ajohno
Great job Steve. I bet you can't wait to start organising everything in your shed now.
There's inherent flaws with doing that. It allows a lot of leaves and sediment to get into the tank. Even with a leaf eater leaves do not clear themselves from the system due to the shallow angle on the mesh grille.I am just a little lost with this diverta system. Why did you not just run the water into the top of the tanks and have an overflow down pipe ?
The down pipes are 25mm and the horizontal is 50mm.Hey, just want to add a quick personal point here. If you want to use these in high frost areas as the 20mm pipes will freeze when they are full of water and can damage the pipework, so they would have to be installed under ground!! JMHO.
Yup aldi. Its great. Honestly the best thing I've ever bought there. 15 mins setup and i was printing great quality stuff.Is that the aldi printer Steve? How's it going?
Yep. Already being tested.
Rained all night. No obvious leaks
Will keep you posted.
Sent from my SM-G955F using Tapatalk
Loved the video Steve![]()
Gutter guard looks great. You'll have to post some pics of your smoked/barbeque goods.
