Joshua_Russo
Re: What did you do "IN" your garage today?
Replaced my transmission breathers, along with doing some touch-up on my drive shafts and replacing the transmission fill tube O-ring. Little things in my punch list to put the transmission back in the truck and test the rebuild.
Last pic shows the transmission fill tube temporary installed to show how the breather lines run. The transmission is engineered to operate under water, so they designed a way to deal with fast temp/pressure changes and located the breather outlet in a nice high spot. I imagine folks who install snorkels on these things for extreme water fording also relocate these breather outlets even higher.
The punch list is also so I don't forget something stupid like replacing the oil filter and putting oil back in the engine (or the transfer case) etc.
Sent from my VS988 using Tapatalk
I think it must have been a family of 8.
