Smokeshow69
I sniped some plvmb off eBay which I got for less than the cost of the shipping[emoji3] I am surprised no one here bid against me! I will post some pics one I get said items! Speaking of eBay who is out bidding me on the top box like ragtopta's ? Don't worry , I am topped out in that auction!
RagTopTA
Wichita Falls , Texas
nooo you must get it!!!!!
Smokeshow69
I want to but with the missing cover and also the seller sketches me out a little bit on the shipping . Notice how the shipping says it is from Florida but the item says it is in Oakland ? I asked the seller about this via eBay messenger and tried to pin him down on a cost to me since I am in Oregon . He would not give me an Oregon rate for shipping and was avoiding the question. It just means for me that the hunt continues for the right box!
RagTopTA
That does sound sketchy. I'd prob pass as well a d find a complete box.
RagTopTA
I know your guy will come through for me or you will get tired of yours :) I also have a bunch of other people looking for me so I know one is bound to come through !
Hope so! I go back to the big monthly flea on May 6th. hope he has something good! We shall see! If I ever get rid of mine Im gonna sale you the entire collection!
RagTopTA
Plomb question of the Day: How hard is it to come by a Big Bertha? I found one thats $125 and says the gear doesnt turn correctly.. thats it. Im wondering if its worth a look or my time talking to the guy..
r_olson_06
SD
7/8" or 1" drive?
Sent from my XT1080 using Tapatalk
Smokeshow69
I saw one at the swap meet for $65 but I did not get it because I know I will never use it ! Big berthas are hard to find but most people don't want them so that limits their resale value ! If you needed it to use it I would say it is not a bad price but if you are just buying it to add to your collection I would wait for a better priced one !
r_olson_06
SD
I was always under the impression that Big Bertha's were 7/8" female drives and male sockets. When did the 1" fall under the Big Bertha's?
RagTopTA
well I went to look at the add and the post has expired... dang. it said 1" big bertha Plomb Ratchet... oh well.. in the mean time I set all my Plomb stuff out to take a MASS picture of what I have so far... I think I have a problem....
Smokeshow69
Does not look like you have a problem , just lots of answers to problems there ! Of course if you still feel like you have a problem, you can send some of them here my way ![emoji38]
RagTopTA
I'm gonna have to spread it all out to get a group pic. Theres so much underneath all that **** its unreal.. one has 14 ratchets in the bottom.. under the ziplock with the screw drivers and such... I gotta get back to messing with my big box.. this one day off every 8 ***** : (
Smokeshow69
Does this mean I am an enabler if I add to the pile ? What do you have left on the box ? Looks like it just needs paint and dent repair ?
Ole Slewfoot
Freedom, CA
That 3/4 box is a 5695 and the middle latch you have half of first seems to appear in the 1942 catalog (pg 50). My impression is mid war the army was using all the green, so after that boxes were red.
Now hurry up and paint that box. I need a paint code, and mine doesn't even have a valid color sample to work from.
I paid $40 for it with the sweet patina import socket set,
Then I drove another half hour to get the matching ratchet for $20. Sped the whole way.
No date code on pebbles, but the non pebbly grip, and more teardrop shaped head make me think this must be a first year pebble. The plate was a little warped and the screws in super bad shape. Turns out a low grade M7(?) screw deforms enough to strip itself in without disturbing the plate. With the guts clean and a dab of lube, it works perfect.
It took some fine angle grinding to remove the mushroom tip of the too long screw.
The paint from inside my box seems to be stuck to the big Chine socket. I think that purple color happens around 550F?
I do need to find a few more of the 4 ring sockets....
RagTopTA
There's a little bit of surface rust in a couple of drawers and the inside the lid there's a little paint still needs to come off. Few dents then get it sanded and ready for primer. Then find a painter!
RagTopTA
All three of my boxes had good paint samples left so should be easy to match. I'll report back when I get that far. thanks for the info on the box! I gotta find a ratchet hopefully for $20! and a Sliding T bar! oh and a couple of extensions.
Smokeshow69
Yeah that box got hot at some point! As I am sure you someone serviced your ratchet some time and put it back incorrectly. The selector should not be on the drive side . Nice pick up !
Ole Slewfoot
Freedom, CA
One of the pawls was in there upside down for a very long time too, you can see the wear pattern is a hair different, and it clicks a tiny bit different in one direction.
thinking I should open an extra can of worms and try to pull the hinge pins out of my box so I can attempt to straighten the parts separately.
Provincial
Near Salem, OR
I can think of two reasons for installing the selector upside down. First, the selector sticks up and in tight quarters could hang up on an obstruction, leading an user to flip the guts to put the selector on the socket end.
Second, the pawls could wear to the point of slipping, and flipping the gear in relation to the pawls could present a fresh wear surface.
Mintgrun
Kingston, Wa.
I found this WF Plomb speeder today for a dollar.
It matches the half inch breaker I already had.
Both of them have the odd up/down arrows.
The ratchet with a few Protos for comparison.
They are all marked 5249 and the chunkier Proto is labeled Professional.
this is a useful little bar
Tom
Mintgrun
Kingston, Wa.
Thanks.
Someone sharpened the screwdriver a bit, which led me to think it was a pry bar.
I am not sure why, but I really enjoy using tools that are not chrome plated.
Oh, I also have a pebble 3/8" breaker I will try and post a photo of. That one is chrome plated.
Smokeshow69
I feel you on the chrome tools. I actually enjoy my plvmb that is cadium plated or is just as forged finish better than my chrome tools!
notlob
norcal
I'd be on this, but I'm laid up post shoulder surgery. Maybe one of you silicon valley Plombites? The Proto WF is especially interesting; I suspect the Plomb is likely 9/32 drive. 25 simoleons.
https://sfbay.craigslist.org/sby/tls/6110362533.html
No affiliation yada yada...
:3gears:
Ole Slewfoot
Freedom, CA
I was just sending them an email, I have to go over there and get my plasma cutter back from lotos anyway. Maybe it will all work out
Smokeshow69
Here is the plvmb I sniped off eBay for $9. I had to pay $13 for the shipping. I will be selling or trading the 3/8 speeder but will be keeping the half speeder/breaker bar! I have wanted one of these for a long time[emoji41]
Notlob,
We've missed seeing you at the estate sales. The sale in Martinez netted these two WF8 ratchets and they are 9/32" drive. A few other items from the Plomb/Proto empire as well.
RagTopTA
Nice!! I was gonna get those for the breaker as well and got busy doing something else and forgot about them till it was too late! i slacked off buying much off Flea bay since I have been hitting sales and fleas so much finding stuff. I get to go back to the monthly this sat and see Florres the tool guy and get some of those delicious Amish fried pies!!
r_olson_06
SD
Plomb was a little scarce at the swap.
Here is is my findings
From top
Plomb 1234 combination 1-1/16
Plomb valve adjusting tool
Plomb 1246 pebble. Already had one but price was too good to pass up.
Dual mark 3/8 breaker bar
3/8 Wf ratchet with large logo
3/8 pebble ratchet
8 proto la crowsfeet
4 plomb 1/2 sockets
1 Firestone 3/8 socket
1 Firestone 1/2 socket
And a first for me. A Calif tool dbe.
Smokeshow69
From top
3/8 pebble ratchet
4 plomb 1/2 sockets
Wow you got some good stuff there! I really like the 1 7/16 pebble, I need to find one of those. Let me know if you are interested in moving that one on!
Cf mtn
went over to a guys house advertising an edger. found out he was going to have a g-sale. checked out some of his tools and got some plomb. the breaker bar might be something unique? everything is marked. the power trim, although nice was over priced. anybody know anything on the blackhawk sockets upper right corner?
r_olson_06
SD
Do they have the little circle on the drive side. If so they are the loc on sockets.
Rileysan
Milwaukie, Oregon
:3gears:
I've been waiting for a suitable explanation on the Proto WF ratchet. I've only been collecting for a short time but was under the impression that the Proto name was created post war. This one seems rare, imo.
Brian
