No it's the opposite the CR-V impacts have thicker walls. It's very evident in the smaller sizes the cr-mo neck down where the CR-V just have a chamfer at the end
The taped design is stylistic and specific to your particular brand or whats in your tool box.
Generally speaking, CRO-MO impact sockets will have a thicker wall than comparable design CR-V impact socket wall thicknesses.
You're right I just checked some sets I have and while the smaller sizes give the impression they are thicker it's pretty obvious on the big ones the cr-mo is thicker.
I think you can say that regardless of alloy, cheaper sockets have the tapered end. Even the HF deep Cr Molys are tapered in the small sizes, rather than necked down. CrV is harder so it is good in a non impact application and allows thinner walls but when you beat on a socket (impact), the less brittle CrMoly are less likely to crack.The taped design is stylistic and specific to your particular brand or whats in your tool box.
CR-V is more brittle than Cr-Mo. Cr-V is more likely to crack when used with an impact wrench.
I have a couple of sets of Taiwan industrial brand sockets,
The cr-v ones are SAE and are thick walled with the o-ring groove on the bottom. Some people call these Japanese style. They stand up really well better than my Proto or Snap-on.
The metric set is cr-m and they are thinner probably similar to a Sunex. Don't use them as much but seem to wear well. For working on cars I would recommend the Sunex type
Just for my info., who makes a necked down CR V impact? Thanks. Virtually all the high end brands that I have checked, use Cr Moly for impacts. Even lowly HF uses Cr Moly for their more expensive impacts and Cr V for their cheaper ones. Harder steels wear less but the trade off is they are more brittle so in shock situations (impacts) they might have to make CrV thicker to compensate. Dunno. This debate is endless. I wish somebody with technical expertise in tool manufacturing would chime in.This is not strictly true on cr-v being more likely crack as it all down to grade of cr-v used and precise tempering which is totally different to that of chromed cr-v sockets.
I got cr-v sockets close to 3 decade old and none cracked and wear is slower over current too soft cr-mo which wallow out easily in hard work with hard hiting air impacts, cr-mo become more popular purely as easier manufacture to impact spec .
Best impacts I got are cr-v and nice design with proper stepped down necks on top for small sizes and bottom on bigger plus have groove at bottom aid pulling socket on hog ring or holds o ring for pin retainer application and wall thickness sensible .
Lot of the popular ones are pretty much manufacture ease over proper made . I don't buy the ease of manufacture design taper nose type or ones with no step down at drive end as too bulky and don't work in recessed areas on long sockets, try avoid cr-mo too as current crop of cr-mo just too damn soft .
^ skips a lot of sizes but proper design, they taiwan tony ?
When it comes to swivel ball impacts I like my old MAC best, not tried any Taiwan on those yet .
I also have a set by Mac however im looking at getting the below set by Genius;
https://www.ebay.co.uk/itm/331342066648
Not bad for less than £70 i reckon.
I realize that the CR-V vs CR-M debate will rage on forever and that there are differences beyond just the type of metal.
Does anyone have a Capri , Sunex, or similar CR-M 1 1/16" impact socket in 1/2" drive that they could measure ? Or a CR-V impact in that size from a brand other than Tekton?
If I have a couple measurements I can just compare.
Thanks,
Seth
Thanks,
Seth
