Mounting light to pole barn siding
AA7483
South Jersey
I know this has been beaten to death but what is the best way to mount a gooseneck on the high rib on the siding?
BSabelhaus
Southern Indiana
Mounting on a rib is not ideal, why not just move it 3 inches to the right or left? I just did this on my new building. You will be the only one who ever knows that it is not centered.
A
AA7483
South Jersey
The location is under a 1 foot gable overhang. It is true that no one will ever know but it'll drive me insane every time I see it.
A
AA7483
South Jersey
Something like this may work but how do I hide the screws?
readhead
Durango, Co.
You didn't say if it is wood or metal framing. But the steps are basically the same. Drill a pilot hole in the high rib. Use a hole saw of the proper size for a round steel box. Install some backing at the correct depth so the box is either flush or slightly proud of the rib. Caulk around the box to seal it to the siding and install the fixture.
For a little nicer look you can use a wood or composite block. Cut out the rib the length of the block. Install screws through the siding from the back into the block. Caulk and paint the block. Install a pancake box on the block and install the fixture.
That is a couple of ways we install lights when we erect metal buildings. One note for those reading this that could make things easier. Before we start sheeting I go through and work out the layout to anticipate these kind of things. Offsetting the first sheet 6" would have solved this problem. Spending a little time doing layout can save a lot of time later. Moving a window 2" can make trimming that window much easier later.
kj_mustang
Harrisonburg, VA
Mount it on a base in between ribs.
9NmBtEN5WwNTsOL2-_qolZfUm_3TLtf0erJNLAmV98pVz5A1Bu_hSOuoxLVYsDm5ABAoShDAuK6SckCM-TkQBzz0mMklCsy4ddI9ZJQRMVNYLX0up3Tvs-W8Fj3d3RWZV1btYqVU49RyKr4pgOwWDTVdWP2kqHTI3KcvsDd-sphLBXPxBYUz6Mq29QR5lRTUN1N0fjuFpihf3thJ0N0MRoJ217Uco5nZddlIMYqMeygACDZ6gRKVuBUXhcM0nVH3oUXNfpVPsJKbXmXrZ4tGO2Hl0hbf9ZPa3kRMokFXOpO08MshXJ1PXr2_3xr_qLRRCjmdihdkHSEHXt-maXM1bR0M5d-AyCttCBg7FuP6qgVd0mM3OKXD5-3BBOK21uZjO7gcD9klghkKVcFzuZLcuqQwOobaVuQGSSv7ttVqao0e1Ae7yJlANilAFo8taLY_GPMwdmnyBZP6K75A6txQ57ZMCJ-W6vU8_EK2gZMha835TO9v1IWmi-8Wy4iDQQJ5dAT--E1jnlWxbbaoB3gQmIisb4aLrGqmWV-0OluO46N004g59Ry4wEW1Qlha3cfnAV-j_rIqT5zfy8T9BG-WS_GsjH7KJTRZF4wm4PBQlC6D-42h5tItDo0ye8hHFJxK90UxTMb6Xpc9zE7x5DxHpHxK9WYo3B42=w534-h947-no
bullnerd
Jersey
Drill a large hole the size of a round box,
Slide box in until enough is sticking out to seal the lamp base,
Tig weld around the box!
Done.
A
AA7483
South Jersey
This would be perfect if the depth was greater. The high rib is 3/4 and this box is a half inch. I guess I could trace it out on to some 1/4 material of some sort to bump it out the difference.
A
AA7483
South Jersey
Wondering where this mount came from
bullnerd
Jersey
OK, how about,
Stop by your local solid surface counter top shop,
Grab some scraps of the right color,
Glue them together and turn them on a wood lathe,
Notch out the back on a table saw,
Done.
cory58
Charlotte, NC
Had the same challenge. The OP in the thread linked below turned me on to a type of composite decking that has a back profile very similar to the standard metal pole barn siding. I bought one board and cut it to make mounting blocks for all of my outside lights. No custom milling, just some caulk to fill in the small gaps. Only limitation is that it does not fit over the big rib. Post #1 show vertical siding and post #7 shows my installation on horizontal siding. Not my best caulk job, but you get the idea.
The product is TimberTech Terrain.
https://www.garagejournal.com/forum/showthread.php?t=320134
Cory
A
AA7483
South Jersey
Well he's is rough draft # 1 using some azek. Traced this flat light mount onto the azek. Cut it out. Then traced the profile of the siding on to azek and cut out the angles with the table saw and the took slices out of the middle and used a die grinder to smooth out middle.
A
AA7483
South Jersey
Should I make the bottom part a little larger than the top and use a router to create a similar profile. Leave the same size and use some bondo to make the 2 pieces seamless? Open to suggestions
readhead
Durango, Co.
If you make the bottom piece a little larger it may not seem as bulky. Do you need the top piece? you could mount a pancake box to the bottom piece and call it a day.
Toomanytools?
Washington
Somewhere buried deep in this forum in an unsearchable thread, I searched for a long time. There is a fellow GJ poster who used auto bondo and made a mold on the siding then poured it in. Turned out great, wish I could locate his post.
A
AA7483
South Jersey
True. That's a good idea however the material is awfully thin in the center. May be a concern?
A
AA7483
South Jersey
Take 2. This one came out a little better. Left some more meat in the center. I'm gonna take this mounting plate back to Depot and get a pancake box. Think it'll be perfect. I'd like to router the top edge but I don't know if there is enough material in the middle part.
A
AA7483
South Jersey
Stupid question but it looks like most goosenecks have a backing plate that is flat, like it wouldn't go over the pancake box. Is this accurate?
readhead
Durango, Co.
Looks good. Ease the edge before you cut the notch. Do you not have the fixtures yet? If not make sure you get something with a canopy that will cover a pancake box.
A
AA7483
South Jersey
That's a good idea about eating the edge before I notch. No I don't have the fixture yet. I'll make sure to get one with a canopy.
A
AA7483
South Jersey
Seems like most of the lights are made to mount directly and not on a junction box. Is this common?
TractorJeff
Elkhorn, WI
The picture in post 14 shows a flat plate.
Isn't a situation where you would mount, then as suggested by another poster run a ****** through to put a junction box inside the wall?
A
AA7483
South Jersey
The attic of my barn will have blown in insulation. If I put the box inside I'll never be able to get to it without compressing the insulation
A
AA7483
South Jersey
Heres what I came up with. Eased the edge of the azek with a router. Ran 2 3/8 lags through the box into blocking on the back side. Now to find a way to mass produce and sell them!
A
AA7483
South Jersey
Had to do some more modifications. My backing plate and cover were the exact size of the pancake so the box was exposed. I had to use a router and take enough depth out of the plate to flush it into the mounting block without taking all of it. Then I had to cut part of the high rib out as the box was hitting it. I was reluctant to do so but it worked out fine. Yes, the grinder got away from me but the plate covered just fine.
