Support electrical box?
polexican23
burbs-Illinois
Looking for information on how to better support single piped boxes like this? (See pic) just afraid of plugging something in one day and basically the box shoves back and away from its position.
P
polexican23
burbs-Illinois
Thats easy enough, i figured there was some fancy electrical do dad or accessory to secure them kinda like the H23 caddys used for steel framed areas.
rburke65
Canfield, Ohio
Yes....don't over think this. A 2x4" behind the box, nailed to the studs and the box screwed to the 2x4" will make it rock solid.
OzarkMan
Ozark Missouri
Needs nothing if the wall covering is cut properly. The device tabs "Ears" will keep the box from shoving in let alone the device cover plate. The box has a bracket which is what it is intended for. If you really feel the need, like others mentioned a block of wood behind the box appropriately sized to fit will make it solid from flexing until the wall is complete.
D45
NW INDIANA
Put a 2x4 under or over it or behind, or a combo of these
Then sink some screws and be done
Norcal
Not always true, if the wrong depth ring is used like a 1/2" raised ring for 1/2" drywall, and/ or sloppy box cut outs in whatever the wall is to be covered in the receptacle will not secure. As to the ring depth, use one that is 1/8 inch deeper then the wall material, for example 5/8" ring for 1/2" material and 3/4" for 5/8" material.
dscheidt
how the **** to do you fish conduit through the wall?
Half inch emt is pretty springy. First hole is drilled oversize and towards the front of the stud, rest are towards the back. No problem getting a 10' section in. I've got ten foot sections of rigid conduit in my walls (house built before emt was invented). I'm pretty sure they built the walls around the pipes.
In residential construction, most work is done through the ceiling or floor, and only vertical runs in the walls. If there's an attic or basement, it's done there, but most new construction uses trusses, which provide plenty of open space for conduit. Most commerical and multi-family residential uses metal studs, which have big holes for conduit
prostreetamx
Las Vegas
A coworker from Chicago told me that when he did houses there that they would just precut most of the 1/2" EMT into 40" pieces. They just used lots of couplers which was faster than trying to make all the holes perfect just so you could use 10 footers. Personally I have used lots of 1/2" and 3/4" EMT in wood studs on commercial jobs. The companies were too cheap to just buy extra boxes of couplers. Personally I would use a metal spreader bar behind the 4s box if you want to firm it up. I don't want to use a block where I will be putting insulation in the future. I prefer good insulation over a space taking block of wood. Spreader bars are cheap and don't have to be cut to length in most cases.
dscheidt
Is BX an option?
Only when adding to a finished space. If the walls are open (or the inspector thinks they should be), it's emt. Chicago electricians get very good at bending EMT, it's impressive to watch a good crew work.
P
polexican23
burbs-Illinois
you got a pic of what you are refering too as a spreader bar? I ran into the insulation situation last night when I was trying to fit wood blocks.
Firebrick43
West central Indiana
I am building my house and using emt(but not in chicago). Only have wood studs on the interior walls and am using 4x4 x 2-1/8 deep boxes like your mounted with 4 1-1/4" screws. As such I am baffled why you need extra support? Did they screw them on or just a pair of nails?
If mine are slightly skewed I have to lay in quite a bit of my 240 lbs to bend the brackets so the face is in plane with the studs. I am seriously putting over 150 lbs of force on them. The studs twist drastically while doing this and is so solid I can't imagine how one could think that any person short of the Incredible Hulk could insert a plug between their fore finger and thumb with enough pressure to move the box. You would break the receptacle first!
View media item 71628
75gmck25
Alexandria, VA
My house was built in 1940 and it has plaster walls with rock-lathe as a base layer. Every metal receptacle box is nailed to a 2x4 on one side, and then there is a very stiff metal spreader bar that runs over to the next stud for support. I guess they needed that much support to keep the boxes in place when they put on the plaster coats.
However, it makes it hard to replace the old small capacity metal boxes, since the metal on the nailing brackets and spreader bar is so thick. By the time I cut through them with a sawzall the vibration usually puts a bigger hole in the plaster than I really want.
Bruce
Norcal
Is BX an option?
Where are you going to buy BX (AC)? What the big box stores sell is Metal Clad, MC. Edit: The areas requiring EMT limit the use of flexible wiring methods.
P
polexican23
burbs-Illinois
It is for the single run boxes, the one you posted has 3 lines coming in. The single runs have less support (according to inspector). Basically what i have found is that they refer to stuff like this as Far Side support.
ard
Sierra Foothills... California
I feel like your inspector likes to just make **** up to make himself feel smart...
Marctrees
TX/LA border - Toledo Bend
30 posts about what is everyday handled w a common 2x4 block behind box? ? ? ?
Buying a steel box support ? ? ?
Why ?? NO benefit, actually not as sturdy as wood block and a few screws in real life.
Marc
mm08822
If Illinois is so concerned about safety, why are they still on the 2008 code? Basically 3 rev's behind!!!
Making all buildings out of masonry units would be safer than running conduit.
dscheidt
Not much in the last three code revisions about safety.
barnjunkie
TN
The city officials must be concerned about safety and well being of the citizens there, I'm sure. They will waste their time arguing about something over and above their own adoption of code while the city turns into a third world ghetto.
Illinois is bankrupt according to the news girl. I drove north to Chicago the other day and the total negligence to the roadway system was amazing. Paid $18.50 in tolls to drive on the most dilapidated roadways in America. They are not too concerned about that too much though.
2Big2Ride
d/FW, Texas - more FW than D
I used similar styled metal boxes, mud plates with MC for our shop. Boxes mounted to a wood stud with no additional support. Yes, the finished boxes have some deflection when you plug something in to the receptacle. I have a few boxes with EMT in the wall so that I could change wiring for a dedicated tool if needed - the connection to EMT makes the box firmer. Do I wish the boxes were more stable? Yes. But, weigh that with time, effort, and potentially insulation capacity and I will live with our wiggle boxes.
P
polexican23
burbs-Illinois
This is what I used and it worked fine (meaning inspector leaving me alone now). thanks for all your help, input and opinions.
toplessHO
central florida
tip for those using wood blocking.
if the box is plumb level square
put the screws in the box first
then screw the blocking to studs while holding box and support block.
