DFB
Southern VT/Western Mass
The bare tool saw is $199 now
You grabbing it? :D
I like mine :thumbup:
I use the 5.0 on it and 9.0 on my waterpump :p
67King
Friendsville, TN (Knoxville area)
Air tank probably wouldn't sink to too many before the pressure drop enough not to run a gun. Plus once that happened I still need a way to fill it again :lol:
Ridgid already has one on the market takes twin batteries and they work in sequence;
And I just read today Dewalt has one now too. Havent seen that yet
Ign also ask about the max pressure
I go see if can pull up some specs and a review
In my experience, nailers consume very little air (otherwise, pancake compressors wouldn't cut it!). Yes, the pressure drop means you may have to adjust the gun. Not a big deal if you pay attention.
A 60V battery will last over 3 times as long as an 18 with the same A-hr rating. Watts is what matters. If 2 60 v 9 a-hr batteries only give 15 minutes, then I was generous with my 3-4 estimate. A pair of 5's would give you 5 minutes.
I have a 58V mower. It is great. Doesn't do my whole yard, though. Battery is pretty big. Can't imagine trying to do it on 18V, it would take 6 charge cycles to do justvthe front yard of a modest lot.
Maybe Milwaukee will prove me wrong. I hope they do. But I just don't see an M18 compressor happening
firworks
IL
Just as an FYI not necessarily for you but for others reading this:
I know that some of the 40V/60V lawn tool batteries are higher capacity but the 60V Dewalt batteries are 1/3 the listed Ah rating in 60V mode. For example, the 60V/20V 9Ah battery is only 9Ah in 20V mode. It is 3Ah in 60V mode. They just have 15 18650 cells in them and are either paralleling or seriesing them to get the two different voltage ranges.
There's the same amount of energy in a Dewalt 60V/20V 9Ah battery as in a Milwaukee 9.0.
MikeF2316
Thornhill, ON
Yes, it would be better if the advertising mumbo jumbo use watt-hours, which as you scientist types know is the unit of energy.
kctyphoon
Jersey/Staten Island
You grabbing it? :D
Already have it.. my hd also has a deal with the rocket lights.. 2000 lumen gets a free 5.0, 3000 lumen w/charger gets a free 9.0.. and they also have 9.0 starter kits for $199 with a free 2nd 9.0 battery..
kctyphoon
You mean like this one?
http://toolguyd.com/ridgid-cordless-air-compressor/
I suggested an M18 jump pack a long time ago, and some people said it would never be possible.. yet you can buy any number of small Lithium jump packs today.. Dewalt makes a cordless 20v welder for Christ sake. The power is there.. most of the dewalt 60v stuff is all marketing.. my feeling is they realized they were STILL being out sold in the 18v market, and needed to create another stellar way to compete with the Milwaukee fuel line.. enter Dewalts 4th battery platform in the 18v and up market...
ocloc24
In store with the 2 9.0's for $199?
DFB
I see that dual 9.0 w rapid charger offer over the Milwaukee deals thread earlier. I think its a pretty good deal and may have to get one.
Anybody know if this available outside of HD?
ThatSickRip
Yes.. it's in a cardboard display in the front isle by the tool section.. packaged for sale with both 9.0's inside.
Havent seen it in my 2 local stores yet, hope it pops up soon. I have a $200 off $200 coupon, and I could grab that and a Inkzall for $180 :D
deberly12
Lebanon County, PA
That's asking a lot out of a compact compressor. Duty cycles can be high, but only a few can put out like that. I wouldn't expect a cordless inflater/compressor to go from 0-60 PSI without needing at least one break from the action.
It would be heavy, expensive, and wouldn't last long on a charge. If it was only one cylinder, they'd have to go absolutely balls-out to get it to last under those conditions.
I'd buy one that can handle half that duty, and I'd pay a fair amount for it, too. Perfect for around the yard stuff when I don't feel like breaking out the Powertank.
I'm chomping at the bit for one of those chainsaws, though.
I get the point of the compressor for running nailers and things but honestly I probably wouldn't buy one. I want just an inflator (maybe a blow gun built in) around the size of a drill. I want it when a tire goes flat a 1/4 mile from the barn. I need enough air to get to the barn. Ideally it would also be light and small enough to take four-wheeling or even Mt biking. Also for when the tire pressure on the car is a little low. If I have serious work to do I will get out my compressor or a portable air tank. The inflator should be super portable! I must be capable of 80 psi as this is what load range e tires are. It doesn't have to go from empty but from 40 to 80 in a few minutes would be reasonable. It must have a locking trigger!!!! If I was designing it it would have 2 settings. High flow at 15-20 psi (blow gun and air mattress...). And low flow at 100 psi (tires). You could do this with a two stage set up. Initial turbine for the low pressure. For high pressure the low pressure is then fed into a piston compressor. Even the $5 12 volt plug ones can get up to 80 psi.
Sent from my XT1635-01 using Tapatalk
Jamie V
Atco, NJ
The Milwaukee addiction thread! 😊
Why would Milwaukee make a pancake compressor? They are a cordless tool company and although the compressor would be cordless they don't sell air tools they sell battery power tools.
The inflator is a great tool that they 100% should make and hopefully will.
We wanted a heat gun, soldering iron, underhood light & staple gun and they delivered. I just hope the inflator is in the works too.
dacan23
RI
All the web stores have the 2x9.0 with rapid for $199 if you dont want to pay sales tax.
Got my Toolup SBF stuff, 9.0 and 2x5.0 were in retail packages.
bcradio
New Mexico
I'm excited fellas. I have the mid-torque 3/8" impact coming and the 4.5" grinder. I love the big boy 1/2" because I have yet to find a bolt it can't free if the clearance is there. However, it will snap M14 bolts with no problem. That can be a problem...
I don't think this exists yet... did you pre-order?
EDIT: I could care less about an inflator, but an M18 Fuel hoverboard would be sweet.
dacan23
RI
Re: The Milwaukee addiction thread! 😊
Cuz monkey see monkey do... Milwaukee actually does make air tools, they have pneumatic .nailers
dacan23
RI
Finding it hard to resist not getting the Rocket2 kit at $499 with free 9.0 and the Radius One Key at $329 with free 9.0. Would want the Rocket kit as it comes with the bag vs bare toll $399 with free 9.0.
DerekV
Central TX
The Flexvolt 9.0s use the bigger 21700 cells. On paper, they have the same watt/hour energy density, but in practice the Flexvolt 9.0 (on identical-ish high load 18v tools) should last longer than the Milwaukee 9.0 since it won't be worked as hard to deliver the same amount of power. On a light, with steady non "peaky" power draw, the run times should be nearly equal.
Theoretically.
Ign
Butte Peak ND
Yep I don't need anymore 9.0's but tempted. Plus the $85 ea on ToolUp's July BF was better.
I just received a Rapid Charger from Redding Fasteners on ebay, $29.95 shipped. Appears to be a kit take-out but looks new.
dacan23
RI
True, but if you had a 10%+ coupon then it gets crazy cheap. I have a Acme 10% birthday coupon good till end of August, and they had the 10% nightowl few days ago.
Put your bday in your Acme acct, they sent you a onetime 10% off code for that month FYI.
jgromada
Maryland (between DC & Balt)
Wow always heard there was a lot of love out there for Milwaukee. Just recently got my first Milwaukee tool, a right angle drill that I found at a garage sale for $25. The Chuck was rusted open. Motor was fine. Removed the Chuck and after a 1 week bath in vinegar and then on blaster I got it to work perfectly. great drill!
Will post a pic if I can. Pics from phone too big
deberly12
Lebanon County, PA
Wow always heard there was a lot of love out there for Milwaukee. Just recently got my first Milwaukee too, a right angle drill that I found at a garage sale for $25. The Chuck was rusted open. Motor was fine. Removed the Chuck and after a 1 week bath in vinegar and then on blaster I got it to work perfectly. great drill!
Welcome to MA (Milwaukee Annomous). Please state your name. Remember admitting you have a problem is the first step to healing. [emoji23]
DFB
Well obviously a bulk of questions have been answered by the time I finish my day. :D
Both a framing nailer and coil roofing nailer wear the red badge. Though no small tank cordless compressor will ever run one. and best I see is that Milwaukee never did have a pneumatic finish nailer 18 or 16 that I can find.
So I really can understand this desire for tiny handheld inflator but seriously can't see Milwaukee coming thru with such an item to compete with something like Ryobi has on the market.
Has been a lot of recommendation for using a plain pressurized air tank with its sorely limited and its generally non rechargeable capacity for off site work and I am sure one these little hand held air inflator could recharge one in only gawd know when, so why not a self contained unit that does it all?
If you ever often have to lug a pancake or hot dog compressor around much or run out long hoses never mind having a circuit breaker issue or shared outlet to contend with other workers you can easily see the benefit of a lighter cordless unit, especially for a small job
Read the reviews on all the feedback...Plumbers are loving the idea of small compact cordless tank unit pressurize their system and check for leaks. Obviously if they offer one you don't have to buy one but think outside the box here.
Honestly I have had many small inflators most are total **** and either just quit or overheat and burn up :D
And maybe I'm the only one but personally for my needs around the farm and my own garage I would much rather have a tiny pressurized tank air no matter how small 1- 3gal to inflate a tire than any continuous run pressurizing unit. If only to cut down the noise :lol:
But to each their own
Oh and thks for other leads on vendors with the 9. 0 pkg deals :thumbup:
DFB
Btw my older M18 Rover lantern the 2361 took a tumble down a flight of rough stairs and landed on a concrete slab.
Even bowled over some pieces of plywood when hit and kept rolling.
And that ended up landing on top of it :lol:
But none the worse for wear :thumbup:
NBHD :D
deberly12
Lebanon County, PA
And maybe I'm the only one but personally for my needs around the farm and my own garage I would much rather have a tiny pressurized tank air no matter how small 1- 3gal to inflate a tire than any continuous run pressurizing unit. If only to cut down the noise [emoji38]
Oh and thks for other leads on vendors with the 9. 0 pkg deals [emoji106]
I have carried a 3 gallon hot dog compressor around. 3 trips from the outlet to the tire to get it pumped. I have also had to drag the 26 gallon compressor 1/4 mile from the barn when nothing else was available. If it has a tank it is heavy. I want something basically like the Ryobi but built to M18 standards. Super portable and convenient. When a compressor isn't. If I actually have to walk to whatever it is I really don't want to carry anything with a tank. As I mentioned before I would carry it when I went ATVing and such. Anything bigger that a drill and that wouldn't work. If I want alot of air I will go to the compressor.
DFB
I do know the value of small portable air inflator unit and sized for convenient storage I used to try a carry some type air inflation on touring motorcycle during long trips none were really that great and pretty glad I really never needed them.
But enough people have a need for a efficient and well made hand held inflator product for certain recreational use and maintenance chores. so honestly it could be a big consumer market
My Craftsman Industrial 6 gal pancake unit is extremely heavy and pretty large overall 18 x 22 x 12 and to move with one hand and no way would I be filling at an outlet and carrying it around any distance for sure :D
I hate lugging it flights of stairs as it is :lol:
Still at least just for me and for my applications a set up similar this new Ridgid would be very handy. Dimensions are 12 x 12 with battery packs installed 16" to the top of carry handle and ls less than 20lbs total weight RTR says 30 second no load recovery rate to peak tank pressure.
Hopefully the company will offer something in the future one option or the other or even both.
Good question then is where exactly would Milwaukee's target market be on accessories like these.
Obviously Ryobi has the homeowner handyman market locked up pretty good They even offer a cordless 18v hand held tank sprayer unit, That's another one off item I can gladly use, but I don't really anticipate one coming any time soon even though Milwaukee recently branched into OPE and hey you never know. But I do know how much lawn aficionados love to spray weeds. :p
The water pump really surprised me and I'm really lovin it again most general consumers just don't have need for one. It replaced my gas engine water pump which was easily as large and heavy as my air compressor.
Now for that OPE stuff personally I don't have any real need for the large leaf blower the small blower is all I need for my construction job cleanups or maybe drying off a washed vehicle like a motorcycle or something like that and I honestly will never need a hedge trimmer :D
Though I can easily see having a cordless line trimmer eventually/
We all got a wish list
bcradio
New Mexico
Does anybody know if they are closing out the Milwaukee nailers on the M18 line? Why would they be doing this? Are they coming out with the new lineup of nailers or discontinuing them totally?
chrisexv6
CT
I think HD might stop selling them, but it doesnt look like other dealers will stop.
The nailer section of all my Home Depot stores is pretty packed with copies of the same...damn...thing. Why sell 3 or 4 different lines of cordless nailers? And with the prices they are at, they probably arent flying off the shelves either.
DerekV
Central TX
Sounds like you're really shooting from the hips here :bounce:
