bmxdad
For what it's worth, here is a trick you might try. As shown in the image below, with a fine grinding wheel, kiss the cutting edge so the edge is flat (parallel to drill body). You should only kiss it so the line is maybe .010 wide or less. This will give you an edge that will resist chipping and grabbing.
Also, make sure the split on the web is equal on both lands. Even factory splits can be off.
A high sulfur cutting oil makes a big difference, but anything is better than nothing.
