arkracing
Just got the HF 2000lb remote control utility winch. Tentative pass. It's model#92860. I bolted it to a piece of 2x4 to span the door jamb at the back of my garage. I'm going to use it to pull my hobby truck back in to the garage when I need to roll it out for using the garage for other repairs (it's not easy to push the truck back into the garage in the snow.) I hooked it up and ran it, actually sounds nice and smooth. Since this is a pretty light duty application, I expect it will work fine. I will report back on my experience after I tow the truck back in tomorrow.
I've had the 5500lb winch on my car trailer for over 1 year. No problems yet - and I love the 80 feet of heavy cable that it has on it. I just took it back before Christmas before the warr. was up. The reason was not b/c of the winch, it was because of the remote control. The switch never worked right, I was just going to cut it and put a momentary toggle on it, but HF said that would void the entire warranty. No Problem. Brought the the whole thing back(missing the broken remote of course
I guess that is a PASS on the 5500lb winch.
The cheap die grinders are a PASS as well.
I also like the Gravity Feed spray guns for spraying primers etc. You can get them occasionally on sale or with a coupon for $9.99 - cheap enough to throw out when they get totally gummed up.
The heads on the smaller Craftsman ones aren't even hex shaped some of the flats are way bigger than others and they almost never grip the heads and round them out instead. in addition the smaller ones aren't even straight and are curved all over like a french fry from McDonalds.
I have bought some real **** at HF, and bought some other items that are great.
