Fretters
I think there are less collectors as well, with smaller collections in general.
Definitely. Nice catch with those two Record's.
I just finished restoring and unsticking a Wilton 1750 a week or so ago.
https://www.garagejournal.com/forum/showthread.php?t=386890
I checked out your build, nice work!
I'm not sure where to start with this one as I don't want to beat on it like a heathen. The PO mentioned that he "broke" it, so I don't think it's stuck because of rust.
Anyone have a tip for removing the end cap without messing it up?
View media item 82145
Nobody commented on Z3K3Y's unusual looking Wilton, so I was "bumping" it to see if anyone had seen one like this. He states the jaws are 2.5" which would suggest a baby or "toddler" Wilton, but it looks....I don't know, weird?
click link for his pics
https://www.garagejournal.com/forum/showpost.php?p=7117285&postcount=63136
Couldn't pass up this Oswego 26 when it literally threw itself at me for $30. Six inch jaws, 160 pounds. Don't think you see these too often.
That's less than 19 cents per pound for a 160 pound vise in seemingly good condition aside from a slight handle bend. Looks like maybe a repaired or homemade swivel lock wrench also, but I'd have to say you **** anyway.
Getting it unstuck is you first order of business. Having the cap off could help that. Catch 22?
Get the screw out and see if you can get maybe a broom stick through to knock the cap out?
Once that is out of the way, you may be able to get the nut out of the end then get a gear puller on the shoulders of the static, and the screw on a slug on the slide.
I suspect the PO has bent the slide and its wedged in place... Once you get it moving it should fall out...
Take the three screws off the c clip holding the screw in. Then unscrew it. You should be able to then drive a long punch through it to remove the cap.
Mc Ad: I agree to take out main screw first by removing the three screws and horseshoe shaped holder and it should just screw out. Then you should be able to get about a half inch wood dowell in thru vise nut to hit out the dust cover so you’ll have a better view of the insides. I’d round off the end of the dowel theat is pushing the dust cover out especially if it’s needing more than a tap to remove it.
Here's one that looks like it might make a good showing.---Kind of unusual configuration.---I'd like to jump on and take a little ride, but after that last one I'm a little gun-shy.---Oh but it's tempting.
https://www.ebay.com/itm/Vintage-Pr...e=STRK:MEBIDX:IT&_trksid=p2055119.m1438.l2649
Hey fellas,
I recently acquired this nice Wilton bullet vise, but I can't identify its actual model.
It's a 4.5'' jaw, date code is 7-53 and on the static body the stamp *appears* to say "9450"; though it's admittedly hard to read. However, on the dynamic jaw it says "8450". The vise is in quite good condition, but does need refreshed.
I'm hoping someone's knowledge of these vises might help me figure out if I have a 9450 or a 8450. Also hoping that someone may be able to tell me the difference between the two as I really can't find much on the differences.
Thanks fellas!
New guy to the forum here. I recently picked up a C.Parker no. 49 vise with 4” jaws. I have done some reading about them but cannot seem to find any info about the No. 49 model. Can anyone help me with this. It is going into my little Blacksmith shop and put to work. It works very smoothly still and looks to have had new faces put on the jaws at some point. It weighs over 40lbs and will be put back into service soon.
Great site here!
Mayer I am not a Wilton expert but I believe that the model number is 9450 and it is normal for the dynamic jaw to be stamped with 8450. In general the 9000 series normally seem to have the dynamic jaws stamp of 8000 (eg 9350 -8350, 9400-8400, 9450-8450, etc.) Here are some examples
https://www.garagejournal.com/forum/showthread.php?t=94265&page=3
https://www.garagejournal.com/forum/showthread.php?p=1393865#post1393865
A nice addition to my shop for a hundred year old tool.
MC,
As Outlaw , AngryBeaver and Drives have stated the proper and normal procedure to remove the cap is to remove the main screw first and then use some kind long wood bunch (dowell) that will fit through main nut to punch the cap off.
However if like Outlaw mentioned you have a catch 22 situation, in other words if for whatever reason (and off hand I can not think what that would be) you can not remove the main screw first (ie it is completely seized and will not budge) , then you might want to weld a small handle piece (something like a Screw Eye Ring) in the center of the cap and use it to pull the cap out.
The cap is a lot thicker than you might think (from memory I think something like 2 mm ~ 1/16") and when it is out you can cut the welded handle and gently grind and smooth the spot.
Another similar idea might be to drill a small hole in the center of the cap and use a hook through the hole to pull the cap out. You can then weld the small hole to plug it and grind and smooth the spot. Honestly if you are planning on painting the vise and the cap, even plugging the small hole with J-B weld and sanding will work!
Obviously these are NOT the preferred and normal method but rather are last resort methods.
The 9450 and 8450 are casting numbers, not model numbers. The model number is 450S because it has a swivel base, a stationary base would be a 450N. Earliest Wilton's up to around 1945 were single digit model numbers, 3, 4, 5,. Then around 1945 they became 2 digit numbers, 20, 25, 30, 35, 40, 45, 50 still with a S or N suffix for the base. This may have been because Wilton added 1/2" increment vises. Then around 1950 Wilton started making the heavier duty 3 digit series in the 3" and up vises, still using the s or N suffix. For a time they were selling the old regular duty and heavy duty vises at the same time. The model 20 baby bullet never changed to a 3 digit number, the model 25 "toddler" stayed 2 digit for a while too.
Thanks for the replies everyone. I probably wasn't clear, but yes the handle won't move at all and the PO already removed the ring. Since I just purchased a cheap welder, I'll take the advice to use it to weld a small bolt to the cover to pry it off. I'll update soon.
View media item 82172
First thing I'd personally try would be tapping that handle with a mallet, anti-clockwise,to see if you can get any movement whatsoever from it.
mc: Here's a cutaway view of a bullet so that you can have an idea of what might be going on inside.
It looks like the PO already spent some time smacking it with a hammer and I haven't been able to get the handle to budge.
My attempt to weld a bolt on today failed because the auto darkening helmet doesn't seem to be working. I'm going to purchase a decent helmet later this week.
Here's the $25 welder with the helmet and vice that were thrown in with the deal:
View media item 82177
Bluebolt Are you sure about this? I think 450 N and 450 S were later models and had parts numbers 101162-101163 on the jaws. And in the vise spread sheet there are separate entries for 9450 and 450 N/S.
Kolive I have also attached a photo of A Parker 5 (4 3/4" 80#) which belongs to one of my buddies and which is closer in age and model to your 49. You can see the same jaw insert configuration as well as collar as in the other photos.
SRX The entire vise was first nickel plated, then powder coated and finally baked.gman,
What is the type of paint used on the black CP?
made in china wilton junior vise.
https://www.ebay.com/itm/Wilton-632...067164&hash=item4d5c6840b6:g:X2EAAOSwZ8ZXBfs3
That's a Wilton SBV100 and I have a table clamp swivel assembly for this vise if anyone is interested. I took the chance a baby bullet would fit on it but was wrong. Measurements available upon request.
Is this in reference to that badass Chas Parker vise on the previous page? Damn it's a beaut.
gman007...I think that Bluebolt is correct.
I too, thought that 9450 was a model #, as I own one. But, after doing some research, I couldn't find any documentation other than models# 450N and 450S since 1950.
Check out the attached 1950 catalog page for reference.
