Thanks ! me too !
And if you compare a 1" Craftsman with a 1" Rahsol ?...
I wish I could have but the 15/16th was my largest Craftsman wrench. It was still heavier than the larger Rahsol. Is the Rahsol a good wrench?
Thanks ! me too !
Yeah, they would go together pretty well
Mine is 52, and I'm considering buying a few cantilever toolboxes and putting padlocks on themHe's not that old, but his personality and behavior is story for itself
When I told him that this is not 5€ tool, and how much it costs, he went voiceless
Probably all tools he bought in his life are worth less that this pair of cutters, and they arent that expensive
To straighten out the mood, birthday present for my brother-in-law
Well, its not made in Europe, but still far better than China![]()
its kinda expensive , do you have a good quality breaker bar ? id spend my money on a good bar first , maybe 3/4 " drive if you feel its stupidly tight
I'd take that Belzer over the Bahco, no question.
Such prestine condition!
Don't waste your money and time using that hand impact. Those are meant for engine bay work where space is limited.
At minimum, get a long 1/2" breaker bar. Better yet is a 3/4" drive breaker, but depending on your budget, a 3/4" drive T-handle with a pipe might be more economical.
afaik the Gedore/Rahsol wrenches were the same except the Rahsol wrenches had a lesser finish.I wish I could have but the 15/16th was my largest Craftsman wrench. It was still heavier than the larger Rahsol. Is the Rahsol a good wrench?
nice set !!!NOS Belzer socket set 1/4 No. 6721 NM
except....everythingNot much has changed it seems:
what a haul !!My last shopping.
^nice set!!
Nos Belzer, nice to see, wish I could find some of that here, even used is thin on the ground.
That is super nice!looks so much better than the Bahco.
nice set !!!
what a haul !!
Festool ETS 125 REQ-Plus 125mm orbital sander
My last shopping
Congrats
What are some brands known for quality/innovative/ergonomic. etc basic carpentry hand tool brands?
Hammers,squares, pry bars, measuring tools,utility knives,nail pullers etc.
Need to buy some of the basics soon. I have fascination for European/Japanese mechanic/hand tools so thought I would check here before buying the typical box store stuff here in the USA.
Thanks.
t.
pry bars from Tove for example. Hammers from Picard, utility knives from Mora, general woodworking tools: Narex.What are some brands known for quality/innovative/ergonomic. etc basic carpentry hand tool brands?
Thanks.
Thanks !Very good orbital sander Monte![]()
Thanks ! I will !Monte... that festool orbital is the icing on the cake enjoy!
Don´t worry ! I guess you can exchange your Makita with a FestoolThanks Monte, now you made me hate my Makita Sander that I just got![]()
News from Metabo:
new mixers, 3 speed drill, orbital sanders, 180mm angle grinder, 7AH LiHD batteries, multi tool etc.:
https://www.metabo.com/t3/fileadmin/metabo/de/070_aktuell/03_specials/specials-2-2017-DE_klein.pdf
"new" Metabo orbital sanders:
greetings to finland
<iframe width="640" height="360" src="https://www.youtube.com/embed/aKIA45hOLw0" frameborder="0" allowfullscreen></iframe>
I guess they´re rebadged Mirka Deros sanders made in Finland.Are these made in Germany?
Do you think Metabo new sander is re-branded Mirka?
How do you you find the Festool 125? I have the 150 ETS and it is very good. However I think they are suited to carpentry and dry paint. I used on our boat trying to remove the primer and I could stall the motor. Mind that the boat is wooden and quite wet even after days on the yard.
I believe yesSome of you guys know if Carolus made in Germany torque wrench is made by Gedore?Is the same wrench?
I need one 60-300nm
https://www.amazon.it/gp/aw/d/B007ML54OM/ref=ox_sc_saved_image_4?ie=UTF8&psc=1&smid=A11IL2PNWYJU7H
I believe yes
Sent from my SM-A510F using Tapatalk
Anyone owns the Metabo sb18ltx brushless?
Could you please confirm that in drill mode you cannot hold it from turning by your hand?
I once tried a couple of them in a fair and I could just stall them by hand. Problem is I cannot recall the setting.
Thank you
Hi pureleaf,Are you asking how to make it put out in max power mode? Hit the red button on the top/back. And yes I can make it stall out.
Nice, thank you!The horizontal handle presses on the lever in the connecting part, which does not allow to be pushed through the fixing ball in the square. This fixes the tool attached to the square and does not allow it to be disconnected. In a horizontal handle, only in one place (with an edge) there is a notch, if it coincides with the lever of the connecting part, the pressure on the lever stops and the fixing ball can be recessed in a square, in this position the attached parts can be removed from the square.
LosvreAnyone owns the Metabo sb18ltx brushless?
Thank you
Losvre
I own the new metabo sb18ltx bl q i.
In drilling mode at speed 1 it has 120nm torque,at speed 2 it has 60nm.
I tried to stop it at speed 1(120nm) but had no chance!!!!Maybe i am not strong enough[emoji123]
I will try tomorrow and i will tell you.I am very happy with the metabo but either the fein or the metabo would be excellent choice!!!!!Many thanks Chrissalas!
Did you tried from stopped or whilst it was running? What about in 2nd gear? I own the old model with max 1400 rpm and I am looking to get a faster one.
It is not about being strong but rather a feature to "protect" the drill.
I am between the Metabo and the Fein but I am on Metabo batteries already and there is the Metabo LTX-3 now.
Monte, does your Fein has any "protection" like this?
Thanks guys
ALL: thanks for showing us what we are all missing in the USA cause a lot of these we might not ever see or be able to buy without a truck load of cash.
i picked these up a while back that i'm not exactly sure what they are, but they are in great shape and MADE IN GERMANY so thought if MONTE didn't know maybe one of you might. i'm pretty sure these are holders, but not exactly sure what they are meant to hold. Any ideas and are they vintage cause they appear to be almost new condition?
i've picked up quite a few tools from your side of the world over the years and most if not all have been very good quality. i love my Fein 250 quick change and own two of them, but i heard the newer ones are quieter. are they?
cheers and hope you are all having a great weekend
Very nice Dremel set
Thanks!
Back to the old love with Belzer?
Beautiful set, almost too nice to use![]()
Thanks.
