The Abrasive Blasting Resource Thread
O
OccupantRJ
Eastern North Carolina
A picture of my shop made media regulator. Due to the 90 degree, the media tends to pile at the intersection to be drawn by the air flow coming into the vent hole on top. The smaller tapped hole on the left is for a thumb style set screw if needed. The suction hose is moved in or out to allow or disallow room air to enter the hole as mix air. The fitting on right was an experiment I may pursue at a later date. This is made of 3/4" nominal threaded pipe and a 5/8" automotive heater hose works nicely for an abrasive feed hose.
O
OccupantRJ
If anyone is getting good use out of the information in this thread, please don't be shy and post up what you have done and post up your results, good or bad. This is how everyone gets to learn. Thank you.
dkmc
NYS--Upstate in the corn fields
Interesting design.
Sounds like it works like a carburetor in effect. I'm guessing it tends
to not pack and clog as much as other designs.
O
OccupantRJ
Yep! Griterator!
Not my original idea, it's just that I am cheap and so self reliant that I just had to make my own. It is basically an Empire brand design. I did not include the drain plug at the corner, I just screw it out to drain used grit. Easy to make, cut a pipe into at a 45, rotate to position, weld, drill a couple of holes.
Post #13 in this thread shows an Empire factory unit I got hold of and used on my large cabinet.
930dreamer
Amarillo,TX and Stinnett,TX
I managed to get away this morning for some shop time, so I thought I'd look a bit more at the bigger Cyclo-Blast cabinet. I almost plugged it in to test the recycler motor, light etc. I started by wiping the light lens and saw it has a bunch of water Inside it.
I climbed into the cabinet ( what could possibly it go wrong) and removed the lens, and yes a lot of water In it. The top of the cabinet has a group of four holes on each side, not sure what the reason was yet.
O
OccupantRJ
The holes are most likely the makeup air for the cabinet to enhance air flow through it when the blower is in operation. I would use some sheet filter media over them with some type of retainer, likely what the small center hole is for. May have had a frame around the filters with a screen to keep the filters from sucking into the cabinet.
Looks like someone has been taping them on in the past by the residue left behind.
930dreamer
I think your correct, here's the boxed area inside the cabinet. I need to find a manual for the cabinet, I found a place in CA that's a dealer? and will give them a call.
Searched for other Cyclo-blast pics and found these.
O
OccupantRJ
Couple of pictures. One of my extra air jets, two different styles. The other pic is of my larger cabinet makeup air intake. I have expanded metal with a sheet of filter media on it to prevent flywaste dust escape. Notice how the intake is positioned to wash the glass of dust with the airflow across it.
O
OccupantRJ
After two separate trials of one of the siphon sandblast attachments used with a pressure washer, I have come to the conclusion that it is not worth another trial and will be relegated to the spare parts shelf for project material. Even though the design should be to pull dry sand down the feed tube to the suction head, the sand ends up wet and clogs the feed hose. Save your money.
I think I may try an attachment for the pot sandblaster instead to inject water fed by a pressure washer through a check valve into the sand stream right at the nozzle to create a dustless blaster.
dkmc
Thank you for the results regarding your testing RJ.
Looking forward to your test data from the pressure pot/ pressure washer
combination.
930dreamer
Pick up complete . Stopping at Bricktown for lunch and then a ball game:)
930dreamer
Houston we have a problem;
I drained the oil out of this pump and it has some water in it. I noticed the unloader cover has a dent so here is what I found inside.:(
O
OccupantRJ
It may still work ok. The compressor I normally run was under 5 feet of water for 2 days in a flood. I drained the oil, let the motor dry out for a month, refilled with oil and fired it up. I ran it for about 30 minutes, changed oil and ran it. That was 18 years ago.
Can you see how the unloader is attached to the crankshaft? The broken corner may not affect it's operation. If you get it off, can you take several views of it so we can see it better?
930dreamer
It's unbolted from the crank end now, the plunger still worked.
O
OccupantRJ
Looks like one of the flyweights has broken away on the unloader casting. I assume the parts were not inside the cover? It may still work properly as it is.
O
OccupantRJ
Moving the gray giant to a better spot in the shop tommorow.
We need pictures!
Have you fired it up yet? I am using glass beads in my smaller one and aluminum oxide in the larger, so I will not have to change out media for different jobs. I have them face to face 3 feet apart in a corner to save a bit of space in my shop, with a 1/2" rubber runner mat between them. One is accessible from both front and back, and the other is on wheels to roll out for service, with a guide track to make rolling it back into position easier.
If you have not yet, consider adding an air hose inside or right outside the cabinet door to blow off grit from parts upon removal from the cabinet. It comes in handy.
930dreamer
Relocated from just inside the North overhead door to closer to the West wall. Not the perfect spot but ......
I plugged the cabinet and turned it on, no issues but this port off the motor spews dust like crazy.
I cleaned out the tray and vacuumed the whole area inside.
StinkinEngine
Magnolia, TX
Re: My Abrasive Blaster
I run at 110-120PSI when using filtered play-sand from Home Depot, 80 PSI when using Blasting Media.
Works great, I blast outside so my recovery method is sweep/bend and scoop.:)
O
OccupantRJ
When I was blasting outside, I used a canvas tarp to blast on, then pulled up the corners to get the grit to the middle. A shovel and dust pan got used next to reload the pot. I would use the grit 4 or 5 times before discarding.
O
OccupantRJ
Make sure the bags have no holes in them, or that one is missing. If so, it will let the dust do a pass through and come out the exhaust. I have my exhaust run outside, but there seems to be no dust coming out, judging by the port outside. I will watch it next time my son is blasting.
O
OccupantRJ
I had to have a few bags for one of mine when I first got them. My mother was still living at the time so she made me more filter bags from Duck, available in piece goods stores. Some units use other materials. I made the mistake of washing and drying them to soften them up. Whoops! They shrunk in length by about 6 inches! I still use them to this day. One of mine tore, so at the moment I run without it by capping off the opening with a hose clamp and a piece of the bag. I have new duck to have a new bag made when I can find one of those elusive round tuit days.
O
OccupantRJ
I asked the lady at the store if it was ok for me to blow through a corner of the duck to test for airflow so I would not seem freaky, but she replied that the older seamstresses did this anyway to test for material for cooler dresses.
930dreamer
Media filter bags are about 18-3/4"×18". Some have a rod sewn into the bottom and a metal frame around the top , other ones have the weight on the outside.
I have more cleaning to do here.
