sberry
Making lists doesn't do much.
Bill,
Maybe I am going against the grain, but I believe the Invertec is a great machine to learn TIG welding steel on. Not having AC is only an issue if you want to weld aluminum, otherwise steel and stainless will be fine. I learned on my V-250S, and didn't have the benefit of a foot pedal. I can agree not having high frequency start adds some difficulty, but learning lift start is really no harder than learning to strike an arc with a stick electrode. Once you get the feel for it, it becomes almost second nature. As far as not having a gas solenoid, its more of an inconvenience than anything else.....you still get the pre and post flow, and while you may waste more gas, it will ultimately be very little as you can simply shut it off at the torch handle.
Here's the real question....do you really need a TIG machine? If not, then there is no reason to spend money on this one (or any other for that matter). On the other hand, if you are serious about learning and do have a need for the skill, I say go for it. Even if down the road you decide you need a TIG with more bells and whistles, you can use the majority of the equipment you buy on the next machine.
Just understand that TIG welding steel is very limited, slow and tedious, and has a much higher learning curve than MIG or stick. That being said, it can be a very rewarding endeavor, but it isn't for everyone.
Jason280,
Let me start by saying that I DO NOT NEED ANY of the welders. This is all just for my own entertainment. I don't expect to ever make any money with them. I just want to be able to stick pieces of metal together. Don't really know what I want to build beyond a welding cart and fab table and rolling bases for machines. Might do some mods on trailers I have.
So as it stands, I'll keep the foot pedal that is on it's way. I'll forego the rest until a little later. I want to keep the money in my pocket as a buffer. I can always pick those things up when I want to. At least I know the machine works, and I can learn stick with it.
I just unhooked it temporarily to rearrange the garage and already feel the loss of not having it ready to use. It will be hooked back up more permanently soon though.
Thanks for all the advice guys. I'm having fun.
Bill
