Updated-Finally getting a shop! Build thread.
Well the long wait is over and now I have a short, but longer feeling wait for the build to start. Got the green light and have the funds. Start date is first week of August but may get pushed up if someone ahead of me doesn't have their site quite ready.
I just got the dirt work done and boy did I luck out on that. I had a guy give me a bid of almost 2k to level my pad(low corner was about 3' out). I came home from work the next day to find a dozer working terraces in the field next to my property. I want and talked to the operator and he said he only had a couple hours work left in the morning and could come right over and work it over for me, ended up charging $390 as his equipment was already there and he had nothing else lined up for the day! I did a little fine smoothing with my tractor and rear blade after and it looks great.
Anyway, the building I'm having put up is a 30x50x12. It will be an open building except for a small storage/ compressor room. I will have one side with my woodworking stuff and the other for auto and welding. It will be a post frame building but will be built with a concrete pier system instead of the traditional post in ground. 27ga steel with 50 year warranty, 16" overhang with gutters, a 16x10 and a 10x10 insulated overhead doors on the long side, 4 windows, double bubble under the roof, house wrap on the sides, and 4" floor for $32k, sound about right?
I will be finishing the interior myself. I'm planning on running water for a hose and sink. I will be using r19 batts in the walls and will blow in cellulose over a white metal ceiling. I plan on heating with a radiant tube, maintaining above freezing in the winter and turn it up when working. I've been getting excited so I've been picking up stuff on sale when I can. I bought 24 8' 4 bulb t8 fixtures for lighting, hoping this will be bright enough for me, arranged in 4 rows of 6 fixtures. Also picked up a 200amp square d box and some misc wiring and electrical supplies.
In stuck on what I want to finish the interior walls with. I like the idea of white metal like I'm going to use on the ceiling but don't like the difficulty of hanging stuff on the walls and having the gaps behind work benches. I do not want drywall. I'm leaning towards osb but am concerned with how well it will take paint and water damage to the bottoms if I wash something out inside the building. Any suggestions?
Here are the pad pics and I will update as progress is made.
