Needs nothing if the wall covering is cut properly. The device tabs "Ears" will keep the box from shoving in let alone the device cover plate. The box has a bracket which is what it is intended for. If you really feel the need, like others mentioned a block of wood behind the box appropriately sized to fit will make it solid from flexing until the wall is complete.
yeah, wood is good . BTW, why the conduit? are you not finishing the walls?
how the **** to do you fish conduit through the wall?
Those boxes with brackets welded on them are pretty tough as they are.Wow, I am glad I am not in Chicago.
Is BX an option?
A coworker from Chicago told me that when he did houses there that they would just precut most of the 1/2" EMT into 40" pieces. They just used lots of couplers which was faster than trying to make all the holes perfect just so you could use 10 footers. Personally I have used lots of 1/2" and 3/4" EMT in wood studs on commercial jobs. The companies were too cheap to just buy extra boxes of couplers. Personally I would use a metal spreader bar behind the 4s box if you want to firm it up. I don't want to use a block where I will be putting insulation in the future. I prefer good insulation over a space taking block of wood. Spreader bars are cheap and don't have to be cut to length in most cases.
Is BX an option?
I am building my house and using emt(but not in chicago). Only have wood studs on the interior walls and am using 4x4 x 2-1/8 deep boxes like your mounted with 4 1-1/4" screws. As such I am baffled why you need extra support? Did they screw them on or just a pair of nails?
If mine are slightly skewed I have to lay in quite a bit of my 240 lbs to bend the brackets so the face is in plane with the studs. I am seriously putting over 150 lbs of force on them. The studs twist drastically while doing this and is so solid I can't imagine how one could think that any person short of the Incredible Hulk could insert a plug between their fore finger and thumb with enough pressure to move the box. You would break the receptacle first!
View media item 71628
It is for the single run boxes, the one you posted has 3 lines coming in. The single runs have less support (according to inspector). Basically what i have found is that they refer to stuff like this as Far Side support.
If Illinois is so concerned about safety, why are they still on the 2008 code? Basically 3 rev's behind!!!
Making all buildings out of masonry units would be safer than running conduit.
They're pretty tough just as they are.
