IT LIVES!!!
I read the manual and did as you said, and I have arc and a bead and penetration!!!!!!!
Bill
I was running 7018 the way your drawing shows on the right.
Bill
Great, glad to hear you have it figured out!
You don't have to have the foot pedal, but it is helpful. You will need a TIG torch with some kind of push button start, otherwise you can't initiate an arc. I have mine wired into the BUS connector on the front, you have to connect it to two of the pins. I'll post a pic and show you how mine is set up, I still use mine without a pedal occasionally, but you can find them on eBay occasionally for a decent price.
In fact, here is one for $100...
https://www.ebay.com/itm/6-pin-TIG-...l1313.TR12.TRC2.A0.H0.Xlincoln+tig+pedal.TRS0
You'll also need a manual gas valve, they don't have a gas shut off solenoid. You can get torches with a valve on the handle body, or you can simply run one inline with the gas tubing.
It is only good if you have a need for it. You have a little wire welder, this will do all the work you can do in a driveway. There is nothing wrong with this machine but its like the rest of them, sell it in a different Clist area. Youi are not a welding contractor in process piping or working on ship decks which is pretty much what it is for.
No matter how cheap it just becomes a collection, now adding more to it already with no possible return. I been at this a long time, have other machines from and for construction,,,, what I really use is another matter , a small wire welder and a simple DC buzzer. My TIG hasn't been on for 20+ years and I know how to use it. Been 10 years since I used a stick rod bigger than 1/8 and,,,, I do this work all the time.
List that for 600 in Traverse or on the other side of the state and another C to ship it. Good for a farmer in some cases, great for someone owns excavating or real welding company. Be great for an Ironwworking contractor.
Now for the torch.
Why a 17 size (125A) and not bigger? Is most TIG work done below 125A? Are the higher amp too hot to hold in an air cooled? Does a smaller torch get in places better?
Who makes a good torch and lines?
Next will be questions about tungsten and consumables, gas and tank.
I'll be honest Bill, that's not a great welder to learn TIG on. It's designed for pipe welders who need to TIG in a root pass then stick weld the cover passes.
It has no high frequency, no gas solenoid, and no AC.
While it's possible to TIG steel with this machine, it's a steeper learning curve than one with at least HF and a gas solenoid.
Unfortunately a decent TIG rig will set you back around 800-1000.
I lived in the burbs a while. I could take care of everything I needed with a handful of tools. I would have the oil changed and a muffler fixed at a local Pop type mechanic place and fix a brake in the yard when I had to, change a belt or a bulb when needed. Even in a home hobby garage I could get by with a small tool box, maybe small torch and wire welder if I wanted to do that sort of thing.
I wouldn't have all this **** unless I needed it and nothing takes the fun out of it all like making it a financial burden. Tossing a grand at that pos will make it obvious in short order. Take the easy way once in a while, get the little feeder working and learn that. It does "structural " work too. That only means its not a pipe or a skin, doesn't have anything to do with the type of machine.
While there are some specialists that need steel tig most real body work is done small mig. It wouldn't even occur to me to use anything else especially a process as time consuming and expensive as tig and that wouldn't be the machine. Its the reason it sold cheap. As the dr pointed out with a bit more grace than I have is it lacks features a hobby crowd wants and is designed for professionals in a professional environment.
Some aged career guys can use the thing and do it but good chance you cant even see well enough to do that work. Let alone the coordination that comes from constant practice. Best I ever see it were really young and relatively young guys, some only knew that one thing, there are exceptions but again,,,,, career welders for the most part.
That is a good machine,,,, for ship building, refinery construction, power plants. Not for art work, auto body and doddering around in the garage.
Replacing shocks is a good job, good to save some money. You have a torch?
I am not advocating doing without tools you need, quite the opposite. Get what you need and only speculate some, keep the cash in reserve so you can get something when you have to.
That is exactly my point, got tools you can use and don't, why keep shoving more **** in a box especially when it costs more money to collect it all. Already have another stick machine that isn't used. A torch is almost an essential in our part of the world for basic auto repair. Its just scrap if it isn't hooked up, usable and ready to go.
sberry,
I'm going to see if I can make that happen!
To be continued.......
Bill
