Show us your cool, "old" drill press
Nothing. Leather was used prior to rubber belts being available and up to the job. Most of these machines are a century or more old...
tombell572
Sea Cliff, NY & Portland, OR
ndfan--probably not many advantages. Current fabric/rubber composition belts seem to grip very well and perhaps better than leather and are cheaper although i am no expert in power transmission. I'm old school, my machines are old, I work on old bikes and other stuff that people drag in and I just like it that way.
Tom B.
ndfan6464
All over
Tom B.
I feel you on the old school..I am the same way. Build old bikes and old cars with old tools...I was born in the wrong era for sure.
So what era was leather used over rubber? I am just now getting feet wet with old power tools. All my old tools are hand tools... Now that I've given up restoring bikes I've gotten into machines and I am OCD when it comes to period correct. So if I build a machine that would have used leather then that's what I'll put on it.. so far my machines are a 39 Craftsman DP and Band saw and now working on a 47 Walker Turner DP..
drivesitfar
ALL: thanks for the 411 on leather treatment using NEATFOOT.
Neatsfoot looks like it's got a couple or maybe more QUALITIES of it and here's Wikipedia's comment:
After cattle are slaughtered, the feet and lower leg bones, including the skin but not the hooves are boiled. The oil that is released is skimmed off, filtered and pressed. The first pressing is the highest grade, the second pressing produces a lower grade oil and a solid press cake or stearin product.
it looks like i can get a gallon of it for around $6.
ND: my Canedy-Otto DP is i think from the mid 1920's, but i haven't found an exact match in a catalog for it yet. here's another picture of mine and if you do a search or read more of this thread there are several bigger versions of my DP on here. there are also replacement belts made out of vinyl if leather is too expensive on your restorations.
Brent: i didn't know loosening the tension on the leather belt would improve the life of it when not in use so i'll have to see if that works to maybe get me a few more years of use. i don't use it much at all cause i have other DP's, but i sure like seeing it sitting on one of my benches and i get lots of comments on it from visiting friends and relatives.
have a happy and safe 4th all of you!!!
isb cornbinder
Thanks for the information on another flat belt supplier. I have been getting my flat belts from - http://www.hitnmiss.com/
I have several 100 plus year old drill presses. I prefer the newer rubberized fabric belts. My little Canedy-Otto drillpress has a leather drive. This leather drive needs regular tightening. I have been making my belt connections with a CLIPPER lacer. I did hand lace the leather quill drive on my WF and John Barnes. There is a good instruction video on You Tube.
CrotalusAtrox
The Great Southwest
Found another Buffalo 18 yesterday it was on CL for a bunch of money and was up there for two months I made a offer and he took it. This one has the head lift so the column is extra heavy. Should be a fun project.
Snappychip
I was going to scrap this old Milwaukee drill press, but on second thought, it's an oldie but a goodie. I haven't done any research into it, got it from an old friend long ago. The number plate seems to be worn off, I cannot find any identifier markings on it.
larry_g
oregon
I have a similar setup to that and have used a few times in lieu of a mag base DP. Clamp the base to the work and proceed. The head can be swung around so it clears the base.
lg
no neat sig line
gtabasso
Cleveland, Ohio
The company where I work has 514 drill presses in right now. Most of the are OLD. I love walking down that aisle thinking of the men who used them and what they made. If only old tools could talk.
bolensboneyard
South East
I just picked up this 20 inch Champion drill press. The back gear is half missing and the power feed has been taken off. It has two feeds which are more than adequate. It took me a few hours to oil and clean it but the old motor is gear reduction vintage. One quick pull when stepping on the foot pedal switch and she was rolling. Sixty eight rev. per minute. Weighs 1000 lbs. Hard to move around but nice to work with. I have a thread in the Garage Gallery (The Model A Ford Garage) if you want to see more pictures.
larry_g
oregon
406Rich
Elk Grove, Calif
Looking at this 1959 Delta/rockwell 14 inch bench top, owner wants $275 for it, he said he`s its been thru it all, just a little of runout in it, whats the odds of not finding bearings for it..? Think the price is good or pass....?
CrotalusAtrox
The Great Southwest
They are a good machine what is his definition of a little run-out? .00?
exmaxima1
Midwest
Too much $$$. I sold a few 50's era Delta 225's recently and never got more than $200 for them, and the last one had a middle pulley. That motor doesn't look too special either.
Just sayin'.....
406Rich
Elk Grove, Calif
Just sayin'.....
Motor is just a 1/2 hp dayton...as said nothing special, but what is the advantage of a center pulley...all new to me..?
tombell572
Looks like he's got it nicely cleaned up--if the quality of the work is as good as the picture I suppose that adds value. Runout could be bearings or a worn chuck. As you noted, correct bearings may be difficult to find. If the chuck is worn, a new Jacobs would add cost. And yes, motor's not great. $200 may be fair.
Tom B.
Lettusbee
The header at the top of the page says to introduce myself on the "introduction" forum, but I can't find that for the life of me.
So, I'll just start out with a pic of my old Drill Press.
exmaxima1
Midwest
Center pulley will reduce lowest speed to about 250-300 rpm, which is useful for drilling holes in steel. Without center pulley the lowest speed is likely around 700-800 rpm for that vintage drill press---ok for wood and non-ferrous metals, but impractical to drill large holes in ferrous metals.
406Rich
Elk Grove, Calif
Thanks, that cleared things up .
GETRIDAONE
Auburn, GA
Craftsman 100 I did for my son. It goes well with the bandsaw I gave him about 6 months ago. I am slowly getting rid of some stuff out of my basement :D
-Brent-
Utah
Still the same DP that I posted before but I finished the wood top and the pic is higher quality. I did get an intermediate pulley but I haven't used it, yet.
GETRIDAONE
Auburn, GA
That Is Nice.
Nice Too!
Thanks, it is fun for me to pass these along to be be used again.
Brent, I have a 1940's table and a floor model like yours in the pile to be worked on. One is missing the pulley guard and both the top spindle cover. That is an interesting motor arrangement you have on there.
-Brent-
Utah
The motor is in the stock location. I copied the How to Bore the Big Ones article (linked) so what you're seeing is the reducer pulley and mandrel, set-up. I pretty much drill everything slow, now. It's an awesome upgrade.
paulm12
NW Chicago 'burbs
New to drill press work. I want to remove the Jacobs chuck from this Shopmaster drill press, it is a bit gunked up. Do I just force it with wedges? or is it threaded? The info I have seen says it is a press fit. Thanks.
Craptain
Tampa Bay FL
It appears that the chuck is removed by using the knurled ring above the chuck. Screwing the ring down should push the chuck off the taper. You will have to lock the quill. This system is very similar to Craftsman.
Having said that, I have never seen a Shopmaster in real life so just basing on the pictures.
Sent from my SM-G900T using Tapatalk
Craptain
Tampa Bay FL
I will try using the knurled ring first. Gotta figure best way to lock the quill. Thanks
There should be a lock. Usually on left side a few inches up from the bottom. On my dp it is the crank/screw bottom front of head casting, just above the chuck. 68bcfa9788fe05fdfe4c708cd03e1490.jpg
Davefr
OR
I found this old CM DP at a barn sale. It came with this oddball fence and a box full of shaper bits/chucks/etc. The box color matches what's left of the DP color so maybe it was a shaper accessory kit but I'm not sure.
It's dirty but 100% complete with no damage or missing parts. The motor runs good and the CM badges look perfect.
I have no need for another DP but the price was right ($5).
That's an Atlas built Craftsman DP probably 1930's, and that's a USUCK score!
I think the fence/guard is from a different machine, probably a shaper.
The box was probably painted and looks to be a 50's/60's lunch box.
