Kitchen Sink Suggestions
Colin Len
Long Beach CA
Stupid question on sink size
I see they sell 33x18 and 32x18
They also sell 33x22 and 32x22
Are these rough openings or how can I measure my current sink to order the right size sink?
The depth would be nice to have a 9" over an 8", just some minor plumbing work underneath right?
I don't think cut outs are standardized in size. With both of my sinks (old and new replacement) the 33x22 dimension was the exterior dims of the sink itself as seen above the counter. Cut out sizes for each were different too, but close. The prior installer had done a terrible job cutting out the counter for the old sink, but they cut it just big enough to drop in the sink (which is significantly smaller than the size the instructions called for). I had to do a little trimming to get the new one to fit but it wasn't bad.
If you can find the make/model of your old sink you may be able to look up the installation instructions online to find the cut out size.
D
D45
NW INDIANA
I might try looking under the sink today, to see if I can find anything regarding a make or model
I am thinking it is a standard sized 33x22
I think a new SS drop in will be my best bet
Mine has some spray in insulation on it, but it looks thin and the sink has served its purpose for 30+ years
I am going to try to find a single hole design........I have a 4 hole now and its too much clutter
I don't even use soap dispenser, but I do have a hand soap bottle on the counter near the sink..........replacing the sink with a soap dispenser is a tough decision
I know some people use the dispenser for dish soap and some use it for hand sand........what technically is the dispenser for? Dish or hand soap??????
ddawg16
S. California
Like Squash said....the farmhouse's are a little lower. We solved that problem by raising the counter top....instead of the standard 36, they are close to 38
We also added a second prep sink. I do my own cabinet....and buy the doors from a local manufacture....I've done doors....it's just not worth my time.
Ok...back to sinks.....we have copper.....ONLY way to go. So f'ing easy to clean. NOTHING sticks to them. Never have to scrub....
On the farmhouse sink, we use a small tub on one side...put the hot soapy water in it and have a small drying rack on the other side. Uses a whole lot less water. If we have something big...just pull the stuff out. One of the best decisions we ever made....
D
D45
NW INDIANA
D
D45
NW INDIANA
Farmhouse style sinks are nice..........but I am NOT modifying my countertops or the cabinets
I just want a new drop in and a new facuet
Jackfre
N CA
If I was you I would modify my counter-tops and cabinets and go with the 36" Kohler Whaitehaven;) Sorry, but i couldn't resist after reading the whole post to find out you want a drop in. This sink is enormous, but we like it a lot. You need the SS grills in the bottom of it though.
D
D45
NW INDIANA
I took advantage of HD special offer, 0% for 18 months and bought a sink and faucet
I wanted a single hole, zero radius, and stainless steel
In a 33x22 size, I narrowed my choices down to 3 sinks
I went with this sink:
https://www.homedepot.com/p/America...in-Kitchen-Sink-Kit-18DB9332211-075/301425843
This sink has a lifetime warranty (others are just 1 year) and this is the only sink that is
IAPMO Certified
Now, I am having some doubts about the sink's drain hole placement........my current sink has the drains in the center of the sink bowls. It seems like all the newer high end sinks, the drains are towards the rear
I understand that I will have to completely redo most of the plumbing underneath, but will the rear positioned drains create major issues for me?
stainless-steel-american-standard-drop-in-kitchen-sinks-18db9332211-075-64_1000_zpsmiqrg9g8.jpg
I like that the garbage disposal will be tucked away closer to the wall
ddurrett896
VA
I went with a Kohler self trimming farm house sink - single bowl. Fits a standard base cabinet with upper drawer deleted.
rburke65
Canfield, Ohio
A few years ago, we went with the Blanco sink...don't know the name of the color, but a granite color. No issues...and yes one has to clean the sink ever now and then. And yes, if you leave th dirty dishes in the sink you will be able to see them...dah! It's a sink...not storage. Was taught to wash, dry, and put away the dishes after use.
niget2002
Josephine, TX
We just installed a stainless 2-bowl sink, but it's an offset where one bowl is larger than the second. The drains being towards the back does require re-plumbing underneath, but it provides more room near the doors for putting stuff. The new sink is also deeper than the old. The center divider doesn't go all the way to the top, so my larger cutting boards can fit in the sink and get washed without water getting all over the place.
My reason for having two sinks is that I fill the big side with soapy water and then rinse in the smaller sink.
We do use the soap dispenser. Ours, the top part lifts out of the container, so we can simply refill the container with a funnel.
Our disposal is one of the Insinkerator noise-isolated ones. I've had these in the last 3 houses I've owned and love them. Super quiet.
D
D45
NW INDIANA
Next weekend I will start gutting the old sink and setup out
I need to caulk where the countertop meets the backsplash this weekend
yeldogt
IAPMO Certified
Are you going to like those sharp flange corners when used as a top mount/ drop in? Also -- the sharp interior corners are hard to clean. franke was the big innovator with the under mount commercial look SS with slight radius corners .... they now make a line in China w larger radius corners .. but, the USA line w/ tight corners is still the best SS IMO. What i always use when going SS
I have white Kohler drop in cast iron at my beach house and love them.
It's all personal preference .. but I'm not sure about the way that sink flashes to the counter. Am I missing something ?
kbs2244
One thing to double or triple check is the height of the drain in the wall.
A too deep sink bowl may not drain.
D
D45
NW INDIANA
The drain into the wall is pretty low inside the cabinet
Unfortunately, I will be removing it all where is goes down into the basement.....the PO has it coming out of the wall with no straight run. There are two 45 degree pieces connected together before going into the trap. It is very odd, but it does drain good
All I have to do is go into the basement and cut off the 90 where it runs up into the wall behind the cabinet and pull the vertical pipe down. Its an easy fix so I know its done correctly
D
D45
NW INDIANA
Sink is in, love the deeper dual bowls and the clean look of the single hole
The new disposal is very quiet compared to the old one
Good project, very pleased with the outcome
Spent a lot of time scraping and removing all the old caulk that was at the back of the countertop, where it met the backsplash...……...put down a new bead of almond silicon and used a cool caulk tool to make a professional finished look
