Solar Swimming Pool Heat DIY with Hubitat / Webcore Automation
Denwood
Thunder Bay, Ontario, Canada
I posted this information in my garage thread, but am throwing it here for Google. I figure this information could be used for any solar heating system, including a system to store water for radiant garage heat. In this case, we're talking a pool which is simpler, and does not require crazy reliability either.
My youngest has been bugging us for a pool. Not wanting to endure the time/expense/pain of an in-ground, this bag of water will do for a few years until the kids split. A few days of digging to level a 20ft circle and hauling three yards of masonry sand, and we were good to go.
I managed to get this level to within about a 1/4" or so, apparently important in keeping a bag of water happy....
Once the day or two of prep was done, setting things up was simple. It turns out salt water is not so hard to manage...but the solar heaters and plumbing ended up likely costing more than the pool/filter/chlorinator combination.
First of all, if you buy a pool kit like this, it will come with hoses terminated with 40mm metric threads (all hose ends are female) to connect the pump and sand filter together. I added a salt walter chlorinator (again, from Intex) which uses the same hoses. If you're planning on adding in solar, you'll want to purchase the hose adapters below, and a few extra 40mm hoses as well. Both can be found on Amazon. The hose adapters take the 40mm female hose end to a male 1 1/2" thread so you can use standard ABS or PVC fittings to plumb in your solar. Intex 1 1/2" hose actually uses a 40mm thread..so you'll need the adapters.
You can mickey mouse your own fittings, but keep in mind that a 7000 gallon pool makes a pretty big mess if a fitting fails! I played with a few iterations and just ended up using these adaptors from GAME. My brother has a similar setup and tried cheap Intex solar mats. Not only did they fail, but his pool was drained twice because of this!
You can see the adapter used in the following pics. Why do you see both ABS and PVC? I started using PVC and then realized that the less expensive ABS is more than adequate given the low pressures and temps at play here.
Btw, if you're planning on adding a pool vacuum, this plumbing arrangement works great. The pool vacuum is the blue hose on the right, and standard water intake for the Intex pool on the left. If you leave the pool vacuum head in the pool, there is an added benefit as you can draw cooler water from the pool bottom. This increases solar efficiency...
As far as the solar, it starts here as I take the water output from the chlorinator via the Intex hose adapter to 1 1/2" PVC pipe. The bottom is the supply (cold water), where you see a check valve (spring removed, so flapper only) to prevent water draining from the panels from running through the sand filter backwards when the system is shut down. Warm water from the solar panels enters the pool via the standard Intex return hose on the top pipe.
In the closed position the valve you see forces all water through the solar heaters, and open, it essentially bypasses them.
As far as the solar water heaters, it makes zero sense to make your own when you can purchase 4x20 ft kits like this via Amazon for $167.
Btw, there are heaters out there like the GAME which are complete and utter wastes of money. To heat pools with solar you need square feet...from 50% to 100% of your pool surface area depending on how shaded the pool is. Our pool is pretty much 80% shaded, so 160 square ft of collectors is a bit undersized.
I've done something unconventional and draped these collectors (they are 20 ft long) over the peak of my kitchen roof..which is about 16ft away and 15ft up from the pool. I was thinking air entrapment would be an issue, however it's not proven a problem.
This is the view of the panels on the intake side, looking down. I've made a manifold of sorts so that each side of the 2ft wide panels is now an intake, and far side (previous pic) are where the water exits the panels. The manufacturer has the panels set up so that water enters and exits the same end..with the far end blocked off. This forces a 40ft water path through each panel, which proved far too restrictive for my setup. I've plumbed these basically in a parallel configuration which is what the pros recommend. Having tried both, I'd agree. Flow was terrible when set up as per the manufacturers recommendations. Keep in my mind that I'm using the standard 1600 gph Intex pump that came with the pool I did not want to up a separate solar circuit and motor. Thankfully, the Intex pump has enough head to run water through these panels, once they they were plumbed as a paralel non-cross flow config. (I tried several configurations!)
This is the view just below the kitchen roof where supply and return are plumbed. The black/green bit in the middle of supply is a combination vacuum relief/bleeder valve.
You might think that this valve should go at the highest point of the solar array, however this did not work. Suction (from return water) kept pulling the floating ball contained in this fitting downward off its top seal, allow air into the system while the pump was running. Putting it on the supply side worked far better as the pump pressure now keeps the internal sealing ball properly pushed up against it's top seal. When the pump turns off, the internal check ball drops down and allows air into the system, ensuring all water in the panels can drain back to the pool. This prevents suction in the system from collapsing the panels. A vaccum relief valve is another "feature" that you would (or should!) find in any professionally installed system. With a more powerful pump I likely could have moved this relief/bleed valve higher in the system so it would serve as a high side bleed as well as vacuum relief.
I should mention that I tried a few configurations, and this one works best. Why? Flow to the pool (again using the standard 1600 gph Intex pool pump) is very good..almost as good with solar as without. Also, temperature gain is about 4-5 degrees F on a sunny day, which indicates high efficiency. The goal with solar pool heating is very high flow, and a low temperature differential. This in turn maximises BTU gain to the pool. On one of the early days of use, I calculated about 460 000 BTU gain in one day. This is calculated taking (gallons X temp gain in F X 8.33). Our back yard is completely shaded virtually all day, so solar gain is pretty much via the solar panels only.
Automating the pool pump via SmartThings turned out to be an interesting project. The first thing I had to do is replace the GFCI plug end for the pool pump as cutting power to it requires a manual reset. Not good for automation. The entire system is plugged into a GFCI, so removing the plug end was not a safety issue in this case.
I'm using a GE outdoor power dongle that is controlled by zwave, so therefore ties into the SmartThings hub and automation. I use these units for my outdoor lighting and winter block heaters (for the cars) ... they are very reliable.
Both pool pump/filter system and salt water chlorinator run off the zwave plug above. The chlorinator has it's own digital timer that you can set. When powered on, it just runs for 3hrs (this time works well for this pool, based on water testing for free chlorine), so this device didn't need any further automation.
To automate things I just needed to be able to measure the roof temps, vs water temps. These SmartThings door/window sensors have a built in temperature chip, so work as relatively inexpensive wireless sensors. They use the Zigbee protocol, so require a powered Zigbee device (like a smart plug) reasonably close (15-20 feet) to ensure good signal relay back to the hub. I had one of these floating in a weighted ABS (sealed) pipe but kept losing signal depending on where in the pool it was floating. More on that later. Right now, these SmartThings sensors work well sitting in a small Tupperware container on the roof, and directly in contact with the return/supply pipes, just sitting on plastic zip lock bags, and wrapped in foam to insulate them from outside temps. These sensors all require "calibration" which means checking the temps with something reliable, and entering an offset in SmartThings ( plus or minus) so the sensor is showing the correct temperature.
I found reference to the 1st generation Fibaro door/window sensor (zwave) that has a connection block to allow use of an external temperature probe (DSB1820). The 2nd gen version Fibaro door sensor does not have an external temp probe, however their Universal Binary Sensor does :) This works very well indeed...and is much more accurate than the SmartThings sensor. No calibration required in this case. I've wired in 3 rechargeable AA cells (3.6 volts) to replace the small lithium cell that the sensor uses. The battery carrier was removed from a cheap LED flashlight, and sits with the sensor in the ABS tube (pic below) attached to the pool frame.
This is the wiring used with the external temperature sensor.
The DS18B20 waterproof external sensor is pretty inexpensive on amazon at $4.
stainless-steel-package-a-waterproof-ds18b20-temperature-probe-temperature-sensor.jpg-2.png
This was my floating sensor housing, now re-purposed as a water proof housing for the Fibaro sensor. It returns temps in Fahrenheit to 1 decimal point accuracy. The probe just hangs over the side of the pool sitting 6-8" in the water.
In the SmartThings app, this is what the pool sensors look like on a sunny day:
I added a SmartThings "virtual switch" (you need to do this in the web IDE) so I could turn the pump on and have it ignore the automation code that turns the pump on and off. The code I wrote using WebCore in SmartThings turns off the solar logic if this virtual switch is "on". WebCore is an app you can add to SmartThings that allows you to write pretty complex automation code in any web browser..freeing you from the iOS app. My little apps (called Pistons on the webcore world) are very simple.
This one turns the pool pump on if the roof temps exceed water temps by six degrees F., and turn it off if temps are less.
This bit of code sends a notification to our iOS devices if the pool pump is turned on or off:
Finally, this bit of code turns the pump on or off and pauses/resumes the solar control app if one turns the pump virtual switch on or off. This way the pool pump can be run regadless of the water/roof temps.
This system has been running pretty much unattended for six weeks now, so a success in my book :)
System performance specifications:
1. Pool Pump - Intex SF80110-1 , 0.2 amps , 1600 GPH.
2. Actual (measured) system flow with sand filter and solar array in use: 1028 GPH
3. Max measured BTU = 1028 x 8.33 x 6F = 51 379 BTU/hour
5. System head (max lift height to peak of roof) : 17ft
LS6 Tommy
Northern NJ
Pretty cool setup. Any issues with moisture getting trapped between your roof and the solar collectors?
Tommy
glentre
Gloucester, Virginia
A nice diy solar installation but, IMO, a little complicated and troublesome with the panels on the roof. I installed my own heater 6-7 yrs ago and it has been working without any problems ever since. But, mine is a fan and coil unit in the attic through which the pool water is pumped. It reduces the 130 degree attic temperature down to about 110 degrees and moves that heat to the pool. Heats the 20,000 gal inground pool to 90 and reduces the attic heat load on my HVAC sysetm reducing my power bill. And, it is all automatic, turning on when the attic temp is 2 degrees hotter than the pool and turning off in the evening when the attic temp is 2 degrees cooler than the pool. Set any pool temp you want with the controller. And, all you see are two 2" pvc pipes going up the outside wall of the house. Best part is, other than the pump horsepower used, the heat is free. Downside as with all solar systems is when it's raining or very overcast, you can't pull much heat out of your attic.
There were only a few suppliers of the coils and controls when I installed mine but there appear to be a good selection of sources on line today if anyone is interested.
Glen
D45
NW INDIANA
I wish I had warmer water...….my 27 foot pool rarely, if ever, gets above 74 degrees
A NG heater was an idea...….but they are very expensive for my cheap wallet
yeldogt
Well -- it looks like a fun engineering project ... what did it all cost? I love stuff like that.
The attic systems are also interesting -- if the size of each (pool /attic) are in harmony -- they can pull some BTU's out. I looked into them at one time. Unfortunately -- we always get a week of bad weather (like this week) where there is no sun and we have rain .... they don't work and unless you have excess capacity -- when the sun does come out they don't get the pool back to temp in August.
My largest pool is 45k gallons. I have a 400k BTU gas unit. Solves the problem ..Thankfully NG is cheap. My unit is about 20 years old -- I had to do some major cleaning on it before last season .. and it's fine this year .. but it's rusting away. Putting 2-2.5K in mental pool budget for a new one.
6768rogues
Western NY
My brother spread out a 100' coil of black plastic pipe on his roof and shunted some of the pump water through it. The water came back about 10 degrees warmer than it went in. It took all of about a half hour.
yeldogt
I thought of doing that on my flat roof .... they use them as pre-warmers for DHW in Africa. When I did some research they only work for a small about of water. In many areas the actual temp is only about 130
D
Denwood
Tommy, no issues with the collectors so far. We'll see how they fare after our rather drastic winters here.
Glen, "Solar Attic" makes those attic air exchangers..and they make sense for some installations. I especially like the idea of using waste AC heat to heat pools, but alas, neither would be a good fit in this case. Our yard is completely shaded, so the roof was my only option for solar heat. The only downside I can see of the SolarAttic product is the cost, risk of leakage (you really need to ensure a tray/sensors etc will cut the water off if it sees a leak!!), and fact that they use copper coils..so 4-6 yr life. Not sure if someone is going a titanium/inconel coil for attic heaters, but that's what I would use if given the chance.
Someone needs to do a study on the solar heaters like I used, as they keep the roof temps beneath them at about 85 degrees or so. It would interesting to compare attic temps over our kitchen (it's not a huge attic) with the solar heaters running, vs not. If surface temps on a hot day are 116F, and your roof is covered with solar heaters, essentially you're water cooling your roof surface to 80F or so. It would a fun study to do.
Dr. Dirt, thanks. The install won't win any aesthetic awards but it works. The roof mounted solar heaters are "invisible" from the back yard, and street which adds a plus for the roof top installation in this case.
D45, a 400 000 BTU NG heater would be great, but likely I'd spend more to heat our pool in summer than our house in winter here!! I should actually add a few more panels to get the pool over 80F more often.
Yeldogt, no question gas is the fastest way to pump heat into a pool :) I've been working over the last few yrs to take my 9000 sq/ft business property and home to as close to net zero as possible. To put into perspective, the pool pump amperage bothers me as it needs to run obviously to pump heat in. Having a completely passive system would make me really happy.
What did it cost? (USD)
18 ft Pool kit on sale: $399
Salt water chlorinator: $199
4 bags of salt: $40
PVC and ABS plumbing: aprox $350 (ouch!)
Solar heaters (four 2x20 panels) $334
SmartThings sensors, Fibaro sensor and GE plug ~$120.
Extra 40mm hoses and adapters $55.
So about $1500 all in.
6768rogues, yes, the water comes out of a 1/2" coil at 10F warmer, however at what flow rate? That is the key. I'm running approx 1400 gph so with a 4F difference, you're talking about 46 000 BTU per hour. With 10F gain but say 100 gph from a 1/2" coil at 100ft you're only at 8300 BTU. That would raise my pool about 0.15 degrees F in an hour..not good. To do anything great with coiled hose, I would need at least 160 sq/ft of surface (that's a lot of hose!!), and likely 10 of them run in parallel to equal the $340 of collectors that I purchased. On a hot day here the temp difference from my system will reach 6F, so that's about 70 000 BTU per hour peak.
Btw, commercial evacuated tube heaters obviously produce very high temps, and do this in winter, however they do so at low flow. This is why you don't see them for pools, but in some cases may work very well for hot tubs/spas run over the winter.
I corroborated these findings by using a day of temp gain in the pool, earlier this yr when the pool was colder to make a few calculations. We had an 8F gain on 6900 gallons of water, so about 460 000 BTU. This works out to an average of 57 000 BTU/hour, over about 8 hrs. Our kitchen roof is in shade until about 11:30 am, so 8 hours is about as good as it gets unless we cut a bunch of trees down (not happening!) :) I did learn during this project that a shaded pool requires nearly double the amount of solar collectors to compensate for the loss of solar gain on the pool water itself. We're at least 80% shaded :-(
I'd say with confidence that the DIY collectors are great fun, but likely not worth the materials or effort for the results once you do the math. Sunlight at peak is about 1000 watts/sq meter so to solar heat a pool efficiently, you need to maximise your square footage. 160 sq/ft of collectors for $340 is pretty inexpensive via Amazon.
D
Denwood
Yep, domestic hot water is a different animal. Much lower volumes, but at higher temps. Martin over at greenbuilding journal actually makes a case for PV + heat pump as a better way to heat domestic hot water. It's a good read:
http://www.greenbuildingadvisor.com/blogs/dept/musings/solar-thermal-really-really-dead
D
Denwood
Thanks Matt. I'm by no means a programmer, hence the separation of functions into three "Pistons" in Webcore. It makes programming and indeed debugging a lot easier ;-)
zak77
Monson, MA
Wow, much more involved than mine. I have the 18' intex pool and wanted to up the temp a little, well more like the GF wanted warmer water, so i built plywood box about 2'x3' and ran 1 1/2" abs back and forth then covered it with a piece of plexiglass i had kickin around. I honestly didnt think it'd help at all but it does help somewhat since i can feel warmer water come out. Of course running it when the weather is cool or even when there's no sun on it, will start dropping the temp. It did drop the pressure and volume from the pump slightly but it's still adequate.
38Chevy454
Cincinnati, OH
Great DIY project with some nice results. We just had an in-ground fiberglass pool installed. No heater of any kind, although I did run sufficient electric if I ever need/want to add a heater. Around here the only real need for a heater is to open pool earlier and extend later into fall. Mine is very open with sun all day, it may not ever need a heater, but TBD.
I have thought about a solar heat setup, you have a lot of good ideas and suggestions. Thanks for the details and descriptions.
glentre
Of course, cost is a major consideration in heating a pool but there are others as well. "Build it and they will come" has real meaning in my case and likely with others as well. Before installing our solar system, our pool was always chilly such that the kids and grand kids would go in but not stay very long. The adults would not go in at all. After heating it, the younger ones now want to come more often to our house and they play in the pool all day long. And, the adults now lounge around on their mats with drinks in hand and soak up the sun for hours.
To me, that is worth some bucks!
Glen
yeldogt
DHW: With warm air temps most of the day and cold water -- the roof warmers help to temper the relative small amount of draw into the typical DHW tank. I have a large solar tank -- this is fed from the gas filled collector. The tank is heated to basically as hot as it can be and then mixed as it comes out to the taps. The coil is only to temper the water to the collector ... it's extremely rare for my system to not keep up and require the resistance backup.
Pool: You have done the calculations and understand. I don't have a large area for a collector .. but I remember the max being in the 70k BTU range in ideal conditions. My 400k NG heater will raise my pool around 1 degree per hour -- so the cost and complex nature of the collector I could have did not calculate out.
D
Denwood
Zak, you've got about 6 sq/ft of solar collector, so you're right in that it's not doing much I'm afraid. The good news is that you're already plumbed for a collector, so a few 2x20 or similar would hook right up. My brother scored a used 4x20 Fafco solar bear for $100...a steal as this is a very nice collector. Your 18' pool needs about 60 000 BTU to increase 1 degree F.
38Chevy, I'm glad you found some useful information in the post...it's my attempt to return what I've learned :)
Bargain, I've done some reading on surface heating, and it seems that allowing sunlight to hit the water directly is more effective in capturing heat than using a black solar cover. I believe it's related to longer wavelength energy and absorption vs reflection. That's why solar covers are never black...
Glen, agree 100%!
Yeldodt, gas filled collector? Can you add details...sounds very interesting. It's hard to beat NHG..I just can't get past the green house gas implications.
D
Denwood
Sberry, see post #9. The coiled loops don’t make sense with respect to material cost vs BTU gain. My pool needs a minimum of 160sq/ft of collector. To do that for $340 and do enough parallel plumbed arrays to get 1400 GPH would take many hours of fab and likely cost more to build in the end...
rpcraft
Waco
Just as an aside, I have been looking at getting one of the small Intex above ground units., maybe one for summer as a pool, then one of the smaller spa units for winter. Any advice of cautionary statements?
D
Denwood
Rpcraft, the pool is fine..no issues with the Easy Set frame system. I can't comment on their spas but in general, here is some pool advice:
1. Level the ground by digging only to undisturbed soil and lay down about 1 1/2" of sand. My frame dips down about 1" over about 10ft of circumference, although the overall level is within 1/4".
2. Try and locate the pool where it will get maximum sun. This really will reduce your need for solar heat. Not sure where you live (climate) but 160 sq/ft of solar on an 18" pool that is shaded..is not enough. The pool varies from 73F to 80F, and the younger kids find that pretty cold...particularly if they are on the lean side. Our night temps often dip below 60F here in summer, so heat loss during the night is 2-3F even with the cover on. I'd agree therefore with some of the solar pool calculators that call for solar heater area equal to pool surface area in our climate. For my pool, that's about 260 sq/ft vs the 160 sq/ft that we have currently.
3. Don't buy a cheap solar cover...waste of cash. I bought one and it lasted only six weeks or so. I ended buying a 7 yr warranty solar cover at a local pool supplier for about $120, and it's much thicker (durable) than the cheap ones.
rpcraft
Waco
Yeah, I was looking at no cover aside from keeping trash out and probably going to build a paver patio or something similar near, around, or under it. Have not decided yet and I have a whole new backyard to sculpt. Right now its about 95 to 110 F daily (in Texas) so warming isn't a desire or objective. What I was thinking was having it up during the hot months, then drain it down and during the cool months drain a majority of it into one of the intex heated spas, and then the rest down the drain.
yeldogt
Denwood--They are just the next step in the evacuated tube technology. The cost of all this stuff has really dropped .. in addition the performance of the photocells and pump motors has increased. The hot water systems can be all off the grid -- with only occasional backup needed. Previously the motors and photocells did not equal out so you had to have on the grid circulators. Now as long as the sun is around the pumps can make it all work.
My pool is just too big -- with cheaper NG it's been nice to keep it warm. Looks like it cost me around $200 for July .. it makes for a big bill when you adding the pumps electrics and all the AC running.
I remember back in the early 00's when NG was 4x current prices there were people trying to use heat exchangers to take heat from AC units and adding additional solar panels .. w/o a long season the cost of the equipment take too long to get any payback
D
Denwood
Yeld, I hear you on the bills. We only use AC sporadically over a few weeks due to proximity to Lake Superior. Winter heat is another issue at -30C...
Here is a bit of data (from SmartThings logs) that shows pool temperature loss overnight, and heat gain from today. It also shows the rather short heating window due to tree shading in the am.
We saw about 5.5 F increase to 7000 gallons, so about 320 000 BTU gain.
goingtoarizona
Central Valley California
Excellent write up! Thanks for taking the time to do such a thorough job. I have an above ground pool that came with a small attached (Bestway) solar heater. The fittings and hoses are garbage, but your info on the replacement fittings are helpful. You've also got a bunch of info here I can use to possibly make a solar water heater for my home and laundromat!
Will these solar panels handle standard water pressure of about 60 PSI?
D
Denwood
Goingtoarizona, I’m glad you found some useful info here. My system is only running about 10 psi on the supply side, but I suspect 60psi is beyond the pool heater panel spec. Pool heating is a very different animal vs domestic hot water...however the laundromat is one of those applications where an array of evacuated tube heaters and larger 2 tank system (solar would preheat water in tank 1) would have a decent cost recovery scenario..particularly if you have federal incentives to offset cost.
D
Denwood
I took a few minutes to measure actual flow (with a 2 gallon bucket) with the sand filter and solar array active. Flow is lower than I had guessed, at about 1028 GPH.
1. Pool Pump - Intex SF80110-1 , 2 amps, 110v, 1600 GPH.
3. Max measured BTU (at about 3pm with full sun, 28C day) = 1028 x 8.33 x 6F = 51 379 BTU/hour
D
Denwood
A new season brings another heating season..and a few improvements.
The solar heat worked quite well last year, but two things became apparent by the end of the season:
1. Because the pool is shaded, the suggestion of having the pool surface area equivalent in solar heaters became obvious. The 18 ft pool has a surface area of 240 sq/ft, so I added two more 2'x20' panels this year. The total is now six, to equal 240 square feet.
2. We have cool nights here due to lake effect. Tonight for example, we're dipping down to 7C (45F) and I figured heat loss to the ground must be significant. The pool was losing 7-10F on cooler nights..about 583 000 BTU last year. This year I decided to try 2 inches of polystrene underneath. We'll see how this goes.
Finally, with the two added solar collectors now on a higher portion of our house roof, the Intex pump could not lift the 17ft of so now needed. I measured power use of this pump at only 100 watts, or 1.4 amps. This is in the order of 1/4 HP, and less than the spec sheet of the Intex SF80110-1 pump. I have a 2 speed 1 HP pump coming in which should do the trick, and make pool vacuuming a lot faster too.
I had lots of help this year as the girls were anxious to get swimming!
Our tap water is very cold this time of year, in the order of 45F, so getting in the pool to addresss liner wrinkles during fill is torture. This combination of bits from HD allowed me to fill the pool via the solar system. With reduced flow, the 45F input water was exiting at about 70F, making it much nicer on the feet :) The brass end is a female coupler for a garden hose, the other end is 1.5" pipe thread to attach to my PVC solar plumbing.
By my rough calculations the new pump and 50% increase in solar collector area should result in about 600 000 BTU on a good day...a solid 10F increase. The science project continues..
Falcon67
Merkel, TX
My only comments on those particular pools is that I would not have one without a regular skimmer. On our old 18' Sun Seeker, I adapted a real Hayward pool skimmer to the pool and that made a big difference. For heating, I'd use a separate pump from the big 3/4 HP sand filter I keep on site. Separate controls, separate timer, etc. Of course here, its no big thing for a above ground pool to be 90+F in the summer. You can easy make 8000 gallons of sun tea if you like.
D
Denwood
Chris, for sure our climate here makes solar pool heat a challenge! I hear you on the separate solar install. Power use/efficiency is a priority so i’m trying to size the pump only to solar. That said, I guess I have two pumps now so could use the Intex just for filtering.
If money was no object, i’d use a DC solar pump and directly power it via a few solar panels.
Falcon67
Merkel, TX
Hmm - solar would be a great idea. Just need enough pump to push the head about 8', not a huge amount of volume needed when running all day. We tore down our 18' last year and are starting to miss it. A side project would be a ground level deck with the solar collector on top...
Now you've done it.
Also interested in your base material.
glend123
SE Wisconsin
I didn't read if you were using a solar cover at night at all? we always use one and it really hold in the heat.
By the way, I had a 4 x 20' solar panel like you have about 10 yrs ago. i was never happy with the performance. only raised the temp .5 deg coming out of it. i had it mounted to a rack next to my pool facing south on 45 deg angle. I had a valve to cut the flow or run full speed, never could make it work very well.
toolmiser
La Crosse, WI
A few years ago on Ask This Old House, Richard T adapted an air conditioning unit for a house to help heat the inground pool. Looked like a good idea.
D
Denwood
Chris, the Intex SF80110-1 pump was adequate to about 15 ft of head so worked just fine last year to pump water up to the peak of a one story roof through 4 collectors.
I originally levelled the lawn area by excavating (no fill) until level using a 10ft aluminium channel, pinned at the centre point like a big compass. Then we added an even layer of about 2" of sand. This year we removed most of the sand, and laid in 2" Styrofoam closed cell polystyrene foam. it's taped using tuck tape, and cut to shape using the same "compass" as a guide, using a reciprocating saw. I had 8 sheets of higher density foam (100lb) but filled in the rest using a standard density. Doing it again, I'd use the higher density to reduce heal dents during installation. We just used some scraps as kneel boards etc. Brock White here stocks the DOW Highload 100 which is much denser than the typical HD stuff. Their price was about 25% less then the big box stores too.
Glend, yes..a solar cover for sure. A lot more heat is lost via evaporation than anything else..so a cover is a must. We get about 400 000 BTU per day from the four 2x20' collectors, so should see about 600 000 BTU from the six. At 3 pm or so, the system was moving a measured 1000 gallons per hour, with a difference of about 6F between inlet and outlet. Your target is 2-4 GPM (gallons per minute) per collector to get the best efficiency. Our home force air gas furnace would need to run about 7 hours full on to equal that heat input! It sounds like your pump may have been running far too much volume through the collector. The Intex pump is only drawing 1.4 amps, so about 1/4 HP..and it was pushing about 4 GPM/per each collector with 15ft of rise. That gave a 6F gain between inlet and outlet in full sun. Ironically, if you run less water so the outlet feels "warm" you're actually losing efficiency. It's all about total BTUs.
Toolmiser, in a hot climate where AC is in use...it's 100% a great idea to dump that heat in the pool. We run our AC all of about 10 days per year :-( I was in Ottawa (much warmer climate) last year in a typical higher end subdivision. Everyone had pools, they were all running AC..and most had 400 000 BTU pool heaters. I saw zero solar covers. That is a crazy amount of wasted energy and Co2 generation. Using pool water as a heat dump for AC is much more efficient than air...
Btw, heat gain on a shaded pool is pretty easy to calculate. Gallons of water x heat gain in F x 8.34. Today it was cold (about 60F), windy, and mostly cloudy. We still managed 4F gain from the original four collectors and roof temps hit 110F. 7000 gallons x 4F x 8.34 = 233 520 BTU. The equivalent would be our furnace running full tilt and burning gas for 4 hours.
I won't have the new pump for a few more days, so the 2 new collectors will sit idle until then.
Falcon67
Merkel, TX
As noted, level the ground is the main thing. If you really want to get after it, use pavers under the easy set poles. I did not on our Sun Seeker 18' and after a couple of years we had about a 2" list to the east. Never really an issue. We had no real place to put a cover, so when the pool was running it ran uncovered. When I shut it down, I covered it. The "7 year covers" last one winter here and they are junk. FWIW, we had our 18' up for about 6 years until the liner got so rough I could not vacuum it very well. Then the GFCI tripped one weekend while we were out and between the dirt blown into the pool and some algae, I had to call it quits. Took a knife to it.
When we lived in Houston, we had a big 24' round. Very nice. Long season down there for sure. That one was metal sided and sunk in the ground about 6", with a sloping bottom and a center drain. Very nice setup.
We do have a place for a cover now, so would use one. But I'll look at 16'ers. Just because I'm lazy. And the back yard depth is an issue if we keep it where it can be seen from the living room area.
I run a 3/4 HP large Taeglus sand filter that we've had for many years. I just keep re-furbing it and change the sand about every 10. LOL, even used it on one of those quickie things with the inflated top ring and no frame pools - fun whirlpool that one.
JAYoung
Butte, Montana USA
If the landscape allows it, the best option is to locate the collectors below the pool an allow it to thermo-siphon -- eliminating the cost of pumping all that water.
Insulating the floor of the pool is good, but heat loss also occurs at night from the surface due to black body radiation.
D
Denwood
Jay, because our yard is shaded by trees on the south exposure, roof top heaters were the only option.
Thermo siphoning would work, but for my six collectors, max efficiency is reached at about 4 gallons/minute/per collector. That's 1400 GPH...pretty hard to do passively.
The good news is if you're not going over 13 feet high, the Intex (cheap) 2100 GPH pump only draws 1.4 amps. Sadly the more powerful pump I just installed uses 8 amps...but has zero issues with the 18ft head I have now.
Interesting pump observation. The inexpensive pump I have packaged with the sand filter is the Intex SF-80110-1. It is quiet, moves a lot of water, and only uses 1.4 amps. It also filtered and moved 1028 GPH through my original four collectors with a max height of around 13 feet.
The new 2 speed pump that came today Has no issues pumping to the six collectors (max height higher now at 18 ft) but gulps 8 amps on high speed to do it. On low speed it is moving far less water than the cheap Intex..but is using 4 amps vs the Intex 1.4 amps. Clearly the Intex pump is more efficient.
