Great looking project! Is that bottom area going to serve as a storage shed or workshop? Cool idea.
Sent from my Pixel using Tapatalk
Very nice. Looking forward to seeing the build come together. Nice work.most likely a storage shed. we have a 10x8 shed falling apart that we will get rid of/transform as a wood storage shed.
the basement of the garage will be where we put our snowmobiles/ATV/snowblower/lawnmower.
Very nice build indeed. How do you get to the "basement" room to unload snowmobiles etc.?
Bon Travail!! Awesome idea having a basement for the other toys/equipment!! Is that two VW GTIs in the mockup?
That is awesome.... a garage with a basement. Such a great use of space. What is the weight capacity of the floor?
This is excellent use of the 24x28 garage size restriction, and the quality of construction looks to be top-notch as well. I might have opted for a compact spiral staircase between levels, but I completely understand your desire to retain and maximize all available floor space.
But then I continued on, and it started to make sense. For a minute there, I was thinking to myself "he sure is building an odd swimming pool".But then I continued on, and it started to make sense.
I really like the basement under the garage idea, which effectively doubles the usable amount of space allowed.I was surprised to see the Tyvek wrap going up over bare wall studs, are you planning on using something like OSB or plywood for your inside walls?
Looking forward to your continued updates!![]()
Ahh, okay, it's the light color that threw me. Looking closer at a couple of the photos, I can also see some of it still on the pallet.There is sheeting underneath the Tyvek... Its ... 1" 1/8, called sonoclimat R4 (https://www.mslfibre.com/Produits/Fiche/14/SONOclimatR4) , and we put angled metallic bracing in all 8 corners for stability.
Inside walls will be a reflective pvc pannel name muralex from vicwest ( https://vicwest.com/products/agricultural/liner-panels/muralex/ )
I would put it on the ceiling. let the hose hang enough so you can grab it from floor level.
nice shop!
What is the floor/ceiling rated for?
Looks great. Being mostly underground, the basement should stay a comfortable temp
Mouthlol, what model is that pressure washer ?
