I use actual paint removers ... I have not heard Oven Cleaner results... so ... don't know.
I look for MethalineChloride (spelled wrong)... use in a ventilated area... two layers of gloves... don't dare have kids around...
Oven cleaners typically have methylene chloride in them.
I have yet to find any project where the 20T hydraulic press can't do and arbor press can......but there are limits to the arbor presss ........so no need to have both, even if the arbor press is free.![]()
Nope^^^^^^^^. Sodium hydroxide aka LYE. But there is other stuff in there too. Some say those other things can be nasty. Mostly lye and some variations of ethanol and butane as the propellant.
Lye will strip paint.
https://www.wired.com/2008/05/st-easyoff/
http://www.beyondtoxics.org/work/green-home-cleaning-campaign/ovencleaner/
http://www.rbnainfo.com/MSDS/US/EASY-OFF-Oven-Cleaner-Heavy-Duty-US-English.pdf
Thought I would share an accessory I made for use with my press. Occasionally mine is used to straighten out something that is bent. It really helps to have a larger working surface, so I cleaned up a 3 foot section of I-beam to use as an extended surface. Its very handy,
Tip:Best arbor press accessory? A drill chuck IMHO.
I came in this thread to see what you use an arbor press for and I still don't know. One thing I do know is some of these look nice. I guess I will youtube it.
Here's a pic of my Dake. Also snapped a pic of my drill chuck. It's magnetically held in place.
Hope this helps.
You're using it to hold a small punch, then? That's a good idea.
