Killing time in a small "2 car" garage
BoilermakerFan
Indianapolis, Indiana
Stunning! Beautiful! I may attempt this one! Thank you again!!
Enviado do meu iPhone usando Tapatalk
:thumbup:
Sent you a DM too...
Tonight I didn't feel like creating more dust in the garage. So I took the night off and did some browsing for speaker designs other than the one I shared for rodpao. I found a couple that caught my interest so they're now bookmarked. For now, I'm going to pick up a little BT enable amp for the garage and just bring my ol' Polk Audio S4s out there after the excessive dust generation is done.
BoilermakerFan
Still waiting for my buddy to have a weekend free that I can get up to his place and grab the plywood and Corian.
Tonight I'll head out to the garage and do more sanding on the work bench top. Tomorrow I'm planning to get the shelves for the basement built, or at least a good jump on them.
I realized I need to get these big things out of the garage to give me room when I finish the walls.
I also need to figure out a new arrangement for the garage so I can accommodate a DIY blast cabinet, curing oven, and spray booth in my limited space. The booth will have to be a partially collapsible unit. I'll basically build the blower into the wall, then have the filters on a frame on the wall. I'll make the top, sides, and bottom hinged to fold flat against the back to minimize floor space when not in use.
I thought about building the oven big enough to allow the blast cabinet to be stored inside the oven when not being used, but then I would have to have the dust collector mounted to a wall and reattach it every time I go to use the blast cabinet. It would also make the oven's footprint bigger than I planned, but it may still be the most efficient use of space.
I really wish I had the room in the attic space to store these things. In my next garage, I'm definitely having a full 2-story shop with storage above. I could easily hoist them up into storage but not in this small garage with only a 4/12 pitch roof.
BoilermakerFan
Another 2-1/2 hours of sanding tonight but I made a lot of progress leveling the top of the workbench.
There is still a little crown in the very center of the top, but my shoulder and hand had enough of the vibration for the night. I'd say I have about 40 sq. inches of area to work on (primarily the 3 center boards about 15" long), but I need more 40grit discs for the sander and a box each of 60grit and 80grit for the next steps:
I did get the box joints sanded flush too. One side trim board needs a little filing in the notches to bring the front trim closer to flush with the bench, but this trim on the RH side that will have the T-Tracks too, so it needs to filed to fit in more easily anyway. What's a few more hours of work at this point anyway... I've been working on this bench on and off since June 7, 2016 according to my IG feed. :eyecrazy:
One of the things that I tested was using corse sanding sawdust mixed in withe the Danish oil to fill the small pits and knots in the top. Well, I wasn't happy with the results and I decided I was going to dig it out and use ZPoxy finishing epoxy with the sawdust mixed in. I'ved used the ZPoxy before and it cures to a very light amber color. It will work fine for this project.
After I was done sanding for the night, I decided that tomorrow is the time to epoxy those pits and knots before I keep sanding. So I dug out the spots that had been filled. Then I decided to go ahead and dig out a couple of other small knots that looked a little suspect. I'd rather fill them now then have them pop later. All said and done, there are 5 or 6 small knots and 5 staple/flooring nail holes that need the epoxy filler. I'll touch up the spots with a diamond burr in my Dremel to make sure there is no oil left in the holes for good adhesion by the epoxy. Any of the sawdust that gets exposed after sanding will absorb the Danish oil so I will touch them up with Medium Walnut oil before I put on the Dark Walnut to pop the grain.
Hopefully by Sunday I can layout the locations for the T-Track grooves and get those routed into the top! Then the finishing can begin! :rocker:
I want this work bench done by mid-December at the latest so it can be moved into it's new home in my basement hobby shop.
Grumblebum
Wollongong Australia
The grain is going to look real nice when you finally get some oil on it BMF.
I finished some drawers today for my dad, but never got to play with box joints, just glued and screwed. I'm at the point where a router table would be handy so will have to see what is about that can easily take jigs.
Cheers GB
BoilermakerFan
Cheers GB
Thanks GB. I had the top about 80% finished before so pics are somewhere in this thread, but I'm going to go a little darker overall this time. I spent a good evening out in the garage early on adjusting the board layout to get the best color variation and grain patterns out of my bulk bundle of hickory flooring. I did the same thing when selecting the boards for the trim. I wanted a lot of figure and variation.
With a router table you can make or buy some really cool jigs to make all sorts of joints. The Porter-Cable jig I'm borrowing uses a hand held router and is limited to 12" wide stock. :( One of my shelves for the basement is 16" wide.
A router table is on my long list of future projects too, but it's pretty far down the list and may not happen until after we move which is an unknown date in the future.
BoilermakerFan
Used a diamond burr the clean out all of the holes and found another knot that I decided to take out. Then I mixed up my Z-Poxy and sawdust...
Filled all the holes and knots. The Z-Poxy cures in about 3 hours so I'll wait until tonight to do more sanding so I know it's fully cured. After it's sanded again, I'll check to make sure all the holes are filled flush with no bubbles or air pockets.
I also pulled off the RH side trim to fill the divot in the top created when my flush trim bit hit a void in the plywood sub top. While it's off I'll file the side box joints down to allow a tighter fit of the front trim and make the side trim easier to remove when accessing the T-Track. I could machine pockets in the T-Track to drop in the bolts to attach my sub-bases, but I prefer the continuous track and I really won't be changing the sub-bases very often. If it becomes a pain I can always machine the pockets in later after I have a better idea where the best positions are for them.
BoilermakerFan
Cheers GB
I realized I never read your thread... so I'm starting at page 1... Your shop area is bigger than mine, but I'll see what ideas I can glean from your thread. :beer:
bj383ss
TX
Boiler workbench is looking great. I made a built in study for my FIL out of Pecan which is very similar to Hickory. It is tough as nails but is smells really good when you machine. I think once you build a router table you won't know how you ever built anything without it.
Bret
BoilermakerFan
Bret
Thanks Bret. I love Pecan too, but I can only get hickory or maple around here beside red oak :)puke: - sorry, I don't like red oak). I could probably special order Pecan, but I like being able to cherry pick the best pieces too.
I'm not sure how much I would use a router table here at this house. After I get this bench and its drawer cabinet done, I don't really have plans for any more real woodworking projects for a while. The speakers can be cut out on the CNC router at the university where I teach as an adjunct instructor in the spring semesters. When we move I know it will come in handy so if it's not built by then it would be one of the first things I do build.
That said, I'm not really a woodworker. I mostly build stuff I need out of plywood or 2x lumber because it's easier or cheaper than building it our of metal. That and I don't have a welder yet. I had a bunch of woodworking plans that I have kept for years that I either recycled or scanned in to PDFs. Now, I do want to build and restore wooden boats in the future, but I don't consider that woodworking in the traditional sense.
BoilermakerFan
I sanded down the epoxy/sawdust repairs tonight with 40 grit, including the divot on the end of the top. The crown in the center of the bench is still there, but it was greatly improved. Tomorrow I'll switch to 50grit discs and keep working on it.
Every one of filled holes was nice and flush, no voids or air pockets to touch up. :rocker:
I also worked on filing the side trim to get it to fit better and looser so it can be easily removed. After an hour, it's better, but I still have more filing to do (for scale, the trim is 3/4" thick):
I realized it will be easier to remove the front trim (on the left) and keep the side trim (on the bottom) attached so I can use the frame edge as a filing guide for how much material I need to remove.
I did about 3 hours of yard work today, most of it with the leaf blower so my arm was pretty tired already. I called it a night a little after 11pm. I need a more aggressive smaller file too. My file that fits in the notches is a pretty fine cut.
I won't get any QGT until late Sunday night and I may not get any at all.
I'm a NASP archery coach and we're starting a team at my son's new middle school (he was at our Catholic parish school for grade school and has been shooting for four years, but with a daughter in college, we moved him to the public STEM Academy for middle school). His new school has had an archery club for the last 3 years and they teach it in gym, but this year we're going to shoot some local tournaments and develop the team. My goal is to get the parents to put pressure on the high school our middle school feeds to allow us to start a team there too. It will take a large group of parents from both middle schools to make that happen. The AD blew me off when I tried to get the high school to start it last year. I've got 2-1/2 years to keep the pressure on the AD at the high school to make it happen.
The teacher that runs the archery club never tied on proper nocks on the bows and the little heat shrink pieces that come on the bows all move around. Hard to coach kids on improving when the bow isn't consistent. So I brought 8 of the school bows home to set them up properly and tie on nocks. The Phys. Ed. teacher is starting archery in gym class on Monday so I have to get the bows done and back to school my 7am Monday morning. Then next Thursday (school is out Friday for Veterans Day) I bring home 8 more bows to setup and get those back the following Monday. The following Friday I can bring the last of the bows home for proper setup. Phew. It's work, but so worth it since it makes it easier for me as a coach and the kids won't get frustrated.
So Sunday is set up bows day and my son wants to go shoot at local indoor range Sunday afternoon with an old teammate. That's ok with me, my shoulder needs a break.
BoilermakerFan
Well, as suspected, no QGT today, but that's ok.
Took my son to get a haircut, then we headed to the Y. Lots of eye candy there today so that made it easier. :evil:
After working out at the Y we headed to the archery range. I brought 3 of the team bows with me to dial in the nock locations for a light draw, medium draw, and heavy draw weight bow. I used those to set up the other bows I had brought home.
National Archery in Schools Program, or NASP, utilizes fixed equipment with pretty strict rules. The Bow is a Matthews Genesis bow. It's a constant draw weight compound bow that can be adjusted between 10 to 20 pounds draw weight and the draw length can be up to 35" IIRC. I know I don't fully draw the bow when I get to my anchor point. The arrows are fixed, you can only use NASP approved Easton aluminum arrows. You are not allowed to use sights, releases, or draw stops. NASP focuses on technique so the rules keeps the field of competition as level as possible. BUT, there are some tweaks you can legally do to the bows to make them shoot more consistently, and that's what I try to do. I dial in the bows as much as I can within the rules which is really just finding the sweet spots for the draw poundage in the ranges and the nock locations. Last year we discovered that as little as 40 thousands difference in the limb gaps can make a huge difference in arrow flight consistency depending on the bow. :wtf: Yeah, that shocked me.
There are elementary school (grades 4 & 5), middle school (grades 6-8), and high school teams. All the archers shoot the same 10M and 15M distances at the same standard size target. My son would consistently beat high school kids as a 5th grader at tournaments, but that was also his fourth year shooting; never the less, he loved beating high school boys. Younger grade school kids can shoot up and elementary kids can shoot with a middle school team. My son started in 2nd grade and I was trained as a coach then. He didn't shoot tournaments until 3rd grade and even then, we only shot 4 or 5 the entire season. In fourth and fifth grade we shot as many tournaments with the team as we could, including state and the nationals in Louisville, KY. Our team qualified for the Worlds, but we personally skipped it. Nationals is actually a bigger tournament that Worlds.
Coaching archery is just one of those things that came naturally to me. It's very easy for me to see what shooters are doing wrong and help them correct it. I can generally add 30-40 points to a shooters score in 4 weeks working one-on-one with them at two practices a week. A perfect score is like bowling, 300. Last year I got 3 archers into the low 290s from the 260s & 270s. Once your in the 290s, it's very hard to get those last few points because it becomes emotional and psychological. A lot of archers choke after shooting 4 tens and then shoot an eight or nine for their last arrow. I do the same damn thing... The last arrow when you have 4 tens becomes the worst arrow you will ever shoot, especially in a tournament. Our middle school team placed in the Top 5 at State in Bullseye the last two years and Top 2 at State in 3D the last two years.
Even though I'm no longer coaching for my son's previous school, I've had 7 archers and their parents (3 of which are coaches themselves) ask if I would continue to coach their kids outside of their scheduled school practices. All 7 kids listen to me and are great kids so I've agreed to keep coaching them when they need help. One girl is a senior in high school this year and both her parents are coaches, but she only improves when I coach her. She doesn't like her other HS coaches and won't listen to them, but they also ride way to hard. Another girl is a 7th grader and her dad works for a company that is one of my customers, but I didn't find that out until later. She and my son shoot really well together. My son actually shoot his best when he shoots with her so it's easy for me to coach the two of them together.
The funniest thing about it though is that my son didn't listen to my coaching until last year. He would really only listen to one other coach so I usually just told her what my son needed to change and she would tell him. And funny enough, her daughter would only listen to me and none of the other coaches including her mom. Then my wife kind of laid into my son about not listening to me when all the other kids I coach do so well and he wasn't shooting very well. He started to listen and actually asked for coaching after that. He improved his average score by almost 40 points last year and won a Top 5 medal for elementary boys in almost every tournament. Now we go and shoot at least every other weekend even during the summer when there is no archery. Once the tournaments start, we'll be shooting at least 3 times a week because now that he's in middle school, it will be harder for him to medal at tournaments unless he puts in the practice time.
Tonight at the range, I was on fire! My worst arrow was an 8 and my worst round was a 47 out of 50. So my son had to focus and step up his game. His worst round was a 45, but neither of us shot a round of 50.
This evening I set up the school's team bows that I brought home:
Only took about an hour and ten minutes so this Thursday I'll probably bring more than 8 bows home.
rodpoa
Another facade of yours! Do you hunt as well?
BoilermakerFan
I think you meant facet and not facade. :D A facade is a fake front. A facet is one side of a many sided object, or in my case one of my passions.
Just giving you a hard time, I know English is not your native language and I knew what you meant.
But yes, coaching archery is one of my passions. I also coached high school girls lacrosse for two years, but I stepped down this year since my daughter graduated high school and is now off to college. The parents asked me to keep coaching the girls, but I just do not have the time to commit to the girls team. I've helped coach or been the head coach of every team my son or daughter has been on for the last 12 years or so. The last 6 years were definitely my most active years with soccer, basketball, baseball, archery, and lacrosse. My son will be playing boys U12 lacrosse this spring so I will be an assistant coach for his team. I know the coach and he's excited to have me help out since U12 and U14 boys lacrosse is no contact like girls lacrosse. Girls lacrosse has a lot more finesse and skill to it since there is no contact.
I've never been a just drop off the kid, pick up the kid parent. I have no issues with parents that are, but it's not me. If my kids are involved in a team or extracurricular activity and they need help, I help.
I try to hunt when I can. I usually only get out in December for deer, it's just the way my schedule tends to work out. I'm a huge proponent of hunter's rights, habitat conservation, and environmental protection. Healthy woods and healthy rivers means healthy game populations and therefore healthy humans. I belong to the National Wild Turkey Federation and Pheasants Forever. I'm a committee member for our local Turkey Federation chapter, but just a member of PF... that time thing again...
I have a nice recurve hunting bow but I don't hunt with it yet. I'm not 100% confident in my shot hitting exactly where it needs to in order to humanely put down a deer so I don't use it. I practice and will keep practicing so that I am 100% confident. Taking that first deer with my recurve is something that I am looking forward to doing.
rodpoa
Don’t worry at all. Do give me the hard time :D that’s the best way to improve. In my defense though I can blame the autocorrect this one time. As I have three active keyboards in my phone and the new iOS autocorrects regardless of which is selected, it never learns the most used expressions from neither and keeps switching my words between different languages. Facade is a front in Portuguese as well, but not a fake one, just a regular front in general.
Coming back to hunting, then you are probably into cooking and meat as well right? I just saw in the other thread a guy that has his own meat room :D
Jokes aside as we’re mostly livestock producers here, everybody is obsessed with a perfect barbecue. Cutting, roasting, cattle race, seasoning is another rabbit hole of mine. Hunting with a bow, though? That’s crazy! Something I’d need years and years of practice to master :D
Awesome hobbies buddy!
BoilermakerFan
That's hilarious!
I was a Sous chef at a country club in college. I own a set of white handled Wusthof Classic knives. Daytons department stores out of Minneapolis thought they would be a great wedding gift so they had them specially produced for their flagship stores. :lol: So I scored a helluva deal from the local Wusthof distributor on them. We've had them for 19 years and counting. So yes, I cook. We often host Thanksgiving and/or Christmas dinner. I used to have a small Char-Griller smoker that I extensively modified (but they are made out of thin sheet metal so it rusted out pretty quickly)... I used to go to Tulsa, OK on business about every 3 weeks and I was active on The Smoke Ring forum. My friends in Tulsa were all competitive BBQ guys and/or pros. I need to buy a stainless steel Hasty-Bake grill to replace my smoker and when we move, I will be building a large outdoor kitchen complete with a large grill, multi-section smoker, and wood fired oven. Already been down that rabbit hole! Popped back up to find a new hole. :p
My hunting mentor butchers his own deer and it is a skill I want to learn, but we have goose egged the last 3 years so I haven't learned how to butcher my kills yet. I also have a dozen books on cooking wild game and 2 on butchering meat. Yes, I caught the post in Gregor's thread about the guy's butcher room. I may be adding that to my future requirements of the next house. :thumbup:
Right now I'm spoiled. I have a meat share in a local producer. They are a family owned farm and many times I go out to their house to pick up the share.
We get 12-15 pounds of meat a month for $85. Several times a year I get a share and a half, especially in November, December, and January. They raise heritage breed beef, lamb, goats, and hogs. NO grain ever, no antibiotics, no steroids, no growth hormone. The animals are on the pasture the entire time. The only thing they add is supplemental flax seed out in the pasture the last 4 weeks if the animals want to eat it, they can. It raises the Omega 3, 6, and 9 levels in the meat. They also sell or give me the less common cuts of meat including oxtail, liver, and heart. I could get kidney and tongue, but I pass on those. I can't eat a lot of pork, it bothers my stomach, but I can eat the bacon so I typically get a pound of it every other month. They're lamb is incredible and I use their ground goat to give my chili a rich, hearty flavor that I just can't get from beef. I rarely eat beef in restaurants. Since having the meat share for the last 4 years or so, store bought or restaurant beef has no flavor and the fat is tough. The fat in our meat melts in your mouth... like I said, I'm spoiled.
If the beef is great, all it really needs is a little salt and pepper. When I grill a chuck roast, I only season it with salt, garlic, and a little sweet basil. It doesn't need the garlic or basil, but we like the flavor profile. Then I cook it indirect and add a little sassafras, pecan, apple, or hickory for a bit of smoke. We also cook a lot of it in the slow cooker with carrots, onions, and celery. Sometimes we toss in potatoes too.
I was diagnosed with Celiac Disease over 5 years ago. That changed what I can eat (and drink) significantly. Beer and artisanal breads are out, as well as traditional pizza crust and pastas. I used to make my own breads, chocolate chip cookies (mine were the best!), pizza crust, potato gnocchi, and empanadas. I haven't attempted to make a gluten free empanada, some day I will. I miss empanadas. I've found a decent gluten free bread kit I can cook in my bread maker and a decent GF pizza crust kit, but they aren't the same. The only thing that I like better GF is shortbread cookies. They turn out flakier and crispier without being tough. Celiac Disease has presented new challenges regarding my cooking, and overall I'm ok with it, but I do miss great breads and great pasta.
rodpoa
That's hilarious!
I was a Sous chef at a country club in college. I own a set of white handled Wusthof Classic knives. Daytons department stores out of Minneapolis thought they would be a great wedding gift so they had them specially produced for their flagship stores. :lol: So I scored a helluva deal from the local Wusthof distributor on them. We've had them for 19 years and counting. So yes, I cook. We often host Thanksgiving and/or Christmas dinner. I used to have a small Char-Griller smoker that I extensively modified (but they are made out of thin sheet metal so it rusted out pretty quickly)... I used to go to Tulsa, OK on business about every 3 weeks and I was active on The Smoke Ring forum. My friends in Tulsa were all competitive BBQ guys and/or pros. I need to buy a stainless steel Hasty-Bake grill to replace my smoker and when we move, I will be building a large outdoor kitchen complete with a large grill, multi-section smoker, and wood fired oven. Already been down that rabbit hole! Popped back up to find a new hole. [emoji14]
My hunting mentor butchers his own deer and it is a skill I want to learn, but we have goose egged the last 3 years so I haven't learned how to butcher my kills yet. I also have a dozen books on cooking wild game and 2 on butchering meat. Yes, I caught the post in Gregor's thread about the guy's butcher room. I may be adding that to my future requirements of the next house. [emoji106]
lol ! Of course you were a sous chef. This is getting funny [emoji3] What haven’t you done? GJ is a crazy place indeed.
I’m surprised you don’t craft your own knives!
I do have meat ‘specs’ as well. As we’re from a cold region we get to raise European cattle. We raise Hereford. To support the family, I only eat grass fed Hereford steak while the rest of the country eats the much cheaper confined Indian based Nelore. They stand heat better.
I don’t know how to butcher either. I actually feel ashamed about it. Although, it is never late to learn.
And empanadas? Really? I literally fly to Argentina for the empanadas! One of the best simple things in the world. Empanadas with oak aged Malbecs [emoji3]
About the celiac stuff, I don’t know what to say. I eat bread and past like if I was born in Italy. I don’t know what would I do in your position. Sounds tough. Sorry about that! I thought about starting to post some extra-curricular activities like homemade pasta and bread making but now I feel like I would be torturing you. That ***** man. Hope your alternatives do work out.
Again: impressive hobbies! Looks like GJ gathers all the people that gets obsessive about stuff. Makes us feel less crazy [emoji3]
BoilermakerFan
Re: Killing time in a small "2 car" garage
Yep, I even wore the full white uniform and carved Prime Rib during wedding receptions. In addition to the good money I got paid, I got to keep the tips. And yes, I know how to carve meat properly.
Not yet... I don't have room for a forge and I haven't built a belt grinder yet. I have been looking for decent anvils though. But again, the good ones are $3-$4 a pound or more and out of my budget at this time. I am planning to buy some knife blanks and craft the handle scales for them though. I have a craftsman out in Colorado who is going to make new handles for a lot of my wife's grandad's hand tools and he's making me a double bit felling axe with a great forged head. I scored a Japanese forged 8lb sledge hammer head that will be going to him too. I already have a hatchet and planishing hammer from him. One of things he makes is knives from old forged rasps. He made a boot dagger and swore he would never make another. I almost have him talked into making just one more for me. :rocker:
No it's never too late. I didn't start hunting until I was 40. Haven't killed anything yet though, but I also don't sit in a tree stand all day and I mostly hunt on public land. And being able to humanely take an animal and butcher it myself is important to me.
Oh yeah, I love empanadas. I used to really be into wine. Got burned out on that too, but I do enjoy a good Malbec or port.
And no worries! Post away! The beer was tough. One of my hobbies was collecting bottle conditioned Belgian ales. Mostly doubles, but triples too. I would treat them like wine. Kept them stored in my basement in a couple of coolers to keep them dark and stabilize the small temp swings. I also loved a crazy brewery called Dogfish Head. They brew some very unique malted beverages. I used to homebrew as well. Sold all my equipment and supplies.
I never drank bourbon before I was diagnosed with Celiac, but now it's a new hobby. I still can't drink it straight or even on the rocks. I need my Coca-Cola training wheels, but I do enjoy it now.
Yeah, like my sig says, too many hobbies. But when something interests me I research it and learn about it. I love learning about things, figuring them out, how they work, how they fail, how they can be improved, etc. If it's something that I can learn to DIY, I will probably head down that path. I do put a value on my time and money however, if it will take me longer and cost more to build it when I can find it in the quality I want at the price I'm willing to pay, I won't hesitate to buy it. I have learned about things that interested me that I never intend to own or do, but I wanted to learn about them. I have a friend that builds small scale P-51s. They are 1/3 scale and fly, they are registered aircraft. It's a fascinating process to build a plane from scratch, but it's something that I would never want to do myself, but the process, the requirements, the skills involved absolutely blow me away. I've been to the EAA (Experimental Aircraft Association) Fly-In in Osh Kosh, WI. I'm planning to take my son in a few years. I love the EAA fly-in. I don't have a pilot's license and have no plans to own a plane, but I love that show and talking to the people who have built their own planes or restored vintage aircraft.
There are some things I do DIY just for the enjoyment of the process, but a lot is driven by economics. DIY audio is one. I can build audiophile grade HiFi for far less than I can buy it. The motorcycles are a bit of both. I can't afford a new motorcycle right now so I traded for a bunch that need to be fixed up. But I love the whole process with the motorcycles. The tear down, the planning, the fixing, the building, and the riding. And when they're done, they're uniquely mine.
BoilermakerFan
ADD is a blessing and a curse.
Eh, I think of it more as a gift, but yes, it can have drawbacks at times. I just turn 45 last week, so in many ways it has gotten better. My doctor did give me a prescription that has helped immensely too. It's an anti-anxiety drug, not the usual ADD stuff so it just takes off the edge of the jumping monkey brain. It allows me to pause to think, "yes, I could go off on that tangent, but maybe we should stay focused." Of course there are times that the answer is "nah bro', we're going off on this tangent... hold on," however, those times are much less frequent than they used to be.
And I take breaks from some hobbies and come back. Others like the wine, I was just totally done with. But for me it's easiest to accomplish things if I have just 2 or 3 projects going so that when something is drying I can keep working on another thing. I'd say it's taken me about 10 years to really figure out the best balance for me WRT ADD, projects, work, life, etc. I don't feel like I'm a zombie, I still have the creative thought process, but I get a helluva lot more done with a lot lower burn out rate.
A good example would be knife making. It's something I have studied extensively. I follow guys that hand forge knives from bar stock on IG. I'd love to jump in and go for it, but I've kept myself focused on the projects I have on hand, the funds I have available, and the limited free time I have. I could save the funds to buy a belt grinder, but building a blast cabinet, spray booth, and curing oven would cost the same as one grinder and those 3 tools will pay me back in spades with my projects and friends already asking if I can coat stuff for them. So I'll buy pre-finished knife blanks and make the grip scales for semi-custom knives for myself. My secondary plan is to trade coating services with a couple of the guys that make knives... So I'll get a custom handmade knife out of the deal.
That's probably one of the things that I do more now than ever, I always try to trade for things I want with either stuff I no longer want, technical services, or goods for those things. It almost always puts a higher dollar value on my time that way too.
BoilermakerFan
Well, it's going to be slow progress for the next couple of days...
Tonight the extent of the work I got done in 90 minutes was to make one pass over the top of the bench with 50 grit on the RO sander and start filing the notches in the side trim to allow the front trim to snug up closer to the top and eliminate the gap.
I was able to get two (2) out of six (6) notches done tonight... The very top one and the second one down.
I used my hand saw to cut depth marks in the two edges of the notches so I know how far to file. I ran the saw in until the teeth were flush with the frame of the bench. It actually worked really well, but I still only have a fine tooth file so it's a SLOW process.
One cool thing that I did notice is that my epoxy patches were darker after the 50 grit sanding pass. If they continue to get darker, this will be very good for the finished look of the bench top since the knots are very dark in the wood.
Time to cool off then head to bed.
rodpoa
****... the ADD thing is officially a confirmed diagnosis then? I think I do slip away sometimes but it never got to the point of searching for professional help. Do you take your medicine regularly or only on a need basis?
Maybe don't go into knives now. Just to not spoil your signature some more :bounce::bounce:
I am starting to wonder whether GJ is healthy to us all :bounce::bounce:
BoilermakerFan
I am starting to wounder whether GJ is healthy to us all :bounce::bounce:
Oh, I knew I had it for years, but yes, I "pass" every ADHD test. In my 20's and early 30's it was really bad. Didn't affect my work too much because of what I did for a living, but I only slept 4-5 hours a night on average during the week and 10+ hours on the weekends. Then in my late 30's and early 40's the forgetfulness got to be too much and it was bothering me so I asked for help. I didn't want the usual medications because they dull you down so much. I take my med daily at night now. The only bad part is if I miss a dose... because it is an anti-anxiety med, missing a dose for than 36 hours caused me to have an anxiety attack. Never had one in my life before and that sucked! So now I know I have to keep it on a schedule. I've read a ton of books on adult ADHD and it was interesting how many of coping strategies in the books I already did so I guess that's why it was never too much of an inconvenience.
Genetically, I come from a long line of "night owls". My natural biorhythm would have me stay up all night about 4-5 times a year when I was younger. Now that I'm older it's down to once or twice a year, but I still stay up for a 32-40 hour period before going to bed. When I travelled all the time it was actually easy to work in to my schedule, but now I just plan it for a Friday night. I'll be up all night on a Friday night, then go to bed around 9pm on Saturday to reset my rhythm.
Yeah, no knifemaking for now. And I may never go that far down the rabbit hole since I enjoy building motorcycles so much. If I just buy the forged blanks and do the finishing work, that's probably as far as I will go. Through InstaGram I've made a lot of connections so it won't be too difficult to get the blanks, but I'm not even thinking about that until next summer at the earliest.
I had already been planning to build the spray booth, but originally I was just going to build a smaller bench top model. Then I saw plans for a built in back wall design. I'm just going to add the folding top, bottom, and sides to keep powder contained and clean so I can reuse the overspray. That was decided when I read that it can be reused if it is kept clean, so that change is driven by economics and my desire to minimize waste. Building my own DIY curing oven is also being driven by economics, but again, I had originally planned to just use an old oven for smaller pieces. When I saw how easy they are to build, I decided to scale it up so I can do my own frames and other parts. The DIY blast cabinet stemmed from the need for cabinet so I don't fill my yard and driveway with sand... and sticker shock at the cost of a cabinet large enough for motorcycle frames.
The oven will be built first, but I have to finalize the dimensions of the blast cabinet before I can build the oven because I have to build the oven big enough to allow the blast cabinet to be stored inside the oven. I'm doing this to minimize the permanent amount of square footage this equipment will take up since my garage is rather small.
And those three projects are on hold until I get my work bench done, outboard motor stands done, the garage rearranged, and get the lean-to added on to the garage for storage of the yard equipment. I'm not even buying materials for them until I have the space ready to go. That's one of the ways the med helps too. Without it, I probably would have gone out and bought all the framing materials and started building the base of the oven... then it would have put off to the side or hung on the wall until I was actually ready to get it finished.
rodpoa
I know what you mean. I sleep very poorly. I used to have the same average 4 hours of sleep and I am beyond forgetful.
My parents never understood it when I was younger. They thought I simply did not pay attention to anything. My house had strict rules. I had to wake up early with everyone, period. I was always moving like a zombie.
I married another night owl and we fit together just fine. But I have to be careful with not letting it impact work. Unfortunately business hours won’t work after 1 am.
First thing I did to improve was adding very intense exercises to my routine. If I make myself dead tired, I get better sleep. I’ve also bought this:
I don’t like smart watches so this was the best compromise for me. Half analog because I can’t stand digital displays. It has a sleep tracker though.
The cool thing about the tracker is that it establishes the social jet lag concept. It is basically the difference between your sleep window during the week and during the weekend. The weekend is usually when we indulge our natural sleep cycle. The week is when you have to adjust to the schedule of those regular people out there in the normal 9am - 6pm world.
Check out one of my reports. It basically said I was killing myself by increasing the odds of heart diseases due to highly dangerous levels of social jet lag:
It is way more under control now.
BoilermakerFan
Very cool! Post a link to the watch... but to quote one of my favorite lines ever in a song:
"Cool kids never have the time." - 1979 by the Smashing Pumpkins.
:D
And as I said, I do a better job managing my sleep now too. I usually go to bed by Midnight regardless of weekday or weekend and no later than 2am on weekends. I get up around 6:15 on weekdays and I'm usually up by 9am on weekends.
Edit: Found it. It's now Nokia Health...
rodpoa
:D
Unfortunately yes. There is no sapphire cristal anymore neither cow calf wristbands. Nokia obviously went cheap. It was a good company that Withings.
dchance
OKC
Really like the bench that you building. I looked for the link to site that I ran across earlier that showed patching wood with black epoxy and how the patches would really blend in with the natural defects. But I have not been able to locate that link.
Dwight
BoilermakerFan
I also read that the app is now horrible under Nokia's ownership... bummer. I guess I'll look for something else. My wife, daughter, and son want me to get a FitBit since they all have them and the Flex2 is finally water resistant for swimming.
Dwight
Thanks. I'll post a few pics tomorrow morning. I went ahead and put a coat of Dark Walnut Danish oil on the bench tonight to see how the patches would take the oil. They don't look bad, but after I sand it off again I'll probably use Black Walnut oil just on the patches before using Dark Walnut to pop the grain and final coats will be Medium Walnut.
I finished filing the notches tonight and the damn gap is bigger! But I figured out what happened so I have to pull the trim off again and sand the frame down more. The 2x4 frame is causing the trim to tilt away from the top. I thought it was a little ridge in the top from the tongues I cut off so I sanded that flush... that is what opened the gap more because the trim board is tight on the crown of the frame.
cash68
Keeper Of Rotor Hill
Milwaukee, WI
Same. I've found that going to the gym 3-4x a week has helped immensely, and I used to have prescriptions to extended release adderal, but I hated the side effects (cold sweaty feet) and if I took it past ~2pm, I wouldn't be able to sleep at all. Now I self medicate with herb, which generally just chills me the hell out and makes me calmer/easier to actually sit still/go to sleep.
I think I'd honestly work better if the rotation of the earth slowed so that one day was maybe 35 hours long, instead of 24. Wake up, go to work 8 hours, get home at 6pm, do projects until 2-3am, then somehow be able to sleep 10 hours and do it again the next day.
BoilermakerFan
Yeah, that would be cool, but then The Man would make us work 12-16 hours a day...
BoilermakerFan
Well, today was busy day at work and I was away from my computer most of the day.
Here is the side trim after I filed it down:
And the pics showing how much I was able to close the fit...
The gaps are intentional so it will be easy to remove just the side trim to change out sub-bases in the T-Track.
But from the pic a few posts above you can see the gap widened. Pissed me off, but I figured out the frame is crowned so the trim has to come off again so I can sand the front frame down.
After that realization I decided to put a coat of Dark Walnut on the top to see how the epoxy fill works and looks with the oil:
It's not bad, but this will all be sanded off again as I go to finer grit until I get to 220. I'm going to use the Black Walnut which is the darkest oil on just the epoxy filler before the next coat of Dark. Most of the dark gets sanded off to pop just the grain, then it will be several coats Medium Walnut and the trim won't get the Dark, just the Medium so it will look lighter for a little contrast.
I also decided I will mix up more epoxy and sawdust and I will fill all the gaps on the top.
BoilermakerFan
My buddy is officially moving to Holland, MI. He was given an offer he couldn't refuse from his employer. He's also a customer of mine so at least I can go visit him on official company business, but it still *****.
The only good news out of it is that he is going to give me a lot more plywood to get it out of his shop. He has a 4x8 trailer and I'm probably going to head up there this afternoon to pick it up since it's going to rain all day tomorrow.
Then I'll load up his trailer with all the shelving and bring everything back to him.
bj383ss
TX
BMF it pains me to see you having trouble with the gaps on your worktop bench. It is probably too late to mention now but a Jack plane would have leveled out the top much easier and faster than trying to sand it flat.
The grain is looking fantastic on the top by the way.
Bret
BoilermakerFan
Thanks Bret. The top is pretty much level now. I poured the Danish oil on it in a few puddles to see what it would do and it spread evenly, versus running in one direction or pooling.
I made the gap worse when I thought I was making it better. There was a little bit of the tongue protruding from that end so I sanded it flush. So that edge is now square, but the salvaged 2x4 frame is where the problem is. I just have to sand it down and the trim will pull in tight. If it was the back edge trim I would just fill it with the epoxy/sawdust mix and be done with it. However, it's the front trim and it's on the side that will be my primary work side since the chest of drawers will hang from the LH side. My office chair will tuck under the RH side and that's the side. So, I'll make it right. I have way too much time invested in the bench to take a shortcut or half-*** it now.
The belt sander did a decent job taking down the top to match up to the trim, the center was just high because it's the center and was hard to keep the belt sander positioned and moving. Plus I would much rather have it be high than low. ;)
I don't have a jack plane, I used to use them in middle school shop class, but TBH, I think they're kind of a PITA to set up. I love my Japanese pull saws and chisels, but I just never got in to hand planes. I thought about setting up a leveling frame to use the router, but that was more work and dust than I wanted to deal with.
The grain and finish looked much better today so I may do 2 or 3 coats of Dark Walnut before switching to Medium Walnut. I did notice today that the edges where the boards meet have raised up a bit again, so I'm glad I put the oil on. I'll probably get a chance to get back to the bench tomorrow night. Today I had to take care of the leaves in the yard again and clean out my gutters on the house because it's going to be raining all day tomorrow.
Tomorrow during the day I'm painting all the grey pieces of the table and chairs for the kitchen. I actually got a few pieces painted with their first coat tonight. I think tomorrow morning I am going to just paint the areas were the pieces fit together. Then once that is dry I can assemble the frames in the afternoon without their wood tops or seats. I think that will actually make it easier to paint everything since the frames will support themselves and I can put all the bottoms of the legs/frames on the painters triangles to keep them up off the drop cloth.
BoilermakerFan
Well, no QGT today at all.
Instead, wifey wanted me to do this:
First coat of paint is on most of the framing of the IKEA table and chairs we bought about a month ago in Cincy. I need to get another coat under the areas were the hinges mount on the extension legs from the first pic and on the main table frame. Then I can attach them to the main table frame and flip the whole thing over for paint the rest of the first coat on the frame. After the second coat I will decide if it needs a third coat.
Then at 7pm I ran over to a buddy's place to help him put on a couple of body panels on his mid-70s Vette project. Got home about quarter till 9m and started working on the NASP Genesis bows.
I brought home 12 bows this weekend since it was easier to tie on the nocks than I thought it would be. One bow actually had a proper nock in the proper location so I only had to setup and tie on nocks on 11 bows:
Eight bows last weekend and twelve this weekend. So that's 20 out of 24 bows the school has for the team/club. I couldn't find the other 4 bows or I would have brought them home too and gotten everything done.
And yesterday I didn't get to my buddy's place to pick up the plywood. :( I had to blow leaves out of the yard, bag them, and clean out the gutters yesterday because we were supposed to get rain all day today. Since rain was the forecast, I also didn't plan to go up today... Well, it rained a bit in the morning then didn't rain the rest of the day. Of course, if I did decide to drive the 75 minutes one-way to his place, it would have poured rain all the way home and kept raining while I unloaded the trailer. Plus there is no way for me to back the trailer into the garage either. The garage is too full and my camper is blocking the turn in the driveway as well. So I would have to carry each board about 60 feet from the driveway to the garage. Oh well.
This week we have things going on everyday in the evenings too, so tomorrow at lunch I am going to try to get the garage blown out again to get rid of some sawdust and move a few things around to make room for the plywood. The Gravely 2-wheeled tractor and Mantis tiller are getting their fuel tanks drained, then they'll be chained to the garage out back and covered with tarps until the walls, the last part of the attic storage, and ceiling are finished. I haven't decided if I'll add fold-up attic stairs at the back of the garage or just put in an access hatch to get into the back part of the attic. The front part has the big 48"x52" opening with the rafter mounted chain hoist already.
BoilermakerFan
I haven't been on GJ much the past week and a half. A week ago Tuesday my wife's back went out. A visit to her chiropractor, an orthopedic urgent care, and a visit to the ER that Tuesday night summed up that day. Then my son and I were out over the weekend for a class field trip. This past Monday the ortho doctor reviewed her MRI from the ER visit and she could clearly see TWO bulging discs. The ER said there was nothing wrong and treated my wife like an opioid junkie. To say that we are pissed is an understatement.
So far the orthopedic doctor is treating it with PT and my wife has seen a nice improvement so we're hoping to avoid a surgery... But I also haven't been able to do any of my projects since I have been having to take care of everything in the house and help her as much as I can. Picked up my daughter from college on Tuesday and I have to drive her back to Purdue on Sunday morning so that pretty much kills this weekend too. Oh well...
