Looks more like a 600. I don't see any pipe jaws.
But I could be wrong.
You were correct....I edited my post.
I missed Outlaw's post until you pointed it out.I had 2 guesses, the first, like Outlaw stated, it may have broken off. My second thought was that these being among the first vises made, the jaw support could have been added on later models as an improvement.
Zoomie, I'm not sure its the same company:
- H&B
- H. B. Smith & Co.
No "&" between the H and the B...
I've been hoping to find a H.B. Smith in the wild for a while!
They were sold with and without swivel bases. 400n (non swivel) or 400s swivel. Well worth 50 bucks in my opinion.
That is an "acorn" style cast iron welding table.
man you are making me want to buy it now lol
how can i tell if it's a 400n or 400s? ill ask the seller for a pic
Breakage is possible, but highly unlikely in my opinion. The support is a cruciform pattern and cast with the body of the vise. It would have to break real clean (again, unlikely) or be cleaned up snug after breaking off ugly. I lean toward a design mod, but I'm less sure if the vises without the support are earlier or later. I can see it going both ways. I can see Parker adding it due to instability in the moving jaw. I can also see Parker deeming it unnecessary with improvements in the mechanism, or metallurgy or design of the vise itself. Plenty of other vises in the same era (on the same ad page, in fact) didn't need a support for the moving jaw/slide, right? Anyway, thanks for commenting. These are the little quandaries that keep me curious.
EDIT: Perhaps if dodge610 and gam007 post photos of the bottom of their vises it might help.
Can anyone id this Wilton C3 as to what the weight might be? The figure of 200 lbs often gets mentioned with the C3. The seller weighed this one and said it weighs 140 lbs. I have seen the newer ones and their actual weight seems to be an honest 200 lbs. This one is missing the swivel base and one pipe jaw, but that would account for less than 10? lbs. Could the seller be mistaken as to the weight or did they actually make the C3 vise over the years with a 50 pound difference in weight? Thanks.
]Can anyone tell me real quick about the Simple Green homemade dunk degreaser/paint remover tank for a vise? I want to try it. How to use the Simple Green? Full strength or diluted?
thanks jake!The recipe is simple :
One plastic bucket, tote, or container of appropriate size.
Enough undiluted Simple Green to cover the object(s).
A cover helps prevent evaporation and contamination.
Time and patience.
Depending on the paint/grease/coating, it can take a few hours or up to a week of soaking to remove the paint. Check it occasionally. Scrub the object with a nylon brush to remove any loose paint and let the SG get into the next layer.
When done, filter the SG to remove any solid waste. Then re-bottle it to reuse on the next project. With filtering, your supply should be good for years, with the occasional new supply to refresh and make up for spillage and evaporation.
The same method works for EvapoRust as well.
If you find one, make sure the Dynamic Jaw support isn't broken off. Almost al I've seen have it missing.
Credit goes to FMC1959 and Outlaw. I was actually in the doubtful camp. Still trying to imagine the circumstances and force necessary to break the sliding jaw support off, which I can only attribute to extraordinary abuse, but perhaps there is a structural weakness in the design that ordinary use would expose. Coincidentally, note that the H.B. Smith vise that zoomieport just found also has a broken off support, and autopts warns that it's very common for H.B. Smith vises. Given all of the above, I am convinced that the supports on dodge610's and your prospective Parker No. 34 were, indeed, broken off.It looks like both FMC and you were on the money regarding the breakage!
Dodge610, I'm very curious to see what the patent number is on the garter of your Parker No. 34. I can make out a few of the numbers, but none of them seem to match up with the Parker patent numbers listed on DATAMP.No markings except No.34 and a patent No.
Just curious if any one has any information on Phoenix watch makers vises. I've seen more then a few on eBay but not too many sales ads or old literature. It seems like 1in or so is the most common model. Here is a picture of a 1in jaw for reference not my picture.
Sent from my XT1585 using Tapatalk
The 956 looks to be in beautiful condition. I think the price is OK, especially if it is a keeper. A 6" Parker in that nice condition, you won't see many. Of course you could offer less, he might be very negociable.
The 60x has been for sale, maybe 5-6 months. It does not look in good shape, needs some serious work on the jaws.
Forget the 60x and go for the 956, you will be very happy, especially when you see it in person (if you haven't seen a 6" in person)
140 lbs is consistent with a 600n with no swivel. I don't see the pipe jaw divot of the c3 in your pic.eitherCan anyone id this Wilton C3 as to what the weight might be? The figure of 200 lbs often gets mentioned with the C3. The seller weighed this one and said it weighs 140 lbs. I have seen the newer ones and their actual weight seems to be an honest 200 lbs. This one is missing the swivel base and one pipe jaw, but that would account for less than 10? lbs. Could the seller be mistaken as to the weight or did they actually make the C3 vise over the years with a 50 pound difference in weight? Thanks.
Only thing that worries me a bit is those pins. They obviously are not original and I know they will give me a hard time coming out, and who knows what I'll find once they are out? If somebody could link me to a thread or something where someone takes apart/puts back together one of these it would be greatly appreciated.
Again, I have no patience.
I brush on paint stripper, wait 10 minutes, and blow the paint and grease off with my pressure washer. Bare metal in no time. Blow the bulk of the water off with my gas leaf blower, let it sit in the sun or heat it with a torch to dry it, and I'm good to go..
Works for me.
Saw an older C3 at a arcelormittal steel plant yesterday. I had no idea how huge these things really were. Most pictures I've seen make them look not so large. That's a full size coffee can for reference.
Works for me.
Rob
May be we should call you the Henry Ford of vise of world for inventing the first industrial scale vise restoration assembly line. But the down side of this title is that (should you accept the title) from now on you have to paint all your vises black.
007
Ha..I'm knocking out vises with about a one day turn around. Strip them down (paint remover, wire brush, sand paper), paint, bake in the oven for a few hours on day one. Remove from oven, sit over night, and reassemble on day two (which is actually usually within 24 hours of starting the day before).
Piece of cake!
RI 594 baking in the oven now. I love the smell of vises in the morning.
Best,
Rob
Oh, oven in the kitchen. The family loves it. Nothing scientific on the temperature. I roast them at about 185° for three or four hours. Shut the oven off and leave them in there for a few more hours, and then take them out to sit overnight.
Today I am cooking at 225°. Just messing around with different temperatures but I really don't think it makes a difference in the ranges that I am dabbling with.
I like my vises well done.
That's made by Illinois iron and bolt company. That's the second one I've seen besides the one I own. Just a very well put together vise if you ask me. The art deco styling is what makes it unique. Here is a picture of mine.just saw this vise online, auction ends about 7:30 CST tonight. Interesting looking slide:
https://www.equip-bid.com/auction/2845/item/389
That's made by Illinois iron and bolt company. That's the second one I've seen besides the one I own. Just a very well put together vise if you ask me. The art deco styling is what makes it unique. Here is a picture of mine.![]()
