this thread is funny. op buys a ****** used compressor for 50 dolllars , knows it is a ****** compressor, takes it apart to prove that it is a shittty compressor and then ******* about the fact that it is a ****** compressor.
American Pickers
That's essentially what the previous owner had you do for him.: Getting rid of a large iron machine at the dump would cost someone considering hauling and dump fees, oh bout 50 bucks .. only instead he profited by the same amount.
This thread is very funny.
Instead of anyone asking any rational questions, like why do you need multiple compressors, or what else is salvageable on that '******' compressor ASSumptions are made and nutty conclusions are drawn.
And you know what they say about ASSumptions.
The ****** $50 compressor had a like new Baldor Industrial 5hp motor, single phase, (the original Dayton must have died) a Square D NEMA size 2 mag starter with overloads. That is why I bought the compressor, not the pump. The tank even looks good.
It was a screaming deal, wish I could find more crappy deals like that.
Too bad the pump looks scrap bound.
As to my 'compulsive hoarding' that I have been diagnosed with over the interwebs
I need lots of CFMs for an outside sand blaster.So I am going to assemble 4 high quality US pumps to provide that air.
Purchase #1 was a IR, 3 stage up to 800psi compressor and tank. Really just wanted the 200 gallon, 9/16" thick tank. $50, a ****** deal. Scrapped the big oddball voltage mtr for probably $30.
Haven't tried to peddle the oddball pump, who knows?
#2 Saylor Beall 705 compressor with issues, Baldor 5hp 3 phase. $140 if I recall.
#3 Kellogg 331TV, $100 with a Dayton (not my fav brand
) 5hp single phase.#4 Champion 15B pump and Weg 3hp single phase mounted to a board, $25 a ****** deal for sure. Burnt the wood board in my shop wood stove for a few minutes of heat.
#5 Another 331TV pump only, $50. Oh that hurt!
#6 Another SB 705 pump, $35 xtra ****** deal.
I have rebuilt SB #2 for $250. Honed, rings, new hi piston/wrist pin, all the bearings etc.
I have rebuilt K/A #3 for $175. ditto, no new pistons required.
#6 needs both hi and low pistons so will have $350 or so in it. I will keep my eye out for another since pistons are $200.
#5 is torn down, only needs the basic rebuild kit and the large bearing retainer. Probably will part it out.
#4 supposedly works fine I will test run before teardown.
The plan, I will mount the 2 rebuilt SB 705s on the 200 gal tank with dual 5hp Baldor single phase motors, picked up a Baldor somewhere in the past. Probably another ****** deal.
Put the rebuilt KA on a 80 gallon tank, with the 5hp single phase Dayton (put new bearings in it $20)
Try the Champion with the WEG 3hp (new bearings in it too)
So I will have 18hp total, 3 rebuilt pumps and 1 used pump for air, that is about equal to 45hp of gas power and 50 CFM??. All for about $1500 with new belts, paint etc, plus my labor which I enjoy doing and knowing it is built right so it should be trouble free.
I can also run one 5hp 3 phase off my 7.5hp rotary convertor if I have to. Which I built, for probably 50 ****** dollars.
So it would up it to 20hp total.
When I am done in a season or 2, or 3, I will sell off the KA and the Champion and keep the SBs for a my blast cabinet.
No, there won't be any shedding of tears or angst selling them Dr Strawberry.
I imagine I will get 1/2 of my $1500 back.
Oh, and while I was out finding one ****** deal after another, I found this.
Got raped on this junker too, $175.
Champion R15B with a Baldor Industrial 7.5 3 phase, with low oil cutout, aftercooler, auto drain (off for repairs), belt guards etc...
Runs great, adjusted the belts, new oil, cleaned up and ready for sale.
Will make enough off it to pay for the bulk of my compressor stable.
So eventually I will pare down to the dual rebuilt SB 705s pumps on the monster tank that can never rust through in my lifetime, powered by the best motors you can buy, for free.
****** deal all around.
