...... What I really should do is scrap the thing and forget about it.
I have one of those production drills. I made a stand for it. It now resembles a regular drill.[emoji106]
[emoji481]
I could always remove a head or two, the table adjusts up and down.
More USELESS PROJECTS that I will use once
I think the mud is going to be bad this weekend, we are supposed to get rain, couple that with melting snow and warmer temps and you have mud.
I do feel better about getting things moved out of the shop, it was really nice to be able to walk in and see the other end of the shop for a change. Tomorrow morning, I have help for a while and will clear out the office. I want to attempt to lift the big drill press, not sure if my forklift can do it or not. I know the hydraulics will pick the weight, but I don't have any counterweight, so the machine may be too tippy and that drill press is fairly top heavy.
Been chilly here as well, but I have been on the jobsite working through some erosion control issues. The shop has taken the back burner again, the office needs to be finished, and my car decided that it did not want one of the cam seals to hold oil anymore. All fun stuff!
The amount of grounding they do for the sites is amazing, especially when you consider if lighting decides to strike, it doesn't care how much grounding you do!
I have only messed with my back once so far this year and I knew it was going to happen, luckily I got over it pretty quick.
I will be at the shop today and should be able to get a few things done. The new burb is the real reason to go there, I just want to get the mirrors swapped out and maybe the stereo if there is time. We will see, looks like I won't even be there until 3PM, but I am at the mercy of my cousin, he is dropping me off so I can drive it back.
They do a ring for standard towers, the AM broadcast towers usually have a large mesh, but that is for more than just lightning. AM towers, the entire tower is the antenna and if you touch it while grounded, you get burned.
That's the first thing that crossed my mind as well.
I did not get any today, I will tomorrow. I am trying to figure out a license plate now. I can get these:
DZLBURB
DSLBURB
TWERGUY - Twerking Guy? OH... Tower Guy... sorry
ITSDEZL
Not sure what I want, but I am sure there are better ones out there.
