The VISES of Garage Journal
damnesia
Northern MN
I picked up this little guy at an estate sale this morning. 2 1/4" un-marked mini vise. At $15, it was a little more than I wanted to pay but it's in such good shape, I couldn't leave it behind.
Does anyone recognize it?
Brian
Pretty sure it's a Stanley Victor jersey vise. If you polish the side of the slide it should be printed there. 15$ is a good price, stout little vises and made well.
mgmlvks
Leavenworth, KS
First visit to a friends house since getting the "Vise Vice" and saw this on his workbench - can someone tell me anything about it and when it might be from?
damnesia
Northern MN
That's an odd one. Any better pictures of the lettering on the right side ( if you're facing the vise )?
rusty65
Pekin,IL
That's from the late 1940s to mid 50s. At one point Montgomery wards sold the same vise in there catalogs.
mgmlvks
Leavenworth, KS
Z3K3Y
Canada
Got around to finishing the Athol 624 1/2 i picked up a little while ago. I cant decide if i want to keep it or sell it.. these are pretty rare in my neck of the woods
va.grouseman
Southern-Central VA.
Here's my Stanley Family.
Two Sweethearts and two bench vises.
It says Stanley on the handle end but the flash obscures.
va.grouseman
Another pic of the Stanley swivel based.
And an Oak leaf that looks just like a Sweetheart.---I doubt Stanley cast their own vises so this one is probably cast by the ones that cast for Stanley.
And a couple of Boley look-alikes.---No makers mark.
AngryBeaver
Lake Milton Ohio
Didn't want the simple brake drum and pipe stand so Royce chain stand got me thinking. Didn't want To permanently mount or, so it had to be heavy enough for general use, and look cool doing it.
167lb base plate gear
78lb toothed gear.
30lb clogged gear
38lbs of chain and 37lb top plate that still needs cut. I can live with this I think.
Rileysan
Milwaukie, Oregon
Thank you for the lesson on these vises. I will clean it up tomorrow and look for the markings.
Brian
Z3K3Y
Canada
Angry Beaver, just curious as too why you mounted the vise so far back (not leaving room for the handle to fully rotate? is there a reason for that? or just to balance it out? just curious.. cheers
G-ManBart
In his parts breakdown he says the top plate still needs to be cut. I'm sure that's what you're seeing.
AngryBeaver
Lake Milton Ohio
yup... Gman got it..
I ran out of oxygen for the torches.... was determined to finish it...
Now to wire wheel it and some linseed oil to protect the raw finish...
va.grouseman
Better pic of the Stanley bench vise.---The through the bench Stanley weighs 3 1/2 lbs., the top bench weighs 2 lbs..---None of the Stanley's have crosshatch jaws, all smooth,---Did Stanley ever sell a medium to large vise that anyone has seen?
And pics of the Boley jaws.---One smooth, one crosshatched.---Both have 1 3/4'' jaws, so how do they cut serration that small,,,KMS?
Pic 1 and 2 are of the bench vise logo and smooth jaws, but the jaws are
kind of blurred.---Lousy cameraman.
Pic 3, 4, and 5 are of the serrated clamp-on fake Boley.
Pic 6 and 7 are of the stationary smooth jawed fake Boley.
KMScott
VA, I know it does not make sense but the smaller jaws are much more time consuming then the bigger jaws. Tiny cutters take more time to cut. The baby jaws I sell are not money makers. The 2" baby jaws are cut at 30 degrees and a pitch of .05 and about .015 deep. The pitch is the cut between each serrations. I use a 4' diameter 3/32 wide carbide cutter ($150 each) and made a fixture to sharpen the 45 degree angle. The pic's should say it all. The trick is to have a holder that is square and does not wobble and your sharpening fixture has to be accurate. I built the special holder so I can serrate the 2" to the 9" jaws and that is why it is so long. Not really to hard but like everything in machine work it has to be right. The two jaws are the 2" babys and the first pic is cutting the baby jaws with a different cutter then what I use now.
PacificaVette
Pacifica, CA
I picked up this Prentiss No. 52 at a garage sale. I arrived just as he was putting things out, and grabbed this one. $40 seemed like a pretty good deal.
The movement is as smooth as I have ever felt on any vise. Jaws are good shape, too. I'm thinking about how far I want to go with the clean-up. I rather like the look of bare metal with boiled linseed oil, so I may try that.
The original castellated nut on the screw is still in place, so I think I'll probably just leave that alone. I don't really see any advantage in taking it off.
G-ManBart
I took a couple of pictures recently that were kind of interesting. First up are two Wilton bullets...both 4" jaws. One is 1941-1942 production and the other is mid-1990s. Talk about a huge change in size for the same model from the same company! This is also further proof that jaw size is a terrible indicator of vise size.
Next up, an early 1970s Wilton C1 (4.5" jaws) and two Wilton C3s (6" jaws). From 70lbs to 200lbs going up just 1.5" in jaw size. That's like 40lbs per half inch of jaw width!
Cope
Houston, TX
I'd clean it and use it. They're only original once. Nice find.
Rileysan
Milwaukie, Oregon
I used deductive reasoning to guess my way into this being a saw sharpening clamp vise. Am I right? The jaws are 9 inches wide. No mfgr’s or any other marks except the MADE IN USA on the jaws. It’s finished in black enamel.
View media item 74679
View media item 74680
View media item 74681
I'm surprised no one answered yet! You are indeed, correct. That is a hand saw vise used when sharpening and setting teeth of a hand saw. I think the black finish is japaning.
Brian
gman007
West Michigan
Hi
Sometime back I believe someone posted a comment regarding how to use Simple Green (SG) to strip the paint off and clean a vise. I have not used this method before but want to try it. However I can not remember if it is best to use the SG without diluting it with water or use a 50-50 mixture or what?
Also should one clean all the grease off the vise before impressing in the solution or will SG take care of the grease too (I do not mind if the solution can not be reused)?
Finally how long typically should the vise soak in this solution?
Any advise is greatly appreciated
Thx
007
damnesia
Northern MN
Hi
Thx
007
I've soaked a lot of painted parts in full strength SG ( wasn't trying to remove paint ) and it removes some paint, but unless maybe the solution is heated, I would not consider it a paint stripper. Maybe I'm wrong and can learn something new from your questions too. In my experience the best paint stripping method ( and rust too! ) is electrolysis, it's also by far the cheapest. The vise below had 4 or 5 coats of paint, tons or rust, oil, etc. It took about 2.5 days in an electrolysis bath to strip it completely down to the bare iron. Then I like to brush some OsPho on it, then it will remain rust free until I decided to paint it.
damnesia
Northern MN
That is a nice vise. I love Prentiss vises. Thanks for sharing.
Bcom
Nebraska
Just picked up this 1969 double pin Wilton C0 today. Pretty good shape. Should clean up nicely. Had to do a few hours on price negotiation but finally got it down to a suitable price.
gman007
West Michigan
Damnesia
Thx much for advice and prompt response
007
red94chev
Northeastern MD
Picked this up off a guy on Craigslist who ended up being a GJ guy (shout-out to Chris). It's a Reed 204 1/2 and it's in amazing shape with a great restoration. He said it lived in a butcher shop it's whole life. I'm proud to give it a new home!
Sent from my Nexus 6P using Tapatalk
Thanks much for the confirmation, Brian. As for the finish, we probably mean the same thing. In my experience, the terms enameled and japanned were used synonymously in vintage tool catalogs, specifications, etc for any resin based lacquer that is baked on in layers, typically for engineers wrenches, auto wrenches, ball-pein hammer heads, clamps, hooks, lathe dogs, and other equipment.
va.grouseman
I read all that KMS, and it sounds really good, and it would all make perfect sense to me if I knew Greek.---But I'm taking your word for it.:D
mgmlvks
Leavenworth, KS
Over the last two months have ended up with two American Scale No. 40 vises. Bought the first one because partial decal remaining, decent (maybe) original green paint, had removable jaw inserts, and primarily - it was made in Kansas City, MO. I am attempting to amass industrial flotsam and jetsam from the KC area as being interesting, and to display in my office.
Second vise was in about the same condition and had the Pipe Jaws! WooHoo.
Doing basic clean-up and find the machine screws holding the inerts are loose, so drill out and remove insert. The other vise has screws that can be removed. The screws are slot head 5/16-18 with a dramatic taper.
Questions are
1. Are these a standard screw and if so - where can I get some!?
2. If obsolete and NLA - I envision chucking up a pan-head screw in the battery operated hand drill and running against the bench grinder. - Is there a better way?
Questions are
  1. Not availabe
  2. other than in a lathe, that will do it!
Not that I'm aware of, and I did give a look in MHB. On;y std Countersunk screws there. I suggest using the old ones as a guide
KMScott
Sorry, been doing this stuff to long and it is easier to do then explain it.
mgmlvks, I have a drawing of the screw in question on my work computer but if making by hand filing it does not matter what the numbers are. Happy to share the drawing if you need it.
mgmlvks
Leavenworth, KS
Thanks - certainly making by hand or on a lathe to match existing doesn't need a drawing - but always nice to know where you are going. Thread below appears to have addressed the same issue - but has the PB photo disease. However - it does mention a 30 degree angle which is what I was mostly interested in.
https://www.garagejournal.com/forum/showthread.php?t=78885
KMScott
That was what I was going to guess but remember that is a included angle. If I was cutting that on a lathe or spin grinding it on a surface grinder I would set the compound to 15 degrees. Good luck.
Shiftless
East Bay SFO
Sounds like it went on a diet.
I'm not sure of a lot of things, but I know that the eBay seller is NOT selling a Reed 408 in that listing. He says it weighs 60 pounds. My Reed 406 double swiveller with of course the smaller 6 inch jaws, weighs about 160. The Reed 408 "unicorn" should weigh in at around 300 pounds.
