When you start a project like this you have in mind one thing and then because of various twists and turns you wind up with something different. You take what the property gives you as it were. I had to get it all cleaned out to see what I had to work with and then proceed from there. As for " restoring " the building some goals I started with were:
#1- without question this was to be a working shop and not a museum. I always had in mind bringing in projects, cars mostly but not exclusively. Many types of items have been fabricated out there over the years and I would be also.
#2- I like old school but some new tools and methods are much better. For example, I have a wire feed, mig/tig welder plus a plasma cutter and love the time savings they provide as well as the quality of work they can produce. But I did retain the old Lincoln arc welder and use it when needed.
#3- I never intended to do body or paint work of any kind in there which shaped how the work space would be allocated.
#4- I wanted to restore and use any old tools or machines whenever possible but they had to function not merely be display ( see #1 ).
#5- I wanted it to be visually appealing. A warm, clean, organized atmosphere promotes good quality work for me. To others it may not matter, but it does to me.
I never planned on doing any blacksmith work so I knew most of that equipment would not be retained. Additionally there was equipment to rebuild plow shares, sickle bars, sharpen reel type lawn mower blades etc. That and other equipment all fell outside of what I planned on using the shop for.
As work proceeded, how the shop emerged dictated the direction I went. Bare concrete floors were functional but not terribly appealing. I wanted to do something different. He never had any running water out there ( the house was just a few steps away ) so no bathroom. I put one in. It never had a driveway bell, ( it didn't have a concrete driveway) but I wanted to put a period correct one in. It didn't have a sound system but I love working to period music so that went in. When you "restore" projects like this there are constant compromises that need to be made. In the end I feel if the owner were to come back the shop it would be very recognizable, but different at the same time. I did the shop for myself with homage to the past. I've told the family many times it will always be their dad's shop, I am just the present caretaker. His presence is always there. The entrance door is in the same spot, his welder is just inside to the right as before, Pepsi machine in it's designated spot as well, his cast iron welders bench is within inches of where he placed it, through the doorway is the lift, his " CASH only " sign over the tool box etc. These are my memories too from my past history of being in there at a very young impressionable age. This shop may have had a bigger impact on my life than I know. It's just a very special place to me.
Thomas
Thomas
I apologize unequivocally and without reservation. I am truly sorry if anyone might have taken offense at that characterization etc.............it's so hard to be PC these days, so hard...........
See it all really started at an early age when I was exposed to too much welding smoke and then one thing lead to another and before you knew it ....................
