My new garage [PICs HEAVY]
mouthlol
quebec
Great looking project! Is that bottom area going to serve as a storage shed or workshop? Cool idea.
Sent from my Pixel using Tapatalk
most likely a storage shed. we have a 10x8 shed falling apart that we will get rid of/transform as a wood storage shed.
the basement of the garage will be where we put our snowmobiles/ATV/snowblower/lawnmower.
KrucksGarage
Washington State
Very nice. Looking forward to seeing the build come together. Nice work.
mouthlol
quebec
Also, here is what the interior will look like:
cabinets are newage pro 3.0
mouthlol
quebec
Very nice build indeed. How do you get to the "basement" room to unload snowmobiles etc.?
Since the laws in our neighborhood only accepted 24x28 as the garage size, we didnt want to lose space with stairs or anything else. The basement will only be accessible by outside.
our backyard ground level is already pretty close to the basement door
edit: see picture:
dare23
Oakville
Bon Travail!! Awesome idea having a basement for the other toys/equipment!! Is that two VW GTIs in the mockup?
mouthlol
quebec
That is awesome.... a garage with a basement. Such a great use of space. What is the weight capacity of the floor?
Sorry, I don't remember the number on the top of my head. All i remember is that when the guy told me the number i said, well never reach that.
Ill ask again when i see the concrete guys.
drivesitfar
Mouth: great looking build and plan. i was looking at a lot in the past that my bride and I were talking about building on a very sloped lot and under the garage was going to be our racquetball court. that didn't make it to fruition, but I still liked the idea.
I don't know how cold or wet your winters are, but looks like maybe you are going to have it roofed and out of the weather before winter so you can maybe work on the insides during the cold and wet weather.
what are you going to use for finished surface for the driveway? rock, asphalt, cement or do tell?
good luck
el monte slim
Midwest USA
This is excellent use of the 24x28 garage size restriction, and the quality of construction looks to be top-notch as well. I might have opted for a compact spiral staircase between levels, but I completely understand your desire to retain and maximize all available floor space.
mouthlol
quebec
Our first idea was something like 28x40 but when we went for our permit it knocked us back to ground because the limitations are 80% width of the house and 100% depth.. so we maxed out and decided to go with a basement.
Not gonna lie, cost wise its probably twice as much as a garahe with a floating slab.. but i think it will be worth it in the end.
C_F
Utah...SNOW BLOWS!
For a minute there, I was thinking to myself "he sure is building an odd swimming pool". :lol: But then I continued on, and it started to make sense.
I really like the basement under the garage idea, which effectively doubles the usable amount of space allowed. :thumbup: I was surprised to see the Tyvek wrap going up over bare wall studs, are you planning on using something like OSB or plywood for your inside walls?
Looking forward to your continued updates! :)
mouthlol
quebec
There is sheeting underneath the Tyvek... Its ... 1" 1/8, called sonoclimat R4 (https://www.mslfibre.com/Produits/Fiche/14/SONOclimatR4) , and we put angled metallic bracing in all 8 corners for stability.
Inside walls will be a reflective pvc pannel name muralex from vicwest ( https://vicwest.com/products/agricultural/liner-panels/muralex/ )
C_F
Utah...SNOW BLOWS!
Ahh, okay, it's the light color that threw me. Looking closer at a couple of the photos, I can also see some of it still on the pallet.
The interior Muralex material looks pretty neat, from the photos on their site.
mouthlol
quebec
updated from friday:
-all doors/windows installed
-radiant floors plumbed/wired/tested/working
-side/back walls exterior finished in canexel
next steps are most likely going to be finish interior wiring, clean up interior.
im still thinking on how to finish up the interior...
the cabinets are sitting on the top floor, i would like to have the floor epoxied before finishing up the walls/installing cabinets but I dont really want to put the cabinets outside for 2-3 days.. and they weigh a ton and a half..
anyways, pretty happy as of now
mouthlol
quebec
Here I am as of today:
Wondering if I should put the air hose reel on the ceiling or the wall?
mouthlol
quebec
Walls are finally finished in Muralex.
Next is hooking up pressure washer + finishing up ceiling
ddawg16
S. California
What is the floor/ceiling rated for?
Looks great. Being mostly underground, the basement should stay a comfortable temp
