobody ever showed up. I finally got serious and called about 10 in a row. Two actually showed up. One didn't follow directions at all, showed up when nobody was there, then mailed me an "I don't wanna do the job" price. The other guy showed up, was super nice, had a very good price, and got the job. His crew did the whole garage, plus a couple smaller jobs on the house (fixed a blown-off shingle, cleaned the gutters, and replaced some apron flashing) all in one day.
The only problem was, he was supposed to install new gutters on the garage too, but the ones he ordered ended up being 6" too short. He's supposed to come back with the correct length and finish up.
It's nice to get this stuff checked off the list. Now I can get a proper ceiling installed in the garage. Someday... LOL.
Bessy
Ontario, Canada
Well yesterday (too tired to post last night), I got up and made the quick trip over to Grandma's house to start digging.
We bought her a new utility sink to install in the garage some two years or so ago, and since it was a nice day (ok it got up to about 24 out of the sun so it was hot) so I started to dig. Dug approximately 3'6" deep, 20-24" wide and 110ish" long trench, layed down two sections of black plastic tunnel (I think it's supposed to be used in a weeping bed) and piped in some 1.5" black ABS. Lined the bottom of the hole with gravel from the section of driveway we are removing, filter cloth and back filled.
Took two garden trailer loads of dirt away from the site, down the street to the dock and filled in a sink hole. I'll probably use the rest of the gravel from the driveway to finish that job in the next week or three.
Shop sink is now functional and ready to go.9996f81bb46842cb13b43cad39be63aa.jpg0d41e33388ac6bf1e47aefec4b42d207.jpg27b7eee7c5644565eef2ab6088035dc8.jpg
Sent from my Pixel using Tapatalk
zcar751
Knoxville, TN
I finished putting up the drywall on the back wall of my garage. One more step in converting the shop from an easy-bake oven to a useable work space during the heat of the year. It will be a welcomed improvement and probably a one of the best improvements.
petee_c
KW area, Ontario CANADA
Saw the top of my workbench for the 1st time in a year or more. Just have to find spots for a few more things and then time to spring cleaning the shelves. 3a7681becae577476154a093ba67db5e.jpg
Sent from my LG-D852 using Tapatalk
Bldmovs
Nothing major, but I did add an HF 50' air hose to the arsenal. Now I need a bigger Compressor. f2f697b02ed995a3e3d1edd1dd32196e.jpg3bc784a7fc46355e2f0ad038eeac66b5.jpg
Kev442
Wi
Finished sheathing first wall.....:)
Congrats. I remember sitting down "in" my new building when it was just three framed walls, no sheathing. Could not wipe the grin off my face with a belt sander!
PhantomEB
Medicine Hat, AB, Canuckistan
Lowered and levelled out the yard between house and garage as well backfilled the side yard. Need to weld up a gate post that I can anchor the thing to the footing as well the curb wall. Only 16" wide but main access to and fro from the back lane.
Also gotta organize my tool box.
thomfr
The Netherlands
Replaced dead water well pump with new one:
old:
New:
DAB (Italy) 5m3 hr. pump on hydro tank (that one is Chinese I discovered). A lot more water now!
and finally got the ladder off the floor (storage idea from GJ):
Thom
StreetGLi
Put my ladders up so they aren't taking up valuable floorspace. 5369b9608b8c70ab1de17c8a045c4577.jpg
Sent from my LG-H812 using Tapatalk
isb cornbinder
My help and I finished a few changes in the stop, turn and brake signal circuits. I had to add a few resistors with heat-sinks. Now, all of the light work as they were intended to.
Tomorrow I want to get an early start on the final ECU programing. If all goes well, the Ford should be on the road later in the day.
SORRY, WRONG THREAD
polexican23
burbs-Illinois
Finally, finally, finally, finally......i have a driveway leading to my garage. Only took 1 year 1 month and 2 days, but who's counting. eefa96ec9281399f7bc41b413e11681a.jpg
Sent from my SAMSUNG-SM-N910A using Tapatalk
fordkid88
New threshold and new door sweep, more of band aid until the wife and I do all new doors in the spring. It looks like the previous owner had a break in some years back that busted the frame, bent the door and un caulked the original threshold(never actually mounted to the concrete) and caused rot in the frame that hopefully stopped at the frame or I'm in for more that just hanging a new door.
<a href="http://imgbox.com/mPrZv6yh" target="_blank"><img src="https://5-t.imgbox.com/mPrZv6yh.jpg" alt="image host"/></a>
<a href="http://imgbox.com/MlJ69uQH" target="_blank"><img src="https://6-t.imgbox.com/MlJ69uQH.jpg" alt="image host"/></a>
More work on some cabinets that ive been building because I'm cheap.
Added a piece of plexi glass as a cheap easy dry erase board.
<a href="http://imgbox.com/SUk5bAtA" target="_blank"><img src="https://9-t.imgbox.com/SUk5bAtA.jpg" alt="image host"/></a>
Made a little laptop stand out of a shelf that was from the beer fridge.
<a href="http://imgbox.com/yv3ezF6l" target="_blank"><img src="https://9-t.imgbox.com/yv3ezF6l.jpg" alt="image host"/></a>
Added eye bolts to keep my tanks from tipping until I can start my welding table and cart project.
<a href="http://imgbox.com/k3BVfgoA" target="_blank"><img src="https://7-t.imgbox.com/k3BVfgoA.jpg" alt="image host"/></a>
And a beer bong for my brother in laws bachelor party. His idea not mine, I'm getting to old for that ****.
<a href="http://imgbox.com/54IV8BGR" target="_blank"><img src="https://7-t.imgbox.com/54IV8BGR.jpg" alt="image host"/></a>
