A few weeks back Matt at Eastwood called and asked if I would be interested in testing one of their new scroll compressors in the shop. I've never "reviewed" a compress...
If that 69 dB rating at 1 m is true
Been looking at this and just waiting for them to tell me I can go to eastwood in chicago to pick it up. So anyday it's ready I will be there. my other compressor just crapped out and had to buy another one to get me buy in the meantime, but I'm excited to work with minimal noise. If it is fact 69db. We will see.
Our Chicago store is participating in the Pre-Sale. You can call them and get the discounted price and save shipping to pick up in the store when they arrive. After the Pre-Sale is over the stores and our site will be charging full price. Hope that helps!
-Matt/EW
Two of the most problematic uses for any compressor are spray painting and sand blasting. Heat added to the incoming compressed air adds or absorbs more moisture to your compressed air supply. When i am spraying anything by the end of my project i am usually seeing moisture in the air lines even with multiple absorbers in line and at the spray gun. If you look through the many GJ threads on this subject, you will find that those problems are tackled with varying amounts of success by the members here. Does the scroll compressor improve this problem?
I have no idea... Maybe Matt at Eastwood could answer your question.
I did, however, use it on the sand blaster for a bit... and it ruled. Even with the tank depleted, the compressor did a great job keeping up with it... and I never noticed much condensation. So, there's that.
It is quieter than most, but I see Eastwood did some movie magic to their videos.... It seems like they shot the video from miles away with the camera zoomed in to get that scroll compressor seemly running at no noise at all. maybe.. the noise difference between the two video is apparent...
What size/specs is the blaster?
What is the price going to be after the Pre-Sale?
How is the longevity of this compressor?
Either way, thx for the review.
Where is it manufactured?
This is the blaster I was using:
http://www.tptools.com/USA-SKAT-CAT-46-Abrasive-Blast-Cabinet,8892.html?b=d*41308
The last time I used this blaster it was hooked up to my monster Champion VR5-8. The QST didn't keep up with the blaster as long as the Champion does, but it did surprising well... and because you can't hear it over the blaster, it made blasting more enjoyable for sure.
I appreciate the review. I was surprised to hear just how loud the compressor was in the video. To be able to hear the background worker, his music, the guy talking, and then hearing the compressor get flipped on, subjectively, that doesn't sound a night and day difference more quiet than my compressor, a California Air Tools type pump. It certainly didn't sound anywhere near as quiet as the marketing video makes it out to be. I guess there really will be know way to know just how loud it is unless you hear it in person. What sounds loud to me, other may barely notice.
Sorry to keep asking question but that's the kind of set-up I'd like to get eventually. Do you remember how long did you go before you were out? Are talking a minute? 5, 10, 15? It's been hard to get some actual idea of what it's capable of in the reviews so far.
I also wondered if the scroll compressor maybe didn't heat the air as much, leading to less humidity. I guess a scientist would have to answer that one. I ask more out of curiosity, as most of my air needs aren't dry-air-critical.
Again, I don't know how to quantify it but this thing is the quietest compressor I've ever been around. The best example of it I can think of is a typical air conditioner... Like right now I have no idea if mine is running because I'm not thinking about it. That's sort of how I feel about this compressor.
Another way to say it... It's produces about the same level of sound as my drill press.
There is no comparing it to any piston driven compressor I've ever heard. I'd bet my pink slip it is way quieter than your piston compressor. You just need to hear one to judge for yourself I think.
If you are looking for an excuse to pass on this one, chose something other than sound level. Seriously. It's quiet. I don't know how else to say it...
I should have taken note... I don't do a lot of reviews because I'm not all that good at them and this is a great example of that.
It's hard to say how long I blasted until the compressor turned on simply because I couldn't hear it kick on. I'd guess I blasted well past 10 minutes though before I noticed the pressure backing off and stopped to let the compressor catch up.
Another question I have is about the unit's center of gravity. Usually, these things are unbelievably top-heavy since the motor is on top. I have avoided putting casters on my small compressors because they will wind up getting pulled around by the air hose or cord and the casters will get tripped up on something and I'll wind up gouging a car door or fender. Is the scroll compressor much lighter or heavier or lower than a comparable piston compressor?
And finally, this type of compressor seems kind of new to me, but I haven't been shopping for compressors lately. Are we about to see several of these types of compressors hit the market? Nothing brings down prices like competition. I might not gag on this price point, but nothing makes me madder than being an early adopter and then finding the same unit for sale from another brand at a much lower price.
That's all fine and dandy, but is it quiet?![]()
Anyone planning on hooking this up to a bigger tank? Is it needed? does the compressor really do the job of a 60gal? I have a true 5HP 60gal with a 2 stage pump that puts out 17CFM@90PSI and it is overkill for what I use but this air compressor on paper would struggle with quite a few HVLP guns. Seems like it all comes down to noise with somewhat decent air output.
I have a skat blast cabinet as well, TL780. The size of the nozzle determines flow, a small nozzle I think is in the 5-10 cfm range, med 10-15 cfm, large 20-25 cfm at 90 psi. There are a lot of nice features with this compressor but the tank size is a concern. As mentioned there is the concern with a new product, will it last, will the price change as competitors copy it, will a larger size be offered that may suit more applications? Do I buy this now only to see say a 18 - 25 cfm machine come out next year?
I have been looking and was very close to the Emax 5 hp 2 stage 60 gallon silent air machine with about 17 CFM so it would be interesting to see these side by side for the low noise title!
