Compressor Shopping Advice?????
Dtraster
Looking for a new air compressor for my garage/shop. Any advice would be appreciated. Major uses:
Filling tires;
Blowing dust;
Staples, brads, and finish nails;
I own a framing nailer but don’t use it much;
Occasionally use a small air hammer to chip cement;
I have sand blast cabinet that I want to be able to use more often.​
Before it shot craps, I was generally okay with my old compressor--details below--except when using the sand-blast cabinet or the air hammer. Even then, it wasn’t terrible.
After reading some on this forum, here’s a short list of preferred features and the reason for each one. I’m not sure that there is a compressor out there that includes all of these features but at this point, I’m trying to figure out what to look for.
Belt Drive: Can replace the motor if it goes bad. Can’t replace the motor on mine. See below.
Oil: Quieter
Lower RPM: Quieter
Tank: Largest tank for the money but it will be in the 25-60 gallon range.
Single stage: KISS
Cast iron: Lasts longer
Stationary: I can drag hose and will eventually plumb the shop with multiple outlets.
Single phase: Don’t have 3-phase power or a phase converter
110 v. 220: Not a major factor but 110 would get me started faster. I would need to run wire for 220 (which I need to do anyway so I can use my welder—it’s just me so they don’t need to run at the same time.)
Current compressor:
Alltrade Air Plus 540011: 25Gal 5HP Air Compressor
5 Peak HP
25 Gallon Air Tank
Oil Lubricated Direct Drive Pump
Cast-iron Cylinder
Maximum Pressure: 125 PSI
Power: 115V, 60 Hz, 15 Amps
Air Delivery: 5.0 SCFM output @ 40 PSI / 3.2 SCFM output @ 90 PSI
Duty Cycle: 50%
Thermal Overload Protection for Safety
High Flow Regulator for Precision Air Flow Control
Dual Pressure Gauges
Weight: 128 lbs. (58 kg)​
Something’s wrong with the motor. Burns start capacitors in a few minutes. Can’t replace the motor because the model is obsolete and parts are out of stock. I called the company—no help there.
Considered taking it to electric motor shop to assess but that would probably cost $50.00 and assuming that it’s repairable plus any repair. Maybe they wouldn’t charge for assessing the problem if I have it repaired but I’d still end up with a less than ideal compressor.
raferguson
Colorado
Your current compressor, and any 115V compressor, is way too small for sandblasting. For the rest of the uses it would be fine. You want to go 240 volts, and have 15 to 25 amps rating on the motor. Compressor horsepower ratings are fantasy, look at the amps on the motor.
BF88
I probably don't know nearly as much as the other people that has responded on here about compressors, but I have experience with the Husky 30 gallon compressors. Can't remember the exact stats on them, but my buddy has the regular black tank 30 gallon upright oiled, and he painted 6 cars with it, and we have used it to do multiple other jobs that it has stood its ground on. I am not a fan of anything husky typically, but their air compressors are quite impressive to me for what they are. I had a 30 gallon husky pro, and I painted part of a car with mine, and have used it for a bunch of other things before I sold it.
Ole Slewfoot
Freedom, CA
I'd look for a used 220 2 stage from the 40s 50s, 60s, 70s,80's, or 90's.
Way more for your money, and the design hasn't changed really. downside is they are not easy to move around.
matt_i
SE Michigan
Imo, the easiest best answer is to buy a 2 stage 60gal compressor with a 3 or 5hp motor. Its well within the range of possibilities that you don't ever have to worry about buying another compressor in this lifetime.
rburke65
Canfield, Ohio
Buy once. You will need a 240 Volt, 60 gal., 2 stage compressor for your blast cabinet. Just buy it....move on...be happy. I have a Champion purchased from TP Tools, very quite.
D
Dtraster
So, update my from Single to Two stage and 220 not 110.
I like the idea of buying an older used compressor. In fact, that's probably my preferred approach. I just haven't seen one on CL recently. I'd worry a little bit about the tank being rusty... is there a way to check to make sure the tank isn't about to go?
