Beags86
northern IL
Added a shelf for my radio, phone, and general stuff while I'm in there.
NewShockerGuy
Northern Virginia / DC
Finally putting my truck back together. It's been in the garage since like January...lol TOO long.
Should have the rest of it put together and be able to drive it tomorrow.
w00t w00t.
-Nigel
SgtHawkUSMC
US
My package arrived today with my replacement casters for my
Car dollies. The original units where small and hard
They made moving my Camaro very difficult.
These new casters are 4” and rates and 300lb ea 4800lb ttl.
Great price too $10. Each !!
Now the car moves nice and smooth with now too much
Effort.
So tempting... Seems cheap at $10 each until you remember you have 16 of the things. Or 32 as in my case.
IMG_20160618_214322 by Dave H, on Flickr
20170924_135307 by Dave H, on Flickr
C_F
Utah...SNOW BLOWS!
Those new blue dolly wheels look great!
w00t w00t.
-Nigel
Looks good! :beer:
BTW, what are the little "ears" poking out of either side of your hood? I apologize if you explained it before & I missed it.
niget2002
Josephine, TX
Got my Quadcopter rebuilt. New electronics and new 3d printed spacers for the frame.
Sent from my VS987 using Tapatalk
Not quite in MY garage; had new shoes put on the"new" T-bird. Put air in the spare doughnut tire.
Yesterday replaced the hood support rods.
Other than that just put stuff away...
ambenz
NW Chicago Suburbs
I finally got out to the garage after a few plumbing issues with my basement laundry tub.
I do not like plumbing, no sir!
So to relax, I usually detail my Mustang but it is in the shop.
So I detailed our 2008 Ranger, it turned 10 years old this year and I am close to 35,000 miles on the OD.
She is still looking and driving like new.
Had to redo the brakes and all new fluids when she turned 8.
She will need tires in the near future too...
https://scontent-ort2-1.**.fbcdn.net/v/t1.0-9/29342213_2175447435815123_7015854834934874112_o.jpg?oh=a266980dd54e6d1cc920ec3f61339b7d&oe=5B02BAEE
Went to the Tavern afterward and had their beer battered Fish Sandwich, MAN, that was tasty!
https://scontent-ort2-1.**.fbcdn.net/v/t1.0-9/29249617_2174994529193747_3397492007864631296_o.jpg?oh=3979a7d02adda58c2a604eb8d549ed2e&oe=5B3053F0
Couple of smokers outside thought my Ranger was a sweet ride....I think I'll keep her.
isb cornbinder
I brought my new-to-me Haulmark cargo trailer home today. I used the front hitch on my Ram 2500 to park the trailer next to my shop.
I will change the lighting on the trailer to LED. The license plate bracket looks terrible and it will be changed.
OccupantRJ
Eastern North Carolina
Shop day today. Son and I will be hanging out in the shop all day. I will be doing paint prep work on my band saw restore, and he will be cabinet blasting parts on his CNC mill restoration. A guy is supposed to look at a vertical mill my son has in my shop for sale, and I hope the guy takes it, as I could use the room right now.
Ben Buck
S. W. Ohio
I forgot to post pictures of my led upgrades, changing the 8 footers out.
I have 14 to do, 6 so far
chrislehr
Portland, OR
Neighbor had some trees cut down so i snagged some burly and crotchy pieces. One is spalted maple and may be too far gone. The other is ash and will need an insane amount of drying time since its so dense.
7D2Nova
Working on the car this weekend! Currently in the process of doing a turbo LS swap. Hope to have the ol girl running by summer!
Plastikosmd
Cut new dozer axles and relief cuts, old ones are closer in pic. Someone built up with weld and appears to have used a bench grinder to turn(many flat spots)
Pressed in the new oilite bushing that I bored, turned and cut a spiral helix in
EOC_Jason
Bentonville, AR
Went to store for some groceries and also peat moss...
Pulled weeds out of one raised garden bed, mixed in some peat moss, and planted my onion sets... Hopefully it will be fluffy enough now for the bulbs to grow a decent size. I think last year my soil was too dense / compact...
Depending on weather tomorrow I might try to plant my potatoes if it's not raining...
CoryDH
VA
Installed a Tripp Lite 15amp breaker surge protector on the workbench and routed that up to the 20 amp outlet. Just needed more plugs. Prepping for 220 install for welder soon.
Sent from my LG-TP450 using Tapatalk
majerus
St. Louis Missouri
Replaced my Nema 6-50 with the correct nema 6-30, and installed a new heater.
How much it costs to run. (Listed as Porter Cable). 45 cents an hour.
In watts..
Not a lot; put some stuff away, relabeled a set of 64 aluminum parts bins as some of the labels had gone missing, so I replaced with taller labels that would not fall out so easy.
The missing bins are out for a stalled project
FANTM58
Brighton, Co
Today I started to install my lift.
First I had to lay out where my radiant heat tubes were in the slab.
Then lay out the placement...ETC
when it came time to anchor it, I had every size but “ except the dame 3/4”
So a trip to HD and it was secured..
It all went pretty good, not quite finished, I have a few hydraulic and cable
Runs to finish, and then the power connection.
I thought I was shorted my cables and hydraulic lines. And was about to contact
The supplier, then looked inside one of my main uprights
That was stacked upside down, they were hidden in there !
The finish and the quality on this lift is great !
Copymutt
Colorado
Replaced sparkler plugs and plug boots on the EcoBoost today. Broke every one of the six locks on the coil on plug connectors. Garbage plastic one time factory use.
Jim
kaymccampbell
Upstate New York
Made and put up a rack for turning tools out of scrap poplar. Made an inertial sander head from an angle driver and an unused hammer handle that's been taking up toolbox space. Cleaned up.
Outlaw, nice bins!
malbojah
Cape Cod, MA
I started emptying out what I've used as a garage / shed for over a decade and the last storm was nothing but wet snow and took a whopping 6" of the stuff to twist it into a pretzel. Already have a storage container to hold the motorcycles (surprisingly no damage), tool box, tire machine, bike lift, etc
bulwnkle
Grabbed my rivet gun so I could reattach the door to my mailbox. The force of the snow coming off the plows was more than it could handle, they aren't made like they used to be. I'm thinking about making my own box this year out it some plate.
Sent from my SAMSUNG-SM-G930A using Tapatalk
LS6 Tommy
Northern NJ
It's a hardware device in my pannel. Have had it for a few years it's great. Called energy curb.
https://www.amazon.com/gp/aw/d/B015...nergy+curb&dpPl=1&dpID=51RDlLDRTJL&ref=plSrch
That looks cool, but IDK if I could justify $400.00 + installation time just to record what each circuit uses and have the ability to turn stuff on and off remotely. An electric bill lists total usage for free and 2 minutes with an ammeter tells me individual circuit usage. I turn off everything not in use when I leave the house and can't envision a reason to turn something on when I'm not there.
Tommy
DTE
North Carolina
I helped my son pull the transmission out of a old Dodge for a rebuild.
majerus
St. Louis Missouri
Tommy
I had to buy two of them as well to monitor every circuit. When I bought this I couldn't really figure out why my electric bill jumped from 1200Kwh a month to over almost 2k. In addition it saved my *** on a shady ac repair company kinda interesting read.
https://www.yelp.com/biz/tiger-plum...popup&utm_medium=copy_link&utm_source=(direct)
Also helps to show that an electric car really doesnt hurt your electric bill that much.
https://imgur.com/a/ShRF3
NUTTSGT
Northern Central Ohio
Changed the oil and rotated the tires on my F250. Getting ready to replace the plastic cap on the tail gate next.
Also unloaded my "free" tool box.
