The VISES of Garage Journal
Shiftless
East Bay SFO
Back to the topic of dynamic slide supports...
After a quick check of a few vises in my collection, I noticed that my Rock Island, Reed, and Craftsman 5191 all had triangular shaped support shelves.
The Athol and the Athol/Starrett had the beefier curved shape.
Anybody else notice this difference? Does this impact the questioning of who made the oft discussed Craftsman 519x vises? :dunno:
gman007
West Michigan
Wow, really. Is this what they sell for in Michigan. I think a $100 is a fair price for that vise with no repairs.
Reverend Scott
To clarify I did state that -"$100 USD .... might be getting an OK deal" and to me OK and fair mean the same.
Now as for a "GOOD" (better than fair/ok) deal, I am going by what I have paid for several Parkers here in West Michigan (which I still feel vise wise is nowhere as good as East Michigan :)). For example I paid $50 for a fixed base 955 which probably weighs nearly twice the fixed base 804. And in my book that was a good/great deal.
So personally here in West Michigan I would consider $30-40 USD for an 804 a good deal (around $1/lb) and at around $70-80 OK/Fair deal (around $2/lb). And honestly here I would be hard pressed to pay $100 for 4" fixed based Parker (and I love Parkers).
Obviously somewhere else such as in Montreal the price ranges might be better or worst than I am used to.
Kind Regards
007
gman007
West Michigan
Anyway,I don't know if this would help the OP or you 007 but the spindle handle brake is easily fixed with a set screw, spring and a ball bearing. I had the same problem on my 974 Parker, missing the spring and pad but thanks to everyone in here, they told me how to rebuild it with minimal effort. Found a random ball bearing on my garage floor and found a random small spring in my boots bucket and it worked great!����
Bcom
Thanks for the tip, it will definitely help.
007
jonshonda
Wisconsin
Great professional looking restoration! :thumbup:
Great Job
Thanks fellas!! My ADD (A dumb a$$ disorder as I call it) really takes over for me sometimes. The only reason I ever got this vice was because my newer craftsman is garbage, we just moved into a new house, and I wanted to have something I was proud of on my new work bench.
After researching the Fuller more and comparing it to some of the nicer vices, it is clear it isn't the heirloom quality vice I am looking for. Hoping the Athol I found will fit that spot for me, then I will be done until I find a nice Wilco bullet. :thumbup:
trijeff
Northern Cali
So why isn't this Reed 109 in TX in Sandman or VISEs hands right now??
https://lubbock.craigslist.org/atq/6285115505.html
f_jimenez
Montreal, QC, Canada
f_jim
The condition does not look too bad (it even has the handle brake screw in the nose- hopefully the spring and brake pad are still inside the nose), and from one of the photos you can barley see a fuzzy glimpse of the jaw inserts which do not look too bad but like Gman said earlier you really need to see the vise up close and carefully check it out.
Now it looks like this is a Parker Model # 804 (fixed based) 4". Based on my limited knowledge, it seems the 4" Parkers with swivel base weigh around 50-60 lb (my 204 and 974 weigh around 60 lb) and obviously the fixed ones weigh less (for example my 5" Parker 955 fixed base weighs 85 lb but the 5" 975 with swivel base weighs 105 lb). For this size fixed base parker at $120 CAD (about $100 USD) depending where you live, your might be getting an OK deal (see below).
Based on past comments regarding availability and prices of vises on this tread, it seems definition of a good deal for a vise among other factors depends on
A- What is availability of old vises where you live.
By the way it is a good idea to include your location in your profile. Even though your profile does not state your location, based on the ad (it is from Laval, northern suburbs of Montreal), I am guessing you are somewhere in Quebec most likely within greater Montreal.
For reference, in my geographic location, personally I would consider $30-40 USD a GOOD deal for this vise. You have to judge what is a good deal where you live.
B- How bad do you want the vise.
If old US made vises are rare in your vicinity and you want this vise, I would go and check it out (you can always state to the seller that you will only buy it if it passes inspection).
007
It appears the jaws are there, but I'd want to see them in person. Parker jaws can be replaced, but if you're not a machinist, the cost will exceed that of buying another vise.
Thanks for the info. I'll be cheking it out on the weekend and decide what i'm gonna do about it bcause 100$ even for a Parker's is way over my budget.
I came across a Columbian Vise that i would be also checking out.
meatsis
Hudson Valley NY
FYI the parker 804 is part of the Superior line of vises. Which is a lot heavier than their eclipse series. Notice the 804 weighs 72 lbs. If I needed a vise I'd gladly pay $100 for that one.
G-ManBart
I don't know if it helps answer the question, but I've always felt the dynamic support on a Reed most closely matched those on the 519X vises. I hadn't thought about the RI support, so I'll have to look at the one I have tonight.
jakemac
New England
Not a vise, but almost as good ....
Snagged this off of fleaBay this week.
Reed copper printing plate.
I have no idea how old it is.
The engraving measures 2-3/4" x 1-3/8", with the actual logo being slightly smaller.
The seller also had a vise plate, but it was part of a lot that had other plates I wasn't interested in.
Stoked to have a bit of Reed history collecting dust in my shop. (besides the 6 Reed vises in my pile) :bounce:
FMC1959
Montreal, Canada / Upstate NY
Hi guys,
I'm new to the thread and would really appreciate any help bowdown:
I came across to a PARKER'S VISE near where i live and would like to know if 120$CAD is a fair price to pay; following is the link with pictures.
https://www.kijiji.ca/v-autres-outi...er/1297072012?enableSearchNavigationFlag=true
The only problem with the Vise is that i don't really notice the Jaws shape on the clamps; so i'm kind of shy to pulling the trigger on that one.:dunno:
Thanks in advance. :thumbup:
Check it out in person, like Meatsis stated, it is a Parker Superior model line; many debates can be had on which is the most robust and strongest vise, the Superior would definitely be in that conversation.
I live in your neck of the woods (Montreal burbs), I would say that it is not a screamin deal, but more like KMS and Meatsis stated, it is a good deal.
If all you want is a good vise, you can easily find a Record for half that price. But if you want American iron, which we don't see as often in these parts, definitely get that Parker....provided it is in good condition when you see it.
Surface rust, small nics and scratches are fine, if it has cracks, signs of welds or really deep gouges, that would be reason to pass or the guy give you a big discount. BTW, he is asking $100, but if he still has it on the weekend, chances are he might go for $90 or less. See what he says if you offer $75
rusty65
Pekin,IL
My first Hollands no 12 1/2 H 2 1/2in jaws opens 4in about 14lbs. I really like the 4 footed flat bases Hollands and several other companies were using so when I saw this one I couldn't pass it up due to the novelty.
Sh40674
Iowa
Can anyone tell me about these? Only 2 pics I got... looks like it says record on the front... valuable? Never heard of record. What's a good price to buy?
G-ManBart
Record are very high quality. You don't find them with the swivel base very often, but it's a nice plus.
lis2323
Records seem to be common out west.
I can't seem to be able to post the link, but there's a nice shape No 6 swivel Record on Kijiji BC with a asking price of $100 (CDN)
Terry
G-ManBart
Does this one look real? Any indications of a fake?
It's almost certainly real with the casting saying "Made in England" the way it does. There are many cheap copies, but they are pretty easy to spot...all I've seen have been clearly marked with another name.
mike_paxton
Was out at yard sale and asked about any old bench vises for sale.
Owner pointed out a vise on shelf, but that he planned to keep it.
Asked if could look at it and we brought it off the shelf.
The good was Prentiss Bulldog No. 92.
The bad was broken/repaired jaw, broken slide and missing swivel base handle.
However, owner got it from a passed away blacksmith shop from the man who was responsible for making the archway at the Newark Ohio Maennerchor (Mr. Luber).
Liked the history and so offered a price, that allowed for a purchase to be made.
Just quick cleanup and oil/lube, as want to keep it similar to how it would have been in Mr. Luber's blacksmith shop.
Mike
Bcom
Nebraska
Mike
Hey Mike, I was just in Newark a week ago and picked up a bullet from a gentleman that lived around the corner from the large basket building. First time I'd ever seen that bulding. A very interesting construction marvel!
Bcom
Nebraska
Is there a video available showing someone disassembleing a Reed vise with the 2 piece split nut? I don't really need a know how video but I thought it would be interesting watching someone else disassembleing a Reed vise for a change with the split nut:bounce:
mike_paxton
Bcom:
It is neat to see the Longaberger Basket, which is currently for sale.
Here is a link with pics, for those who may have an interest.
http://www.roadsideamerica.com/story/10658
Rileysan
Milwaukie, Oregon
I hit up an estate sale today and the first thing that caught my eye was a pile of about 20 or so vises. Most were chinese or open screw type, but this one jumped out at me. A Patent Pending 3.5" Reed. $40
Brian
G-ManBart
Road trip today with the Wilton/Anvil magnet. Ran over to Chitown and met Autopts while picking up a very tight C3 ($250!) and a very nice 200lb Fisher anvil! The stand to the right is for the C3 and weighs an easy 100lbs. I'm tired, but happy 😊
dutchgray
Dorset. England.
It looks in great order and is a decent vice, not as heavy as typical American designs but still gets the job done, needs a set of jaws but as Irwin Record still make them (In China) you can still buy new ones. Get it bought if it is reasonably priced.
G-ManBart
Nice score G-Man and you got face time with Nick. Sounds like a great trip.
Meeting Nick in person was the best part! The worst part was the chucklehead with the forklift bending the handle on the C3, but I straightened it on the press last night :)
G-ManBart
As some folks know, there's a thread here on Wilton vise date stamps with 30+ pages of information, data, discussion and conclusions. That finally got to the point where I think the theory is now fact. Since the question comes up a lot, I wrote a summary of what that thread turned up and posted it on my website. Feel free to give it a read and if you have additional info, or find something I missed or got wrong, send me a note....no pride in authorship, I just want to make sure the info is correct, and hopefully, not confusing!
http://mivise.com/wilton-vise-date-stamping/
Thanks to all the guys on that thread that put in a lot of effort to sort this out for the rest of us!
mgmlvks
Leavenworth, KS
. . . ... I wrote a summary of what that thread turned up and posted it on my website. Feel free to give it a read and if you have additional info, or find something I missed or got wrong, send me a note....no pride in authorship, I just want to make sure the info is correct, and hopefully, not confusing!
That is a good read!
trijeff
Northern Cali
Agreed, this is fantastic ... great work.
Follow up question due to your prolific Wilton magnet use ;) I am pretty familar with values of more recent Wiltons, but haven't had many opportunities to purchase the really old ones. Do you think the earlier ones are significantly more valuable? For instance, a 1941-42 No. 3 versus a 1980s 9300. Not sure if the latter date/model reference is correct and know values fluctuate depending on location, but you probably get the gist. Thanks in advance for any info here!!
Guapo
California
Hello all,
I'm looking for some input. I came across a Wilton 600 with stationary base for $600. The vise looks hardly used. It has some surface rust on the top side of the jaws and at the edges of the base. Handle needs a good scrubbing. No other defects noticed. The seller claims it's been in storage for a couple of years, and barely used. Sorry, I did not take pictures.
What do you fellas think something like that is worth?
454ragtop
Carver, MA
Hello all,
Worth, I dunno, maybe $400. I'm sure someone else might pay more, myself I wouldn't pay more than $250, maybe $300 if really mint. But then I don't need one, would only buy it if a real good deal.
G-ManBart
Hello all,
I've bought several fixed base 600s for $300-350 in the past. All cleaned up, stripped, primed, painted, etc they bring quite a bit more than that...$500+.
G-ManBart
I've found that people will often pay a premium for the Chicago-era vises, and even a bit more for the really early models without date stamps, but condition and size always factors into things.
I think a lot of it is who the buyer is, and what they plan to do with it. If you're going out of your way to buy a Chicago-era vise you're doing it because you think it's cool, so you're more likely to spend a little extra. if you're looking to buy the most vise for your money, you're going to look at newer vises and have a tighter budget since they're really just a tool to be used.
I've also seen some evidence that the older, larger vises (5"+) typically don't bring as much as the newer larger vises. My thought is that someone buying a 100lb+ vise is buying it to use, and the newer models are a bit bigger and stronger, so they have more appeal.
Generally speaking, given equal condition, I'd expect to get more for an early No.3 than a modern 300S.
I guess that's a long way of saying "it depends" right? :p
Rileysan
Milwaukie, Oregon
I picked up this little guy at an estate sale this morning. 2 1/4" un-marked mini vise. At $15, it was a little more than I wanted to pay but it's in such good shape, I couldn't leave it behind.
Does anyone recognize it?
Brian
