rlitman
I'm changing the ball joints (among a few other things) on my Wrangler, and ran into an issue that has not come up for me before.
I do most of my work on the car with my 1/2" drive deep impact socket set. I've got the Snap On 325SIMM set, which includes (25) deep impact sockets (10–27, 29, 30, 32–36 mm).
(rant on)
First, in removing the hub bearings, I found that each side has a 13mm 12 pointed bolt head, and all of my metric sockets are only 6 pointed. Off to the store to pick up a 12 point socket.
Then, I found out that the castle nut on the lower ball joint is 28mm. What the heck. I thought that I'd be pretty set for whatever comes up with this socket set, but darned if they didn't skip that size. I was able to get the nut off with a 1-1/8" socket, but if it were any more rusted, I'd have risked spinning it and doing myself a real disservice.
(rant off)
And of course, the replacement ball joint uses a 27mm castle nut, so I'm all set for that.
So what's the deal with 28mm nuts, and why does every set I can find seem to skip them? Will I ever be likely to encounter one again, and if so, should I go and buy the socket?
(rant on)
(rant off)
