bubinga
l got a reeves drive set up on my old oliver lathe, took off a single phase motor, and put a VFD service motor, and a 110 volt VFD, I totally love it.It's currently variable from 350 to 4250 RPM. I could add a VFD and overclock the motor by approx. 30% and get to over 5000 RPM. Or turn the speed wheel down to 350 and then dial down the VFD to around 10 Hz. That would get me <100 RPM.
It's also quicker and easier to turn a little potentiometer then to turn the speed wheel.
And you can also get reverse with a VFD.
It might not be worth the expense/hassle though.
I will reverse to sand sometimes,
when i'm ready to finish, crank my Reeves way down as looooooooooow as it will go, and turn the VFD to abt. 10 HZ, and brush on my finish.............
